最近学IIC,拿PCF8563做个钟!在OURAVR得到很多帮助,再次感谢!
冲压发动机2010/06/30电子技术 IP:浙江
高手不要笑啊!
+100  科创币    虎哥    2010/06/30 应该详细讲下电路、制作 ..
冲压发动机 作者
13年11个月前 IP:未同步
230387
哦!那就说说吧!放芯片那板是我用油性笔画的。    电路很简单。相信大家都懂!
#include<reg52.h>
#define uchar unsigned char
sbit sda=P1^7;
sbit scl=P1^6;
sbit w1=P2^0;
sbit w2=P2^1;
sbit w3=P2^2;
sbit w4=P2^3;
sbit w5=P2^4;
sbit w6=P2^5;
sbit w7=P2^6;
sbit w8=P2^7;
unsigned char leddata[]={
                0xC0,  //"0"
                0xF9,  //"1"
                0xA4,  //"2"
                0xB0,  //"3"
                0x99,  //"4"
                0x92,  //"5"
                0x82,  //"6"
                0xF8,  //"7"
                0x80,  //"8"
                0x90,  //"9"
                0x88,  //"A"
                0x83,  //"B"
                0xC6,  //"C"
                0xA1,  //"D"
                0x86,  //"E"
                0x8E,  //"F"
                0x89,  //"H"
                0xC7,  //"L"
                0xC8,  //"n"
                0xC1,  //"u"
                0x8C,  //"[s:9]"
                0xA3,  //"o"
                0xBF,  //"-"
                0xFF,  //熄灭
                0xFF  //自定义
uchar t, a,month,day,fen,shi,miao;
uchar mo1,mo2,f1,f2,d1,d2,s1,s2;
void disp(uchar mo1,uchar mo2,uchar day1,uchar day2,uchar shi1,uchar shi2,fen1,uchar fen2);
void delay1(uchar x);
void read_8563();
void delay()
void start()  //开始信号
    sda=1;
    delay1(1);
    //delay1(1);
    disp(mo1,mo2,d1,d2,s1,s2,f1,f2);
    scl=1;
    delay1(1);
    //delay1(1);
    sda=0;
    delay();
void stop()   //停止
    sda=0;
    delay();
    scl=1;
    delay();
    sda=1;
    delay();
void respons()  //应答
    uchar i;
    scl=1;
    delay();
    while((sda==1)&&(i<250))i++;
    scl=0;
    delay();
void init()
    sda=1;
    delay();
    scl=1;
    delay();
void write_byte(uchar date)
    uchar i,temp;
    temp=date;
    for(i=0;i<8;i++)
        temp=temp<<1;
        scl=0;
        delay();
        sda=CY;
        delay();
        scl=1;
        delay();
    //    scl=0;
     //   delay();
    scl=0;
    delay();
    sda=1;
    delay();
uchar read_byte()
    uchar i,k;
    scl=0;
    delay();
    sda=1;
    delay();
    for(i=0;i<8;i++)
        scl=1;
        delay();
        k=(k<<1)|sda;
        scl=0;
        delay();
    return k;
void delay1(unsigned int x)
    uchar a,b;
    for(a=x;a>0;a--)
     for(b=100;b>0;b--);
void write_add(uchar address,uchar date)
    start();
    write_byte(0xa2);
    respons();
    write_byte(address);
    respons();
    write_byte(date);
    respons();
    stop();
uchar read_add(uchar address)
    uchar date;
    start();
    write_byte(0xa2);
    respons();
    respons();
    start();
    write_byte(0xa3);
    respons();
    date=read_byte();
    stop();
    return date;
void uart()
     TMOD=0x21;//设置定时器1为工作方式2,8位自动重装,设定时器0为16位定时器。    d=0;
