从零开始组装Linux(Linux From Scratch)
acmilan2016/08/17软件综合 IP:四川
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX/
Welcome to Linux From Scratch!
Linux From Scratch (LFS) is a project that provides you with step-by-step instructions for building your own custom Linux system, entirely from source code.
Currently, the Linux From Scratch organization consists of the following subprojects:
LFS :: Linux From Scratch is the main book, the base from which all other projects are derived.
BLFS :: Beyond Linux From Scratch helps you extend your finished LFS installation into a more customized and usable system.
ALFS :: Automated Linux From Scratch provides tools for automating and managing LFS and BLFS builds.
CLFS :: Cross Linux From Scratch provides the means to cross-compile an LFS system on many types of systems.
HLFS :: Hardened Linux From Scratch focuses on building an LFS system with heightened security.
Hints :: The Hints project is a collection of documents that explain how to enhance your LFS system in ways that are not included in the LFS or BLFS books.
LiveCD :: The LiveCD project provides a CD that is useful as an LFS build host or as a general rescue CD.
Patches :: The Patches project serves as a central repository for all patches useful to an LFS use
[修改于 7年10个月前 - 2016/08/17 15:03:04]
来自:计算机科学 / 软件综合
7年10个月前 IP:浙江
824586
这个装起来累,用起来更累。
acmilan作者
7年10个月前 IP:四川
824587
引用 .........:
这个装起来累,用起来更累。
所以这东西了解下就好,有需要的时候再去组装→_→
acmilan作者
7年10个月前 修改于 7年10个月前 IP:四川
824590
其实个人认为,这里面最有学习价值的是CLFS,即从零开始交叉编译Linux,这个自由度最大,也最麻烦,学到的东西也最多。不过实际上,所有的版本都很麻烦,也很浪费时间。比如LFS要编译3遍GCC,两遍GLIBC,而CLFS要编译4遍GCC,两遍GLIBC。
hackerboygn
7年10个月前 IP:湖北
824598
没有做过一次完整LFS的,应该不算懂Linux。
这个项目真正目的,是让你理解和看到,如何从一堆源代码变成真正的操作系统,过程有点像神话传说,上帝-》微生物-》低等动物-》高等动物-》智慧生物。要是把它当发行版用,估计没几个人能接受掌握得了。
暗夜幽灵
5年4个月前 IP:北京
854101
引用acmilan发表于2楼的内容
引用 .........:这个装起来累,用起来更累。所以这东西了解下就好,有需要的时候再去组装→_→
你可以试试gentoo
acmilan
进士 学者 笔友
2009/05/30注册,5年4个月前活动
