牙科X射线管(全新)
计划出16个,600/个,先款500,打包优惠,注意这个新管子比二手的寿命长的多且靶面干净,求带走!
出完我会更新帖子,看得到就表示东西还在
V心:Xhrram
pic
pic
pic
pic
pic
pic
pic
pic
General Data
Safety Classification:
FDA …………………………………………………………………………………………... I
IEC60601-1:2005……………………………………………………………………………..IB
Directive 93/42/EEC ..…………………………………………………………….………… IIB
Electrical:
Circuit:
High Voltage Generator……………..……Constant Potential High-Voltage Generator
Grounding………………………………………………………….……. Center-grounded
Nominal X-ray Tube Voltage (IEC60613:2010)….………………………...…….…...70 kV
Nominal Focal Spot Value (IEC60336:2005)………………………………………….…..0.4
Nominal Anode Input Power (at 1.0s)……..……………………………..………………600 W
Exposure Duty Cycle......................................................................... 1:30 or more
        (Exposure time : interval time)
Mechanical:
Dimensions
Overall Length…………………………………………………See dimensional outline
Maximum Diameter ………………………………….……… See dimensional outline
Target:
Anode Angle(IEC/TR 60788:2004)............................................................12 degrees
Material ….................................................................................................... Tungsten
Inherent Filtration (IEC 60522:1999) ............................................ Min. 0.8 mm Al / 75 kV
X-ray Coverage ................................................................ φ70 mm at SID 200 mm
Cooling Method………………..……Oil immersed (60°C Max.) and convection oil cooling
Tube Holding .................................... Holding the glass envelope of the anode end and
cathode end or the screw of the anode shank.
[修改于 1 个月前 - 2019-05-19 10:45:26]
来自 交易交换
2019-5-19 00:47:32
这不是微焦点吧?不过价格不错。
这是牙科射线管吧
0.4的焦点和工业微焦点比还是太大了
k569999765(作者)
改了下,微焦点改成牙科了
2019-5-24 20:11:22
2019-5-24 20:11:22
k569999765(作者)
更新,还剩6个了,感谢各种先款的信任
2019-6-13 16:53:25
2019-6-13 16:53:25
求留一个。现在在外地,回不去。大约还得4~5天
想参与大家的讨论?现在就 登录 或者 注册
{{submitted?"":"投诉"}}
{{reason.description}}