    TH1=0xfd;
    TL1=0xfd;
    TR0=1;
    ET0=1;
    TH0=0x4c;
    TL0=0x00;
    TR1=1;//启动定时器1
    REN=1;// 允许串行接收。
    SM1=1; //方式1,8位UART
    EA=1; //开总中断
    ES=1; //开串行中断
void main()
    init();
    uart();
    write_add(0x07,0x06);    //月
    delay1(100);
    delay1(100);
    write_add(0x05,0x29); // 日
    delay1(100);
    delay1(100);
       write_add(0x04,0x23); //时
    delay1(100);
    delay1(100);
    write_add(0x03,0x29);  //分
    delay1(100);
    delay1(100);
     P2=0xff;
    while(1)
          mo1=month/10;
           mo2=month%10;
           d1=day/10;
           d2=day%10;
           s1=shi/10;
           s2=shi%10;
           f1=fen/10;
           f2=fen%10;
          if(t==20)
              t=0;
            read_8563();
            ES=0;
            SBUF=miao;
            while(!TI);
            TI=0;
            ES=1;
w1=0;
P0=leddata[mo1];
delay1(10);
w1=1;
P0=0xff;
w2=0;
P0=leddata[mo2];
delay1(10);
w2=1;
P0=0xff;
w3=0;
P0=leddata[day1];
delay1(10);
w3=1;
P0=0xff;
w4=0;
P0=leddata[day2];
delay1(10);
w4=1;
P0=0xff;
w5=0;
P0=leddata[shi1];
delay1(10);
w5=1;
P0=0xff;
w6=0;
P0=leddata[shi2];
delay1(10);
w6=1;
P0=0xff;
w7=0;
P0=leddata[fen1];
delay1(10);
w7=1;
P0=0xff;
w8=0;
P0=leddata[fen2];
delay1(10);
w8=1;
P0=0xff;
void read_8563()
       miao=read_add(0x02)&0x7f;//获取秒数据
      /* miao=((miao&0xf0)>>4&0x0f)*10+(miao&0x0f);//BCD码转换成10进制数
   if(miao>=60){miao=0;} */
   fen=read_add(0x03)&0x7f;//获取分钟
   fen=((fen&0xf0)>>4&0x0f)*10+(fen&0x0f);//BCD码转换成10进制数
   if(fen>=60){fen=0;}
   shi=read_add(0x04)&0x3f;//获取小时
   shi=((shi&0xf0)>>4&0x0f)*10+(shi&0x0f);//BCD码转换成10进制数
   if(shi>=24){shi=0;}
   day=read_add(0x05)&0x3f;//获取日数据
        day=(( day&0xf0)>>4&0x0f)*10+( day&0x0f);//BCD码转换成10进制数
   if( day>=31){ day=0;}
  /* week=read_add(0x06)&0x07;//获取星期
   if(week>6){week=0;} */
   month=read_add(0x07)&0x1f;//获取月
   month=((month&0xf0)>>4&0x0f)*10+(month&0x0f);//BCD码转换成10进制数
   if(month>=24){month=0;}
  /* year=read_add(0x08)&0xff;//获取年
   year=((year&0xf0)>>4&0x0f)*10+(year&0x0f);//BCD码转换成10进制数
   delay1(100); */
void time()    interrupt 1
    TH0=0x4c;
    TL0=0x00;
    t++;
   void ser() interrupt 4
    RI=0;
    P0=SBUF;
+300
2010-06-30
原创
立蛋
13年11个月前 IP:未同步
230414
没有很好的逻辑思维我,写不出来。
冲压发动机作者
13年11个月前 IP:未同步
230415
呵!有分加!谢谢!我还要加把油!
13年11个月前 IP:未同步
230443
我有一个老式单片机谁要?我当时花300在武汉力源邮购买的 用BASIC语句的 除了9伏层叠电池没电了之外其他包装盒说明书电脑连接线程序软盘都全新。
AsyncMaster
13年11个月前 IP:未同步
230449
一个单片机居然要300……无语
的卢宝马
13年11个月前 IP:未同步
230467
引用第4楼87685302于2010-06-30 23:49发表的  :
额 我收集了一套夏普的PC1500,带打印的。
小特斯拉圈圈
13年11个月前 IP:未同步
230497
300.............
stitch
13年11个月前 IP:未同步
230540
[s:247] 居然要300大洋……………………什么单片机啊?
shiaki
13年11个月前 IP:未同步
230585
估计是开发板吧?BASIC stamp?
nhlijiaming
13年11个月前 IP:未同步
231062
这里是KC,不是ourdev........
冲压发动机
2006/03/11注册,3年10个月前活动
