已经帮楼主编辑。包含代码请使用backtick(数字1左边的键),具体参考markdown规范。
<code class="language-c">#include<reg52.h> #define uint unsigned int #define uchar unsigned char uchar code table[]={ 0x3f,0x06,0x5b,0x4f, 0x66,0x6d,0x7d,0x07, 0x7f,0x6f,0x77,0x7c, 0x39,0x5e,0x79,0x71}; uint tent,sec; bit write=0; sbit sda=P1^2; sbit scl=P1^7; sbit dula=P2^6; sbit wela=P2^7; void delay() {;;} void delay1ms(uint z) { uint x,y; for(x=0;x<z;x++) for(y="0;y<110;y++);" } void start() { sda="1;" delay(); scl="1;" stop() response() uint i; while((sda="=1)&&(i<250))" i++; init() write_byte(uchar date) uchar temp,i; temp="date;" for(i="0;i<8;i++)" read_byte() k,i; k="(k<<1)|sda;" dealy(); return k; write_24c02(uchar adress,uchar start(); write_byte(0xa0); response(); write_byte(adress); write_byte(date); stop(); read_add(uchar adress) date; write_byte(0xa1); date="read_byte();" display(uchar shi,uchar ge) dula="1;" p0="table[shi];" wela="1;" delay1ms(5); main() init(); sec="read_add(2);" if(sec>100) sec=0; TMOD=0x01; TH0=(65535-50000)/256; TL0=(65535-50000)%256; EA=1; ET0=1; TR0=1; while(1) { display(sec/10,sec%10); if(write==1) { write=0; write_24c02(2,sec); } } } void qwe()interrupt 1 { TH0=(65535-50000)/256; TL0=(65535-50000)%256; tent++; if(tent=20) { tent=0; sec++; write=1; if(sec==100) sec=0; } } </z;x++)></reg52.h></code>
[修改于 7年10个月前 - 2016/06/16 12:22:19]
虽然不知道硬件电路,但是十分可能是某个地方的delay()延时不够久。
给你个参考 display.c
<code class="language-c">#include "stm8s.h" #include "display.h" #define A(a) a ? (GPIOA->ODR |= GPIO_PIN_1):(GPIOA->ODR &= (~GPIO_PIN_1)) #define B(a) a ? (GPIOF->ODR |= GPIO_PIN_4):(GPIOF->ODR &= (~GPIO_PIN_4)) #define C(a) a ? (GPIOC->ODR |= GPIO_PIN_5):(GPIOC->ODR &= (~GPIO_PIN_5)) #define D(a) a ? (GPIOC->ODR |= GPIO_PIN_7):(GPIOC->ODR &= (~GPIO_PIN_7)) #define E(a) a ? (GPIOD->ODR |= GPIO_PIN_0):(GPIOD->ODR &= (~GPIO_PIN_0)) #define F(a) a ? (GPIOA->ODR |= GPIO_PIN_2):(GPIOA->ODR &= (~GPIO_PIN_2)) #define G(a) a ? (GPIOC->ODR |= GPIO_PIN_4):(GPIOC->ODR &= (~GPIO_PIN_4)) #define DP(a) a ? (GPIOC->ODR |= GPIO_PIN_6):(GPIOC->ODR &= (~GPIO_PIN_6)) // 0 1 2 3 4 5 6 7 8 9 P - const uint8_t display_data[] = {0xFC,0X60,0xDA,0xF2,0x66,0xB6,0xBE,0xE0,0xFF,0xF6,0xCE,0x02}; //void Display_b(uint8_t data); //void Display_3(uint16_t data,uint8_t dp,uint8_t dig); //显示刷新函数 /* uint8_t dp == 小数点高有效 3'b000 ~ 3'b111 */ void Display(uint8_t dp) { extern uint8_t dig_1,dig_2,dig_3,display_cnt; switch(display_cnt) { case 0: GPIOD->ODR &= (~GPIO_PIN_7);//DIG3_LOW A(dig_1 & 0X80); B(dig_1 & 0X40); C(dig_1 & 0X20); D(dig_1 & 0X10); E(dig_1 & 0x08); F(dig_1 & 0X04); G(dig_1 & 0X02); DP(dp & 0x04); GPIOD->ODR |= GPIO_PIN_3;//DIG1_HIGH break; case 1: GPIOD->ODR &= (~GPIO_PIN_3);//DIG1_LOW A(dig_2 & 0X80); B(dig_2 & 0X40); C(dig_2 & 0X20); D(dig_2 & 0X10); E(dig_2 & 0x08); F(dig_2 & 0X04); G(dig_2 & 0X02); DP(dp & 0x02); GPIOD->ODR |= GPIO_PIN_2;//DIG2_HIGH break; case 2: GPIOD->ODR &= (~GPIO_PIN_2);//DIG2_LOW A(dig_3 & 0X80); B(dig_3 & 0X40); C(dig_3 & 0X20); D(dig_3 & 0X10); E(dig_3 & 0x08); F(dig_3 & 0X04); G(dig_3 & 0X02); DP(dp & 0x01); GPIOD->ODR |= GPIO_PIN_7;//DIG3_HIGH break; } display_cnt++; if(display_cnt == 3) display_cnt = 0; } void Display_Init(void) { //PA 1 2 GPIO_Init(GPIOA,(GPIO_Pin_TypeDef)(GPIO_PIN_1 | GPIO_PIN_2), GPIO_MODE_OUT_PP_LOW_FAST); //PC 4 5 6 7 GPIO_Init(GPIOC,(GPIO_Pin_TypeDef)(GPIO_PIN_4 | GPIO_PIN_5 | GPIO_PIN_6 | GPIO_PIN_7), GPIO_MODE_OUT_PP_LOW_FAST); //PD 0 2 3 7 GPIO_Init(GPIOD,(GPIO_Pin_TypeDef)(GPIO_PIN_0 | GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_7), GPIO_MODE_OUT_PP_LOW_FAST); //PF 4 GPIO_Init(GPIOF,GPIO_PIN_4, GPIO_MODE_OUT_PP_LOW_FAST); } /* 数码管显示数据刷新 uint16_t data == 显示数据 0 ~ 999 */ void Display_update(uint16_t data) { extern uint8_t dig_1,dig_2,dig_3; dig_1 = display_data[((uint8_t)(data/100))] ; dig_2 = display_data[((uint8_t)((data%100)/10))]; dig_3 = display_data[((uint8_t)(data%10))]; } </code>
display.h
<code class="language-c">#include "stm8s.h" #ifndef DISPLAY_H_ #define DISPLAY_H_ void Display_Init(void);//数码管初始化 void Display(uint8_t dp);//数码管刷新 void Display_update(uint16_t data);//数码管显示数据更新 #endif </code>
我是stm8io冲突没法使用整组io只能这么搞了 每次调用显示函数移位一次每次显示小号69 -71时钟周期
<code class="lang-"> ORG 00H AJMP MAIN ORG 0BH AJMP T0INT ORG 30H MAIN:LCALL INIT ;初始化 START:LCALL DISP ;开始 JB P1.4,PAUSE SETB TR0 AJMP START PAUSE: LCALL DISP //暂停 JB P1.5,CLEAR CLR TR0 AJMP PAUSE CLEAR: LCALL DISP //清零 JB P1.6,START CLR TR0 MOV R4,#0 MOV R0,#0 AJMP CLEAR DISP: //显示 MOV A,R4 MOV B,#10 DIV AB MOV DPTR,#TAB //不带小数点显示 MOVC A,@A+DPTR MOV P0,A CLR P1.0 CLR P1.2 CLR P1.3 ACALL D1MS SETB P1.0 SETB P1.2 SETB P1.3 MOV A,B MOVC A,@A+DPTR MOV P0,A CLR P1.1 CLR P1.2 CLR P1.3 ACALL D1MS SETB P1.1 SETB P1.2 SETB P1.3 ACALL D1MS MOV A,R0 MOV B,#10 DIV AB MOV DPTR,#TAB MOVC A,@A+DPTR MOV P0,A CLR P1.2 CLR P1.0 CLR P1.1 ACALL D1MS SETB P1.2 SETB P1.0 SETB P1.1 MOV A,B MOV DPTR,#TABEL ;带小数点显示 MOVC A,@A+DPTR MOV P0,A CLR P1.3 CLR P1.0 CLR P1.1 ACALL D1MS SETB P1.3 SETB P1.0 SETB P1.1 RET INIT:MOV SP,#60H MOV R4,#0 MOV DPTR,#TAB MOV TMOD,#01H MOV TH0,#0D8H ; 10MS MOV TL0,#0F0H SETB ET0 SETB EA RET T0INT: MOV TH0,#0D8H MOV TL0,#0F0H INC R4 CJNE R4,#100,RTI ;10MS X 100 = 1S MOV R4,#0 INC R0 CJNE R0,#100,RTI MOV R0,#0 RTI: RETI D1MS: MOV R7,#01H DL1: MOV R6,#8EH DL0: MOV R5,#02H DJNZ R5,$ DJNZ R6,DL0 DJNZ R7,DL1 RET TAB: DB 3FH,06H,5BH,4FH,66H,6DH,7DH,07H,7FH,6FH 不带小数点显示 TABEL: DB 0BFH,86H,0DBH,0CFH,0E6H,0EDH,0FDH,0F7H,0FFH,0EFH 带小数点显示 END </code>
