科创茶话
手被陌生人摸一下肿了,起水泡、红疹,有没有可能是剧毒试剂之类?
Bobby 2018-12-13 18:34:11
事情很诡异,让我这种工科生难以理解,事情经过是这样:
    有个陌生外省人士(穿着光鲜)去找我老爸聊天。我老爸以为他来询问问题的,就聊了起来,对方说他是来附近参加演出,闲着到处逛。然后那个人有一句没一句聊来聊去,然后说给我老爸把脉。我老爸说当时也很疑惑,因为这人的言语和行为都有点怪怪的。
     结果那人走后,几个小时后,被把脉的位置就开始痒,起水泡,几天过去了,症状加重到图中所示。
    前阵子聊电话中,我老爸说是可能被人整了,有可能对方会来敲诈,我不以为意,说别想太多,都什么年代了,估计只是过敏而已。然后我老爸说肯定有关,就是把脉的位置起水泡,传染很快,还痒,然后又说,如果对方准备敲诈,几天后肯定会回来。我叫他拍照看看,他说自己不会拍(我当时一直认为他想多了,也就没认真让他找人帮忙拍)
    然后我老爸突然来电话,说不出所料,那个人还真来了,可惜不是我老爸值班,没碰上。
    这个时候我觉得蹊跷,让我老爸拍照看看,他说不会。最后我选择了视频聊天,叫他把摄像头对着痒的位置。然后吓我一跳,三只指印太明显了!!!!!!
    坛友们有见过类似的事情么,我百度谷歌都没搜到类似的资料。感觉那个人应该是用了什么药粉之类的,现在几个指印的地方浮起来了,表面皮也破了,还有小水泡。。。刚叫我老爸今晚找时间找亲戚(当医生的)看看。
pic
[修改于 4 个月前 - 2018-12-20 19:07:34]
加载全文
2018-12-25 01:14:16
90楼
化学品致敏在欧盟REACH有害物质管制标准当中的地位仅次于致癌致畸致突变,logo也一样是“胸部碎裂”,即“有造成不可逆后果的风险”。
[修改于 4 个月前 - 2018-12-25 01:15:32]
2018-12-25 01:24:35
91楼
引用:虎哥 发表于89 楼的内容:
记得根据过敏机理不同,某些过敏源就是要接触以后才会致敏,第一次没事,第二次卒。
部分过敏源更严重,接触一段时间之后突然变成对其他物质(交叉)过敏的过敏体质,甚至过敏性哮喘患者。
类似用山寨化妆品用成敏感肌。
http://www.ilpi.com/msds/ref/sensitizer.html
Sensitizer
Definition
A sensitizer is defined by OSHA as "a chemical that causes a substantial proportion of exposed people or animals to develop an allergic reaction in normal tissue after repeated exposure to the chemical."
The condition of being sensitized to a chemical is called chemical hypersensitivity.
Additional Info
Guardian Equipment G1909 safety station
Safety Emporium carries all kinds of eye/face washes, safety showers, drench hoses and more.
Certain chemicals have no immediate health effects. But if you are exposed to them several times, they can make you allergic or sensitive to other chemicals, often quite suddenly. A classic example is formaldehyde (CH2O). Typical reactions to sensitizers can include skin disorders such as eczema and respiratory disorders such as asthma.
Sensitization is an immune response. Therefore, some people may be easily sensitized while others may never be affected. Like any allergic response, a reaction to a sensitizer can be fatal in rare circumstances. You can not predict your reaction to sensitizing chemicals, so treat all sensitizers with great respect and follow proper chemical safety and hygiene procedures.
Once you are sensitized to a particular chemical, even minute amounts will cause symptoms. Sensitization is usually a life-long effect, so avoid working with such substances even if you have suffered no ill effects in the past.
甲醛、环氧树脂反复接触都致敏。
乙二胺反复皮肤接触致敏,和其他一些胺类交叉过敏。
http://www.inchem.org/documents/sids/sids/Ethylenediamine.pdf
[修改于 4 个月前 - 2018-12-25 01:56:34]
92楼
希望楼主可以多公布一些资料比如那些人的照片之类的
[修改于 4 个月前 - 2018-12-25 10:02:21]
93楼
引用:虎哥 发表于56 楼的内容:
这个事情的诡异之处在于,当第一个受害者报告经历以后,竟然引来了第二个受害者,两位受害者的共同特点是:.....
