t69108
hello world全集
2014/12/27
IP:广东
hello world是一个经典的语句。
ActionScript
trace("Hello, world!");
[1]
Ada
with TEXT_IO; procedure HELLO is begin TEXT_IO.PUT_LINE ("Hello, world!"); end HELLO;
[1]
汇编语言
x86 CPU,GNU/Linux,NASM
     section .data msg db 'Hello, world!',0xA len equ $-msg section .text global _start
_start: mov edx,len mov ecx,msg mov ebx,1 mov eax,4 int 0x80 mov ebx,0 mov eax,1 int 0x80
x86 AT&T、Gas
.data
        msg : .string "Hello, world!\n"
        len = . - msg
.text
.global _start
_start:
        movl $len, %edx
        movl $msg, %ecx
        movl $1  , %ebx
        movl $4  , %eax
        int $0x80
        movl $0  , %ebx
        movl $1  , %eax
        int $0x80
[1]
x86 CPU、Windows、MASM32
.386 .model flat,stdcall
        option   casemap:none ;========================================================== include     windows.inc include     user32.inc includelib  user32.lib
    include     kernel32.inc includelib  kernel32.lib ;========================================================== .data szCaption db "A MessageBox!", 0 szText db "Hello, world!", 0 ;========================================================== .code start: invoke   MessageBox, NULL, addr szText, addr szCaption, MB_OK
    invoke   ExitProcess, NULL ;========================================================== end start
8086操作系统(nasm)
[BITS 16] org 0x7c00 mov ax,cs mov ds,ax mov es,ax call DispStr jmp $;End Hear DispStr: mov ax, BootMessage mov bp, ax mov cx, 16;How long is the String mov ax, 0x1301 mov bx, 0x000c mov dl, 0 int 0x10 ret BootMessage: db "Hello, world!" times 510-($-$$) db 0x0 dw 0xaa55; Bootable Mark
ASP
<% Response.Write("Hello, world!") %>
[1]
或者简单地写成:
<%= "Hello, world!" %>
AutoIt
MsgBox(1,'','Hello, world!')
AWK
BEGIN { print "Hello, world!" }
[1]
Bash (or sh)
echo 'Hello, world!'
或者:
printf 'Hello, world!\n'
[1]
BASIC
传统版 BASIC(例如 GWBASIC):
10 PRINT "Hello, world!" 20 END
或在提示符输入:
? "Hello, world!"
现代版 BASIC(例如 Quick BASIC):
以下的语句,在 Quick BASIC 中同样有效:
? "Hello, world!"
BCPL
GET "LIBHDR"
LET START () BE
    WRITES ("Hello, world!*N")
Brainfuck
BlitzBasic
Print "Hello, world!" WaitKey
BOO
C
#include <stdio.h> int main(void) { printf("Hello, world!\n"); return 0; }
或者:
#include <stdio.h> int main(void) { puts("Hello, world!"); return 0; }
[1]
C++
#include <iostream> int main() { std::cout << "Hello, world!" << std::endl; return 0; }
或者:
#include <iostream> using namespace std; int main() { cout << "Hello, world!" << endl; return 0; }
[1]
C++/CLI
int main() { System::Control::WriteLine("Hello, world!"); }
C# (C Sharp)
class HelloWorldApp { static void Main(string[] args) { System.Console.WriteLine("Hello, world!"); } }
[1]
或者(仅用于Microsoft Windows)
class HelloWorldApp { [DllImport("user32.dll")] static extern MessageBox(string title, string message); public static void Main() { MessageBox(null, "Hello, world!"); } }
或者(使用附加的Windows Forms)
using System.Windows.Forms; class HelloWorldApp { public static void Main() { MessageBox.Show("Hello, world!"); } }
COBOL
IDENTIFICATION DIVISION. PROGRAM-ID. HELLO-WORLD. ENVIRONMENT DIVISION. DATA DIVISION. PROCEDURE DIVISION. DISPLAY "Hello, world!". STOP RUN.
