thesnake
14年6个月前 IP:未同步
164110
把手钻改成这样了啊
wangshuo
14年6个月前 IP:未同步
164113
[s:247]
NB
heqiaokyou
14年6个月前 IP:未同步
164116
喷什么出来?
computerpan
14年6个月前 IP:未同步
164129
会不会打到自己 [s:247]
delete
14年6个月前 IP:未同步
164136
外星人的枪! 莫非枪的主人是外星人?
finalapple
14年6个月前 IP:未同步
164155
这么出门吓唬小朋友是不对滴····会被集体拍砖的
卡布卡作者
14年6个月前 IP:未同步
164159
打到自己  不会吧 [s:247]
潜伏者
14年6个月前 IP:未同步
164173
看样子像是老外做的那个。
3c
14年6个月前 IP:未同步
164175
什么枪这么灵异呢?
小特斯拉圈圈
14年6个月前 IP:未同步
164202
引用第4楼computerpan于2009-11-14 15:05发表的  :
会不会打到自己 [s:247]
不会
电弧又太不长
小特斯拉圈圈
14年6个月前 IP:未同步
164203
引用第6楼finalapple于2009-11-14 15:59发表的  :
吓唬小朋友?好主意啊
小特斯拉圈圈
14年6个月前 IP:未同步
164206
引用第3楼heqiaokyou于2009-11-14 14:59发表的  :
喷什么出来?
高压电
小特斯拉圈圈
14年6个月前 IP:未同步
164212
The design for this Tesla Coil is based on the larger battery powered DIY Tesla Coil project but with the aim of getting a much smaller and portable device. A Power Pulse Modulator circuit is used to drive two small high voltage ignition coils wired together in an 'anti-parralel' configuration. The output is rectified and used to charge the tank capacitor of a small spark gap Tesla Coil.
The device is packed into the casing of chepo cordless drill from a DIY store. This drill used an 18V battery and comes with a charger which made it ideal for the project. The ignition coil driver circuit used takes a direct 18V input which is connected using the original switch from the drill.
This video clip shows the plasma gun causing a nearby light bulb to light up as if it were a plasma globe.
The high frequency, high voltage from the plasma gun causes the Argon gas in the light bulb to become ionized. This creates streamers that are attracted to the fingers holding it.
The device draws about 6 amps from a well charged 12 V battery which makes the total power consumption to around 72 watts. Unfortunately this low power means the plasma arcs will be limited in size, but since it is hand held that's probably a good thing. The typical length of the output arcs is between 5 and 7cm.
Such a small Tesla Coil inherently has quite a high resonant frequency which in this case is about 500 kHz. This frequency is too high to feel as electric shock but when being zapped you can feel the low frequency component of the spark gap firing rate.
PARTS LIST
PWM-OC10ADrive Circuit
SW1Trigger Switch
Spark Coil 1 & 2Small Ignition Coils
D115kV Diode x 4
C11nF 15kV
C22nF 15kV
C3Topload Sphere
L1RF Choke 10uH
L2RF Choke 10uH
L3TC Primary Coil
L4TC Secondary Coil
Input Voltage12 VDC
Power Consumption75W Max
Max Arc Length5cm (in air)
7cm (with gas)
Output Voltage (approx)50kV
Primary Transformer2 x small ignition coils < 20kV
Spark GapSealed Static gap. ~4mm
Primary Turns
Primary Diameter
Primary Inductance
70 mm
1 uH
Secondary Turns
Secondary Height
Secondary Diameter
Secondary Inductance
Secondary Resistance
520
135 mm
26 mm
900 uH
10 ohms
Topload32 mm Sphere
Special FeaturesHand Held
Portable
Battery Powered
Trigger Activated
Plasma / Flame discharge
The main driving circuit is a type of pulse width modulation circuit with protection against high voltage spikes. It is adjusted to get the maximum output from the two ignition coils.
The two ignition coils were stripped of the casing in order to reduce the overall size and allow access to the internal wiring. The inputs are wired in an anti-parallel arrangement to help keep the charging voltage high when under load.
The HV outputs of the spark coils are connected to a rectifier (D1) made from four HV diodes potted in epoxy resin. Connected to this is a small smoothing capacitor (C1) which helps to reduce the ripple in the HV DC output. The tank capacitor (C2) is charged from the HV DC supply via two RF chokes (inductors L1 & L2) which serve to prevent the RF oscillations of the TC primary circuit from interfering with the rest of the circuit.
The previous battery powered tesla coil design needed to be well connected to a good RF ground such as a metal rod in the earth. Without this the output would be limited and the driver circuit would be prone to failure.
With this mini tesla coil the RF ground connection is made by connecting it to a copper pad on the handle.
The body of the person holding the device is used as the RF ground and the large area of copper ensures the energy is spread out to prevent RF burns.
In most Tesla Coils this would not be safe at all but this device is very low power so there is little risk of electric shock. The RF its self probably isn't too healthy though!
The TC part (Tesla Coil) uses the common single static spark gap and flat primary design for simplicity and size. The primary coil is closely wound around the base of the secondary with several layers of insulation tape preventing flashover.
