t20006
【Binary.dll[阉割版]】源代码放出
2009/10/06
IP:广东
RF Studio 版权所有
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Text;
using Microsoft.VisualBasic;
namespace Binary
    public class CSunsafe
        private System.Drawing.Bitmap curBitmap;
        private int[,] pic;
        private int[,,] pic1;
        public void File_Init(string sFilename)
            if (sFilename != null)
                curBitmap = (Bitmap)Image.FromFile(sFilename);
        public void BMP_Init(Bitmap BMP)
            if (BMP != null)
                curBitmap = BMP;
        public int[,,] GetRGB()
            if (curBitmap != null)
                Rectangle rect = new Rectangle(0, 0, curBitmap.Width, curBitmap.Height);
                System.Drawing.Imaging.BitmapData bmpData = curBitmap.LockBits(rect, System.Drawing.Imaging.ImageLockMode.ReadWrite, curBitmap.PixelFormat);
                pic = new int[bmpData.Width, bmpData.Height];
                pic1 = new int[3,bmpData.Width+1, bmpData.Height+1];
                unsafe
                    byte* ptr = (byte*)(bmpData.Scan0);
                    for (int i = 0; i < bmpData.Height; i++)
                        for (int j = 0; j < bmpData.Width; j++)
                            pic1[0,j,i]=ptr[2];
                            pic1[1,j,i]=ptr[1];
                            pic1[2, j, i] = ptr[0];
                            ptr += 3;
                        ptr += bmpData.Stride - bmpData.Width * 3;
                curBitmap.UnlockBits(bmpData);
                return pic1;
            else
                return null;
93°作者
17年3个月前IP:未同步
155627
【示例】
        Dim r(,,) As Integer
        Dim aa As New Binary.CSunsafe
        aa.BMP_Init(PictureBox1.Image)
        r = aa.GetRGB
93°作者
17年3个月前IP:未同步
155640
看函数名就明白了吧。。。 = =