[1]
Common Lisp
;直接输出 "Hello world!" ;或者 (format t "Hello world!~%")
[1]
DOS批处理
@echo Hello, world!
对于MS-DOS 3.0或更低版本:
echo off
cls echo Hello, world!
Linux Shell
echo Hello, world!
[1]
Eiffel
class HELLO_WORLD creation make feature make is local io:BASIC_IO do !!io
        io.put_string("%N Hello, world!") end -- make end -- class HELLO_WORLD
[1]
Erlang
    -module(hello).
    -export([hello_world/0]).
    hello_world() -> io:fwrite("Hello, World!\n").
Flowgorithm[编辑]
主条目:Flowgorithm (programming language)
Forth
." Hello, world!" CR
[1]
Fortran
    WRITE(*,*) 'Hello, world!' STOP END
[1]
HTML
Hello World <html> <head> <title> Hello World </title> </head> <body> Hello World </body> </html>
[1]
HQ9+[
H
INTERCAL
PLEASE DO ,1 <- #13 DO ,1 SUB #1 <- #238 DO ,1 SUB #2 <- #112 DO ,1 SUB #3 <- #112 DO ,1 SUB #4 <- #0 DO ,1 SUB #5 <- #64 DO ,1 SUB #6 <- #238 DO ,1 SUB #7 <- #26 DO ,1 SUB #8 <- #248 DO ,1 SUB #9 <- #168 DO ,1 SUB #10 <- #24 DO ,1 SUB #11 <- #16 DO ,1 SUB #12 <- #158 DO ,1 SUB #13 <- #52 PLEASE READ OUT ,1 PLEASE GIVE UP
[1]
Java
public class Hello { public static void main(String[] args) { System.out.println("Hello, world!"); } }
or in tinystruct2.0:
package tinystruct.examples; import org.tinystruct.AbstractApplication; import org.tinystruct.Application; import org.tinystruct.ApplicationException; import org.tinystruct.system.ApplicationManager; public class hello extends AbstractApplication { @Override public void init() { // TODO Auto-generated method stub this.setAction("say", "say"); } @Override public String version() { // TODO Auto-generated method stub return null; } public String say(String words){ System.out.println(words); return words; } /**
* @param args
* @throws ApplicationException
public static void main(String[] args) throws ApplicationException { // TODO Auto-generated method stub // Praise to the Lord! ApplicationManager.install(new hello()); // to print 'Hello World' ApplicationManager.call("say/Hello World", null); // Hello World // or... Application app=ApplicationManager.get( hello.class.getName()); app.invoke("say", new Object[]{"
Hello, World!
Hello, World!
Bye!
Bye!
// or... // http://localhost:8080/?q=say/Hello World // XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX } }
JSP
<% out.print("Hello, world!"); %>
[1]
或者简单地写成:
<%="Hello, world!"%>
Lisp
;直接输出 "hello, world" ;或者 (format t "hello, world~%")
Lua
[1]
Malbolge
('&%:9]!~}|z2Vxwv-,POqponl$Hjig%eB@@>}=<M:9wv6WsU2T|nm-,jcL(I&%$#"
`CB]V?Tx<uVtT`Rpo3NlF.Jh++FdbCBA@?]!~|4XzyTT43Qsqq(Lnmkj"Fhg${z@>
Mathematica
Hello[] := Print["Hello World!"]
