asp .net core 面向搜索引擎开发 新手入门 淌坑一览
张静茹2019/09/28软件综合 IP:山东
asp .net core 修改 cshtml 保存后 需要重新编译才能看到效果 浪费时间
解决方法:
nuget安装:
 Install-Package XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXntimeCompilation
  // This method gets called by the runtime. Use this method to add services to the container.
        public void ConfigureServices(IServiceCollection services)
            XXXXXXXXXXXdControllersWithViews()
                .AddRazorRuntimeCompilation();//保存cshtml 后立即生效
来自:计算机科学 / 软件综合
张静茹 作者
4年7个月前 修改于 4年7个月前 IP:山东
864388
pattern: "{controller=Home}/{action=Index}/{id?}");
此路由的含义是:
当网址为 https://localhost:44327/Home/Privacy 时
将寻找工程中继承了Controller并且类名为HomeController的类
访问他的Privacy方法 获得返回页面
public class HomeController : Controller
        public IActionResult Privacy()
            return View();
将访问工程中Views/Home/Privacy.cshtml
当网址为 https://localhost:44327 时
等效于访问https://localhost:44327/Home/Index
张静茹作者
864390
form表单submit按钮提交页面不跳转
方案一
 <html>
  <body>
  <form action="" method="post" target="nm_iframe">
      <input type="text" id="id_input_text" name="nm_input_text" >
      <input type="submit" id="id_submit" name="nm_submit" value="提交" >
  <iframe>
  </iframe></input type="submit" id="id_submit" name="nm_submit" value="提交" ></input type="text" id="id_input_text" name="nm_input_text" ></form action="" method="post" target="nm_iframe"></body>
  </html>
方案二
 <html>
  <body>
  <form action=" api user register" method="post"  id="registSubmit"  >
  </input type="submit" id="id_submit" name="nm_submit" value="提交" ></input type="text" id="id_input_text" name="nm_input_text" ></form action="></body>
  </html></pre><p><span class="cnblogs_code_copy" style><a title="复制代码" style="text-decoration-line:underline;"><span data-tag="nkcsource" data-type="picture" data-id="303973" style="width:20px;">
          <span style="padding-top:100%;">
            <img data-global-click="viewImage" data-global-long-press="downloadFile" data-global-data="%7B%22name%22%3A%221569849591412.gif%22%2C%22url%22%3A%22https%3A%2F%2Fimg.kechuang.org%3A81%2Fr%2F303973%3Fc%3Dresource%26t%3Dlg%22%7D" data-src="https://img.kechuang.org:81/r/303973?c=resource" alt="1569849591412.gif" data-type="view" dataimg="content" class="lazyload">
          </span>
        </span></a><p></p><p><span class="cnblogs_code_copy" style><a title="复制代码" style="text-decoration-line:underline;"><span data-tag="nkcsource" data-type="picture" data-id="303971" style="width:20px;">
            <img data-global-click="viewImage" data-global-long-press="downloadFile" data-global-data="%7B%22name%22%3A%221569849591413.gif%22%2C%22url%22%3A%22https%3A%2F%2Fimg.kechuang.org%3A81%2Fr%2F303971%3Fc%3Dresource%26t%3Dlg%22%7D" data-src="https://img.kechuang.org:81/r/303971?c=resource" alt="1569849591413.gif" data-type="view" dataimg="content" class="lazyload">
          </span>
        </span></a></span></p><pre data-tag="nkcsource" data-type="pre">$('#registSubmit').on('submit',      event.preventDefault() //阻止form表单默认提交
function registPost () {
   $.ajax({
       type: "post",
       url: "/api/user/register",
       data: $('#registSubmit').serialize(),
   }).success(function(message) {
     console.log(message)
   }).fail(function(err){
     console.log(err)
     或者用jquery.form.min.js提交
     $('#registSubmit').ajaxSubmit(function(message){
        console.log(message);
张静茹
进士 学者 机友 笔友
2010/12/30注册,2天0时前活动
