C#中重定向stdout和stderr到同一个文件(用WinAPI实现)
2016/07/04
IP:四川
C#自带的Process类只能重定向到管道,并且stdout和stderr只能分别接收,无法达到命令提示符的效果。这里实现了一个Cmd类,其中Cmd.RunCmd函数可以运行命令同时返回所有输出。
Cmd.cs:
using System;
using System.Runtime.InteropServices;
using System.IO;
using System.Text;
using System.ComponentModel;
using System.Diagnostics;
/// <summary>
/// Summary description for Class1
/// </summary>
public class Cmd
	public Cmd()
		// TODO: Add constructor logic here
    [StructLayout(LayoutKind.Sequential)]
    private class SECURITY_ATTRIBUTES
        public int nLength;
        public IntPtr lpSecurityDescriptor;
        public bool bInheritHandle;
    [Flags]
    private enum STARTF : uint
        STARTF_USESHOWWINDOW = 0x00000001,
        STARTF_USESIZE = 0x00000002,
        STARTF_USEPOSITION = 0x00000004,
        STARTF_USECOUNTCHARS = 0x00000008,
        STARTF_USEFILLATTRIBUTE = 0x00000010,
        STARTF_RUNFULLSCREEN = 0x00000020,  // ignored for non-x86 platforms
        STARTF_FORCEONFEEDBACK = 0x00000040,
        STARTF_FORCEOFFFEEDBACK = 0x00000080,
        STARTF_USESTDHANDLES = 0x00000100,
    private const Int16 SW_HIDE = 0;
    [StructLayout(LayoutKind.Sequential, CharSet = CharSet.Auto)]
    private class STARTUPINFO
        public Int32 cb;
        public string lpReserved;
        public string lpDesktop;
        public string lpTitle;
        public Int32 dwX;
        public Int32 dwY;
        public Int32 dwXSize;
        public Int32 dwYSize;
        public Int32 dwXCountChars;
        public Int32 dwYCountChars;
        public Int32 dwFillAttribute;
        public STARTF dwFlags;
        public Int16 wShowWindow;
        public Int16 cbReserved2;
        public IntPtr lpReserved2;
        public IntPtr hStdInput;
        public IntPtr hStdOutput;
        public IntPtr hStdError;
    private class PROCESS_INFORMATION
        public IntPtr hProcess;
        public IntPtr hThread;
        public int dwProcessId;
        public int dwThreadId;
    private const uint GENERIC_WRITE = 0x40000000;
    private const uint FILE_SHARE_READ = 1;
    private const uint OPEN_EXISTING = 3;
    private const uint FILE_ATTRIBUTE_NORMAL = 0x80;
    [DllImport("kernel32.dll", CharSet = CharSet.Auto, SetLastError = true)]
    private static extern IntPtr CreateFile(
         string filename,
         uint access,
         uint share,
         [In] SECURITY_ATTRIBUTES securityAttributes,
         uint creationDisposition,
         uint flagsAndAttributes,
         IntPtr templateFile);
    [DllImport("kernel32.dll", SetLastError = true, CharSet = CharSet.Auto)]
    private static extern bool CreateProcess(
       string lpApplicationName,
       string lpCommandLine,
       [In] SECURITY_ATTRIBUTES lpProcessAttributes,
       [In] SECURITY_ATTRIBUTES lpThreadAttributes,
       bool bInheritHandles,
       uint dwCreationFlags,
       IntPtr lpEnvironment,
       string lpCurrentDirectory,
       [In] STARTUPINFO lpStartupInfo,
       [Out] PROCESS_INFORMATION lpProcessInformation);
    private const uint INFINITE = 0xFFFFFFFF;
    private const uint WAIT_FAILED = 0xFFFFFFFF;
    [DllImport("kernel32.dll", SetLastError = true)]
    private static extern uint WaitForSingleObject(IntPtr hHandle, uint dwMilliseconds);
    [DllImport("kernel32.dll", SetLastError = false)]
    private static extern IntPtr GetCurrentProcess();
    private const uint DUPLICATE_SAME_ACCESS = 2;
    private static extern bool DuplicateHandle(
        IntPtr proc1, IntPtr handle1,
        IntPtr proc2, out IntPtr handle2,
        uint access, bool inheritable, uint flags);
    private static extern bool CloseHandle(IntPtr handle);
    public static string RunCmd(string cmd)
        string tmpname = Path.GetTempFileName();
        // WIN32 section starts
        SECURITY_ATTRIBUTES sa = new SECURITY_ATTRIBUTES();
        sa.nLength = Marshal.SizeOf(sa);
        sa.bInheritHandle = true;
        sa.lpSecurityDescriptor = IntPtr.Zero;
        IntPtr outhandle = CreateFile(tmpname, GENERIC_WRITE, FILE_SHARE_READ, sa, OPEN_EXISTING, FILE_ATTRIBUTE_NORMAL, IntPtr.Zero);
        if (outhandle == new IntPtr(-1))