Hello[]
[1]
Metapost[
beginfig(1);
draw (0,0)--(0,10);
draw (0,5)--(5,5);
draw (5,0)--(5,10);
draw (12,0)--(7,0)--(7,10)--(12,10);
draw (12,5)--(7,5);
draw (14,10)--(14,0)--(19,0);
draw (21,10)--(21,0)--(26,0);
draw (28,5)...(30.5,0)...(33,5)...(30.5,10)...cycle;
draw (38,10)--(39.25,0)--(40.5,10)--(41.75,0)--(43,10);
draw (45,5)...(47.5,0)...(50,5)...(47.5,10)...cycle;
draw (52,0)--(52,10);
draw (52,10)..(57,4)..(52,6.5);
draw (52,5)--(57,0);
draw (61,10)--(61,0)--(66,0);
draw (68,10)--(68,0)..(73,5)..cycle;
endfig;
end
MIXAL
TERM EQU 19 the MIX console device number
        ORIG   1000        start address
START OUT MSG(TERM) output data at address MSG
        HLT                halt execution
MSG ALF "MIXAL"
        ALF    " HELL"
        ALF    "O WOR"
        ALF    "LD   "
        END    START       end of the program
Nuva
<..直接输出..>
Hello, world!
<..或者..>
  // 不带换行
  ?  "Hello, world!"
  // 或者
  // 带换行
  ?? 'Hello, world!'
Objective-C
#import <Foundation/Foundation.h> int main(int argc, const char * argv[]) { @autoreleasepool { NSLog(@"Hello, World!"); } return 0; }
[1]
OCaml
let main () = print_endline "Hello world!";;
Pascal
program Hello;{此行可以省略} begin writeln('Hello, world!'); end.
[1]
Perl
#!/usr/bin/env perl print "Hello, world!\n";
Perl 5.10(含)以后版本:
#!/usr/bin/env perl use 5.010; say "Hello, world!";
[1]
PHP
<?php echo 'Hello, world!';//通常使用這個,比 print 少一個字元 print 'Hello, world!'; ?>
或者
<?= "Hello World!"?>
Pike
#!/usr/local/bin/pike
int main()
    write("Hello, world!\n");
    return 0;
PL/I
Test: procedure options(main);
    declare My_String char(20) varying initialize('Hello, world!');
    put skip list(My_String);
end Test;
Prolog
goal write("hello,world!").
Python
适用于Python 2:
#!/usr/bin/env python print "Hello, world!"
适用于Python 3:
#!/usr/bin/env python print("Hello, world!")
[1]
REXX
say "Hello, world!"
Ruby
#!/usr/bin/ruby puts "Hello, world!"
[1]
Sbyke Laborana
INIT min:1001
Om:"Hello, world!"
Scheme
(display "Hello, world!") (newline)
Scratch
主条目:Scratch (编程语言)
sed
(需要至少一行输入)
sed -ne '1s/.*/Hello, world!/p'
Seed7
$ include "seed7_05.s7i";
  const proc: main is func
    begin
      writeln("Hello, world!");
    end func;
Smalltalk
Transcript show: 'Hello, world!'
Small Basic
TextWindow.WriteLine("Hello, world!")
SNOBOL
    OUTPUT = "Hello, world!"
END
SQL
第一种
CREATE TABLE MESSAGE (TEXT CHAR(15)); INSERT INTO MESSAGE (TEXT) VALUES ('Hello, world!'); SELECT TEXT FROM MESSAGE; DROP TABLE MESSAGE;
第二种
SELECT 'hello, world';
第三种
print 'hello,world!'
Swift
println("Hello, World!")
Tcl
#!/usr/local/bin/tcl
TScript
? "Hello, world!"
Turing
put "Hello, world!"
UNIX-style shell
程序中的/bin/sh可改为您使用的shell
#!/bin/sh echo 'Hello, world!'
bc
#!/usr/bin/bc -q
print "Hello World"
quit
dc
#!/usr/bin/env dc
[Hello World]p
Wiki
<includeonly>Hello, World!</includeonly>
GUI
Delphi
program HelloWorld; uses Dialogs; begin ShowMessage('Hello, World!'); end.
Nuva
  System.Ui.ShowMessage('Nuva', 'Hello, world!', ['OK'])
Visual Basic
MsgBox "Hello, world!" '或者 Print "Hello, world!"
Visual FoxPro
? "Hello, world!"
X11
用一个程序
xmessage 'Hello, world!'