The topload sphere is made from a metal draw handle which has been drilled to allow gas to be ejected from the end. A pipe from this sphere runs down the inside of the secondary and to the back of the handle where it can be connected to a gas supply.
Using noble gasses such as Argon or Neon will cause the output arcs to be forced along the flow of gas. This allows the plasma to be directed in a straight line from the tip of the plasma gun. It is also possible to use butane gas which makes this thing into some kind of flamethrower - plasma gun hybrid. The electricity is conducted along the flame from its tip. You can see photos of this effect on our plasma page.
Apart from making cool arcs of plasma, this device even transmits wireless electrical power. It can light bulbs and fluorescent lights just from being nearby.
The interference created by this wireless energy can cause all sorts of electronic devices to switch on and off or start behaving erratically. This is because the energy is causing tiny currents to be induced in the tracks and wires in the devices. If a simple circuit had a matching resonant frequency to that of the plasma gun, it would be possible to collect the wireless energy from a greater distance.
There are several improvements that could be made on this design which could result in a greater power throughput and therefore bigger arcs.
The spark gap is just a single gap which has been seal inside a plastic case for safety and size. This sort of switching will have poor performance due to quenching difficulties and oxide buildup. A solid state version would be better but it would likely be larger and considerably more expensive.
A larger topload would allow for larger breakouts, but it would also need more primary capacitance. The secondary coil is also rather long relative to its width. Ideally this would be shorter and wider.
方旭
14年6个月前 IP:未同步
164238
强!真用手拿着啊?!牛啊 [s:247]
點蒼
14年6个月前 IP:未同步
164240
感觉很火星,,,有外星人的味道
卡布卡作者
14年6个月前 IP:未同步
164249
烤羊肉不错 [s:94]
power_rdx
14年6个月前 IP:未同步
164315
这个真科幻
小特斯拉圈圈
14年6个月前 IP:未同步
164330
引用第15楼點蒼于2009-11-14 19:10发表的  :
感觉很火星,,,有外星人的味道
有臭氧的味道
black
14年6个月前 IP:未同步
164334
YouTube上面早就有了
iamjedi
14年6个月前 IP:未同步
164680
这个不错我也打算做一把。。。
春华秋实玖
14年6个月前 IP:未同步
164804
这个真科幻
这可是实实在在的!
stitch
14年6个月前 IP:未同步
164810
这个………………要是再有紫外激光就爽了!
卡布卡作者
14年6个月前 IP:未同步
164848
引用第22楼stitch于2009-11-15 23:09发表的  :
有紫外线 但 没有激光
nhlijiaming
14年6个月前 IP:未同步
164891
RF GND得怎么做?
小特斯拉圈圈
14年6个月前 IP:未同步
164903
引用第24楼nhlijiaming于2009-11-16 13:19发表的  :
RF GND得怎么做?
接地嘛
这里是上面有铜片,人碰铜片,接地
nhlijiaming
14年6个月前 IP:未同步
164998
引用第25楼特斯拉线圈于2009-11-16 13:48发表的  :
接地嘛
这里是上面有铜片,人碰铜片,接地
岂不是把自己也电了一会?!
应该是大面积的金属箔作为电容电极吧?
hypermania
14年6个月前 IP:未同步
166491
Copper grounding pad on handleWith this mini tesla coil the RF ground connection is made by connecting it to a copper pad on the handle.
(功率小,人当地线也不怕)
小特斯拉圈圈
14年6个月前 IP:未同步
166493
引用第26楼nhlijiaming于2009-11-16 21:15发表的  :
岂不是把自己也电了一会?!
应该是大面积的金属箔作为电容电极吧?
功率一大人就糊了..
卡布卡作者
14年6个月前 IP:未同步
166494
引用第28楼特斯拉线圈于2009-11-22 13:12发表的  :
功率一大人就糊了..
皮糊了
小特斯拉圈圈
14年6个月前 IP:未同步
166500
引用第29楼zxzxz于2009-11-22 13:21发表的  :
皮糊了
功率再大就蒸发了.
йvdanger⊥
14年6个月前 IP:未同步
166521
好象没什么用处吧,威力也不打,不过,是个自残的好工具.................
hypermania
14年6个月前 IP:未同步
166527
那个线圈和放电端貌似跟某个器官很像。。。。。。
xseven007
12年4个月前 IP:未同步
355724
要是能像13号仓库那种特斯拉枪那就碉堡了~~
ktcat_2008
12年4个月前 IP:未同步
356055
这外国人什么都能搞出来
小特斯拉圈圈
12年4个月前 IP:未同步
356057
两年前的坟又被挖出来了~
话说我看标题还以为发错版了
鱼小凡1809
12年3个月前 IP:未同步
370928
这电弧会打到自已吧
tslahz
2012-02-25
再次挖坟...
Τerminator
12年2个月前 IP:未同步
373474
电不到自己
PS感谢楼上挖坟 我盗墓
卡布卡
2008/12/22注册,6年3个月前活动