            throw new Win32Exception(Marshal.GetLastWin32Error());
        IntPtr outhandle2 = new IntPtr(-1);
        if (!DuplicateHandle(GetCurrentProcess(), outhandle, GetCurrentProcess(), out outhandle2, 0, true, DUPLICATE_SAME_ACCESS))
            CloseHandle(outhandle);
        STARTUPINFO si = new STARTUPINFO();
        si.cb = Marshal.SizeOf(si);
        si.dwFlags = STARTF.STARTF_USESTDHANDLES | STARTF.STARTF_USESHOWWINDOW;
        si.hStdInput = new IntPtr(-1);
        si.hStdOutput = outhandle;
        si.hStdError = outhandle2;
        si.wShowWindow = SW_HIDE;
        PROCESS_INFORMATION pi = new PROCESS_INFORMATION();
        if (!CreateProcess(null, cmd, null, null, true, 0, IntPtr.Zero, null, si, pi))
            CloseHandle(outhandle2);
        CloseHandle(pi.hThread);
        if (WaitForSingleObject(pi.hProcess, INFINITE) == WAIT_FAILED)
            CloseHandle(pi.hProcess);
        // WIN32 section ends
        string outstr = File.ReadAllText(tmpname, Encoding.Default);
        File.Delete(tmpname);
        return outstr;
[ 修改于10年5个月前 - 2016/07/04 17:17:08 ]
acmilan作者
10年5个月前修改于 10年5个月前IP:四川
822262
RunCmd过程分解:
  1. 用Path.GetTempFileName()创建一个临时文件
  2. 用CreateFile打开它,其中第四个参数中SECURITY_ATTRIBUTES结构体中的bInheritHandle设置为true,表示句柄可继承
  3. 用DuplicateHandle复制一份句柄
  4. 设置STARTUPINFO。开启STARTF_USESTDHANDLES,将stdin设置为空文件句柄,将stdout和stderr分别设置为这两个句柄;开启STARTF_USESHOWWINDOW,将wShowWindow设置为SW_HIDE,隐藏窗口
  5. 用CreateProcess创建进程,第五个参数设置为true,表示继承句柄,最后一个参数返回PROCESS_INFORMATION结构体,包含有进程和主线程句柄
  6. 用CloseHandle关闭用不到的句柄
  7. 用WaitForSingleObject等待进程退出
  8. 用CloseHandle关闭进程句柄
  9. 用File.ReadAllText读取临时文件
  10. 用File.Delete删除临时文件
  11. 返回读取到的字符串
acmilan作者
822269
C++/CLI版本(使用时需要#include "Cmd.h")
Cmd.cpp:
#include "StdAfx.h"
#include "Cmd.h"
Cmd.h:
#pragma once
#include <vcclr.h>
#include <windows.h>
#pragma comment(lib, "kernel32.lib")
using namespace System;
using namespace System::IO;
using namespace System::Text;
using namespace System::Runtime::InteropServices;
using namespace System::ComponentModel;
public ref class Cmd
public:
	Cmd()
	static String^ RunCmd(String^ cmd)
		String ^tmpname = Path::GetTempFileName();
		pin_ptr<const wchar_t> p_tmpname = PtrToStringChars(tmpname);
		SECURITY_ATTRIBUTES sa = { sizeof sa };
		sa.bInheritHandle = TRUE;
		HANDLE outhandle = CreateFile(p_tmpname, GENERIC_WRITE, FILE_SHARE_READ, &sa, OPEN_EXISTING, FILE_ATTRIBUTE_NORMAL, NULL);
		if (outhandle == INVALID_HANDLE_VALUE)
			throw gcnew Win32Exception(GetLastError());
		HANDLE outhandle2 = INVALID_HANDLE_VALUE;
		if (!DuplicateHandle(GetCurrentProcess(), outhandle, GetCurrentProcess(), &outhandle2, 0, TRUE, DUPLICATE_SAME_ACCESS))
			DWORD errcode = GetLastError();
			throw gcnew Win32Exception(errcode);
		WCHAR *p_cmd = (WCHAR *)Marshal::StringToHGlobalUni(cmd).ToPointer();
		STARTUPINFO si = { sizeof si };
		si.dwFlags = STARTF_USESTDHANDLES | STARTF_USESHOWWINDOW;
		si.hStdInput = INVALID_HANDLE_VALUE;
		PROCESS_INFORMATION pi = { 0 };
		if (!CreateProcess(NULL, p_cmd, NULL, NULL, TRUE, 0, NULL, NULL, &si, &pi))
			Marshal::FreeHGlobal(IntPtr(p_cmd));
			throw gcnew Win32Exception();
		String ^outstr = File::ReadAllText(tmpname, Encoding::Default);
		File::Delete(tmpname);
		return outstr;
</const></windows.h></vcclr.h>
acmilan作者
822450
C++/CLI第二版——重定向了stdin,并可指定编码格式
// CmdHelper.h
#pragma once
#include <vcclr.h>
namespace CmdHelper {
	public:
		Cmd()
		static String^ RunCmd(String^ cmd, String^ instr, Encoding^ enc)
			String ^tmpin = Path::GetTempFileName();
			pin_ptr<const wchar_t> p_tmpin = PtrToStringChars(tmpin);
			array<unsigned char> ^inbytes = enc->GetBytes(instr);
			File::WriteAllBytes(tmpin, inbytes);
			HANDLE inhandle = CreateFile(p_tmpin, GENERIC_READ, FILE_SHARE_READ, &sa, OPEN_EXISTING, FILE_ATTRIBUTE_NORMAL, NULL);
			if (inhandle == INVALID_HANDLE_VALUE)
				CloseHandle(inhandle);
			si.hStdInput = inhandle;
			array<unsigned char> ^outbytes = File::ReadAllBytes(tmpname);
			String ^outstr = enc->GetString(outbytes);
			File::Delete(tmpin);
			return outstr;
</unsigned></const></unsigned></const></windows.h></vcclr.h>