使用Qt
#include <QApplication> #include <QLabel> int main(int argc, char *argv[]) { QApplication app(argc, argv); QLabel label("Hello, world!"); label.show(); return app.exec(); }
C 和 GTK+
#include <gtk/gtk.h> int main(int argc, char * args[]) { GtkWidget * win, * label; gtk_init(& argc, & args); label = gtk_label_new("Hello, world!"); win = gtk_window_new(GTK_WINDOW_TOPLEVEL); gtk_container_add(GTK_CONTAINER(win), label); gtk_widget_show_all(); gtk_main(); return 0; }
用C++和gtkmm 2
#include <iostream> #include <gtkmm/main.h> #include <gtkmm/button.h> #include <gtkmm/window.h> using namespace std; class HelloWorld : public Gtk::Window { public: HelloWorld(); virtual ~HelloWorld(); protected: Gtk::Button m_button; virtual void on_button_clicked(); }; HelloWorld::HelloWorld() : m_button("Hello, world!") { set_border_width(10); m_button.signal_clicked().connect(SigC::slot(*this, &HelloWorld::on_button_clicked)); add(m_button); m_button.show(); } HelloWorld::~HelloWorld() {} void HelloWorld::on_button_clicked() { cout << "Hello, world!" << endl; } int main(int argc, char *argv[]) { Gtk::Main kit(argc, argv); HelloWorld helloworld; Gtk::Main::run(helloworld); }
Java
import java.awt.*; import java.awt.event.*; public class HelloFrame extends Frame { HelloFrame(String title) { super(title); } public void paint(Graphics g) { super.paint(g); java.awt.Insets ins = this.getInsets(); g.drawString("Hello, World!", ins.left + 25, ins.top + 25); } public static void main(String args []) { HelloFrame fr = new HelloFrame("Hello"); fr.addWindowListener( new WindowAdapter() { public void windowClosing(WindowEvent e) { System.exit( 0 ); } } ); fr.setResizable(true); fr.setSize(500, 100); fr.setVisible(true); } }
Java Applet
Java Applet用于HTML文件。
HTML代码:
<html> <head> <title>Hello World</title> </head> <body> HelloWorld Program says: <applet code="HelloWorld.class" width="600" height="100"> </applet> </body> </html>
Java代码:
import java.applet.*; import java.awt.*; public class HelloWorld extends Applet { public void paint(Graphics g) { g.drawString("Hello, world!", 100, 50); } }
JavaScript
JavaScript是一种脚本语言。最广泛用于HTML文件中,也可以用在其它宿主环境下,比如Microsoft? Windows? 脚本宿主(WSH)和一些web服务环境。
用于HTML中:
alert("Hello, World!"); //或者 document.write("Hello, World!");
用于WSH中:
WScript.Echo("Hello, World!");
PostScript
PostScript是一种专门用来创建图像的语言,常用于打印机。
/font /Courier findfont 24 scalefont
font setfont
100 100 moveto
(Hello World!) show
showpage
XAML
<Page xmlns="XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX" xmlns:x="XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX" x:Class="XAMLSample.Page1" > <Button Click="HelloWorld" Name="Button1">Click Here</Button> </Page>
接着使用 C# 建置
using System; using System.Windows; using System.Windows.Controls; namespace XAMLSample { public partial class Page1 : Page { void HelloWorld(object sender, RoutedEventArgs e) { MessageBox.Show("Hello, world!"); } } }
易语言
.版本 2
.程序集 窗口程序集1
.子程序 __启动窗口_创建完毕
信息框 (“Hello, World!”, 0, )
12年0个月前IP:四川
737079
这是需要多大的毅力这么无聊==
12年0个月前IP:北京
737131
表示看到c 和c艹很亲切啊
12年0个月前IP:广东
737193
看到JAVA很亲切!
12年0个月前IP:广东
737204
引用 回忆:
看到JAVA很亲切!
java不带换行的吗,看的好晕啊