要是我也肯定选择宁死也不报警。因为这种事情说起来太邪门儿了,接警的人正常思维下没法相信,反而会说这是臆想出来的,受迫害妄想症,弄不好反倒被当成精神病抓进去了。
Bobby(作者)
94楼
引用:极枢 发表于92 楼的内容:
照片是有的,证据都有留,但是这种情况下公布对方照片也不合适,指不定对方反咬你诬蔑诽谤。
对方摸一下起红疹,搜不到毒物的话,你也很难证明就是他下的手,也难以说对方是故意的,指不定他说你只是对他手上的汗液过敏呢。只有案例多了,才有说服力,才好定罪。如果只有个别案例,对方打死不认,根本定不了罪名。
Bobby(作者)
95楼
引用:hwdz 发表于93 楼的内容:
要是我也肯定选择宁死也不报警。因为这种事情说起来太邪门儿了,接警的人正常思维下没法相信,反而会说这是.....
假如出大问题了,涉及生命的,报警是绝对要的。报警了,就能找到对方,即使最终无法证明,无法将对方绳之于法也可以接受。反正你能得到对方长相和个人信息,后边自己想办法解决问题即可。
96楼
引用:Bobby 发表于95 楼的内容:
假如出大问题了,涉及生命的,报警是绝对要的。报警了,就能找到对方,即使最终无法证明,无法将对方绳之于.....
可问题就是现在这种情况只是出疹子,正常思维根本没办法相信摸一下就这样的事情,所以不能报警啊。
2018-12-29 21:43:40
97楼
这帖子有点吓人啊。。。。
手指角质层厚,手腕皮肤显然更敏感,利用这个差异来进行攻击也许是可行的。
关注后续。。
2019-3-28 22:18:39
Bobby(作者)
98楼
引用:zywzyw5 发表于97 楼的内容:
这帖子有点吓人啊。。。。手指角质层厚,手腕皮肤显然更敏感,利用这个差异来进行攻击也许是可行的。关注后.....
没后继了。
福建网友看医生说是麻疹,开药吃了完全没效果,隔不到几天,找对药了,说是别人给他的,也没说药名。可能他用药及时,很快就消了。
我老爸开始自己搞偏方弄不好,还越来越严重,破皮了。问医生开了皮炎药消炎之类的,抹了也没效果。后边用人给的草药,一抹隔夜就消,结痂。我老爸过了半个多月才找对药,所以比福建那位严重些,后边结痂了,隔了一段时间才好。
微博给警方信息,也没有下文。
99楼
估计这种偏门的东西网上会有揭露,有空找找看
100楼
这医生有问题啊,知道内幕却不说,一伙的?
不报警怕被当成傻子...  也是想太多..
[修改于 1 个月前 - 2019-03-29 12:42:04]
101楼
根据楼主的症状反应,可以初步排除是由于S-(2-二异丙基氨乙基)- 甲基硫代膦酸乙酯引起的
Bobby(作者)
102楼
引用:20!Dopaminor 发表于100 楼的内容:
这医生有问题啊,知道内幕却不说,一伙的?不报警怕被当成傻子...  也是想太多..
医生知道内幕?应该不知道吧。。。这种情况有点邪,没有百分百的证据,而且说白了也只是皮肤病,报警也没人理。
福建那位网友说他朋友给的药,说一瓶100,问是什么药名,也没说,可能是他朋友自己搞的偏方吧。本来还怀疑该网友是不是一伙的,不过应该不是。他自己也中招了,更何况高清监控都截图发了,确实和他文字描述的一致。
这种症状,我之前搜了很久,各种关键词搜索也没有找到其他案例。奇怪的是,去医院开的药似乎都没有效果,最后都是偏方搞定,而且疗效异常明显。比较科学的解释,可能是油漆过敏,药物毒素之类,不科学的解释嘛,蛊?虫?
想参与大家的讨论?现在就 登录 或者 注册
Github  https://github.com/kccd/nkc.git
科创研究院 (c)2001-2019
蜀ICP备11004945号-2 川公网安备51010802000058号
