对,不是C++/CLI。用的是.NET的非托管接口和反射特性。
优点是与编译器无关,缺点是比较麻烦,需要用反射进行调用。
<configuration>
<startup uselegacyv2runtimeactivationpolicy="true">
<supportedruntime version="v4.0.30319">
<supportedruntime version="v2.0.50727">
</supportedruntime></supportedruntime></startup>
</configuration>
// bindcoree.cpp : 定义控制台应用程序的入口点。
#include "stdafx.h"
#pragma warning(disable: 4996)
#include <windows.h>
#include <shlwapi.h>
#include <mscoree.h>
#import <mscorlib.tlb> rename("ReportEvent", "ReportEvent_mscor")
#pragma comment(lib, "shlwapi.lib")
#pragma comment(lib, "mscoree.lib")
using namespace mscorlib;
int _tmain(int argc, _TCHAR* argv[])
// 初始化COM线程模型
HRESULT hr = CoInitialize(NULL); // 重要!运行WinForms和WPF必需
// 构造app.config路径
WCHAR path[MAX_PATH];
GetModuleFileName(NULL, path, MAX_PATH);
PathRemoveFileSpec(path);
PathAppend(path, L"app.config");
// 初始化.NET运行库(没找到app.config按.NET2.0/3.x加载)
ICorRuntimeHost *crh = NULL;
hr = CorBindToCurrentRuntime(path, CLSID_CorRuntimeHost, IID_ICorRuntimeHost, (void**)&crh);
crh->Start();
// 获取当前程序域
IUnknownPtr domainunk;
crh->CurrentDomain(&domainunk);
_AppDomainPtr domain;
domain = domainunk;
// 加载WPF运行库程序集(只加载需要的就行了)
// 注册程序集一般要强名称才能加载,可以去以下两个地方找到相关信息:
// C:\Windows\assembly - .NET 2.0/3.x
// C:\Windows\Microsoft.NET\assembly - .NET 4.x
_AssemblyPtr prefx = domain->Load_2(_bstr_t(L"PresentationFramework, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"));
//_AssemblyPtr precore = domain->Load_2(_bstr_t(L"PresentationCore, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"));
//_AssemblyPtr winbase = domain->Load_2(_bstr_t(L"WindowsBase, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"));
// 获取Window类型信息
_TypePtr twindow = prefx->GetType_2(_bstr_t(L"System.Windows.Window"));
// 创建Window类型实例
variant_t objwindow = prefx->CreateInstance(_bstr_t(L"System.Windows.Window"));
// 调用ShowDialog方法
twindow->InvokeMember_3(_bstr_t(L"ShowDialog"),
(BindingFlags)(BindingFlags_InvokeMethod|BindingFlags_Instance|BindingFlags_Public),
NULL, objwindow, NULL);
// 下面是调用没有强名称的一般程序集的做法
//_AssemblyPtr assembly = domain->Load_2(_bstr_t(L"ClassLibrary"));
//_TypePtr t = assembly->GetType_2(_bstr_t(L"ClassLibrary.Class1"));
//variant_t nullobj;
//t->InvokeMember_3(_bstr_t(L"WriteVersion"),
// (BindingFlags)(BindingFlags_InvokeMethod|BindingFlags_Static|BindingFlags_Public),
// NULL, nullobj, NULL);
// 卸载ICorRuntimeHost(只有它不是智能指针)
crh->Release();
crh = NULL;
// 卸载COM
CoUninitialize();
return 0;
</mscorlib.tlb></mscoree.h></shlwapi.h></windows.h>
