t56254
KC客户端另一版本公布
2013/04/21
IP:湖南
这个是我在rexsee网站在线做的一个客户端,由于还没学会编程,我暂时没办法编辑改进。
欢迎懂编程的同学可以把改进方案发上来,以便在线编辑调优。
起始原软件看帖功能很强大,视频图片都能直接看,电脑网页界面显示,可以评KCB...............只是有些Bug:签不了任务拿KCB、不能直接发贴。
起始原软件:
attachment icon com.rexsee.website.w1360836561-release.apk 515.94KB APK 37次下载
另一稍改进版软件,改进了一些网页配置,但不知效果如何:
attachment icon com.rexsee.online.kechuang_apk_V1.a0-release.apk 668.62KB APK 57次下载
在线页面:
原软件在线编辑原代码(javascript脚本,可以在浏览器上在线编辑
编辑文件【/2013-02-14/com.rexsee.website.w1360836561/assets/config.js】
var packageName="com.rexsee.website.w1360836561";
var versionCode=1;
var versionName="1.0";
var websiteName="科创";
var websiteIntro="KC-手机";
var websiteHome="http://bbs.kechuang.org/index.php";
var websiteIcon="XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX";
编辑文件【/2013-02-14/com.rexsee.website.w1360836561/assets/index.html】
<HTML>
<HEAD>
    <META http-equiv=Content-Type content=text/html charset=GB2312>
    <META http-equiv=Expires content=0>
    <META http-equiv=Cache-Control content=no-cache>
    <META http-equiv=Pragma content=no-cache>
    <SCRIPT type=text/javascript src="config.js"></SCRIPT>
    <SCRIPT type=text/javascript>
        var jsUrl = "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX";
        window.onRexseeReady = function(){
            rexseeJavaView.create('cover','LinearLayout','orientation:y;background-color:#000000;');
            rexseeJavaView.create('progress','[s:9]rogressBar','mode:circular;width:36;height:36;');
            rexseeJavaView.setChilds('cover','progress');
            rexseeJavaBar.add('cover','border-width:0;bar-position:layout;');
            rexseeBrowser.setAllowErrorDialog(false);
            rexseeAjax.submitWithCallback(jsUrl,"version="+versionCode,"GB2312");
        window.onAjaxReturned = function(ajaxUrl,response){
            response = unescape(response);
            eval(response);
            rexseeTitleBar.setStyle("visibility:visible;");
            rexseeStatusBar.setStyle("visibility:visible;");
            rexseeBrowserStyle.setStyle("background-color:transparent;");
            rexseeBrowserStyle.setStyle("background-color:#FFFFFF;");
            rexseeInception.add('init','rexseeBrowser.clearHistory();rexseeInception.remove();rexseeJavaBar.removeAll();rexseeJavaView.destroyAll();');
            rexseeBrowser.load(websiteHome);
        window.onException = function(className, message){
            //alert(className+":"+message);
            alert("嗨,看起来网络不太好,呆会儿再试吧。");
            rexseeApplication.exit();
        window.onAjaxTimeout = function(ajaxUrl,timeout){
        function copyright(){
            alert("本网站客户端由开发者自行使用Rexsee网站客户端平台创建,Rexsee网站客户端平台仅提供自动创建Android网站客户端的技术,不对作品版权、内容及质量负责,如有任何问题,请联络开发者,Rexsee不承担相关责任。");
    </SCRIPT>
<HEAD>
<BODY style="background-color:black;"></BODY>
</HTML>
+100
qg2010
2013/04/21
高质量发帖
+69
玄明
2013/04/21
辛苦了,把我脑袋搞得那么大
+25
powder
2013/04/29
helium作者
13年8个月前IP:未同步
518360
@虎哥
最高主机泡泡
2013/04/21
竟然有了@功能、、
helium作者
13年6个月前IP:未同步
539880
我公布的APP软件初步评测:【高级模式发帖回复,发出售帖回复,KCB评分,点击头像、ID、设置按钮弹出栏】
+25
powder
2013/06/24
高质量发帖
