煎饼:vr头追难题解决
2017/01/09
IP:上海
摄像头是小蚁的(拆开来看到Xbee,紫蜂通讯。直接买的小米VR,不准备做FPV。两块arduino nano,两块蓝牙主从一体模块,GY-85九轴传感器,舵机云台。硬件差不多布线完成了,软件方面参考XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
发现他arduino语句有问题
头追程序
// Written by Dennis Frie - 2012
// Contact: Dennis.frie@gmail.com
// Version 0.08
// Discussion:
// XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Channel mapping/config for PPM out:
1 = PPM CHANNEL 1
2 = PPM CHANNEL 2
3 = PPM CHANNEL 3
4 = PPM CHANNEL 4
5 = PPM CHANNEL 5
6 = PPM CHANNEL 6
7 = PPM CHANNEL 7
8 = PPM CHANNEL 8
9 = PPM CHANNEL 9
10 = PPM CHANNEL 10
11 = PPM CHANNEL 11
12 = PPM CHANNEL 12
20 = ANALOG INPUT 0
21 = ANALOG INPUT 1
22 = ANALOG INPUT 2
23 = ANALOG INPUT 3
24 = ANALOG INPUT 4
25 = ANALOG INPUT 5
26 = ANALOG INPUT 6
27 = ANALOG INPUT 7
20 = DIGITAL INPUT 0
21 = DIGITAL INPUT 1
22 = DIGITAL INPUT 2
23 = DIGITAL INPUT 3
24 = DIGITAL INPUT 4
25 = DIGITAL INPUT 5
26 = DIGITAL INPUT 6
27 = DIGITAL INPUT 7
30 = HT pan
31 = HT tilt
32 = HT roll
Mapping example:
$123456789111CH
#include <Wire.h>
#include "config.h"
#include "functions.h"
#include "sensors.h"
#include "ServoSupport.h"
#include <EEPROM.h>
extern unsigned char channel_mapping[];
extern unsigned char PpmIn_PpmOut[13];
extern char read_sensors;
extern long channel_value[];
extern float gyroOff[];
int counter =0;      // Delay for serial-output.
char printPlot = 0;  // print plot for GUI?
// External variables (from sensors.h):
extern float tiltBeta;
extern float panBeta;
extern float gyroWeight;
extern float GyroWeightPan;
extern int maxPulse;
extern int servoPanCenter;
extern int servoTiltCenter;
extern int servoRollCenter;
extern int panMaxPulse;
extern int panMinPulse;
extern int tiltMaxPulse;
extern int tiltMinPulse;
extern int rollMaxPulse;
extern int rollMinPulse;
extern float panFactor;
extern float tiltFactor;
extern float rollFactor;
extern char tiltInverse;
extern char rollInverse;
extern char panInverse;
extern float magOffset[];
extern int accOffset[];
extern unsigned char htChannels[];
extern char resetValues;
void setup() {
  Serial.begin(SERIAL_BAUD);
  pinMode(7,OUTPUT);
  pinMode(9,OUTPUT);
  digitalWrite(2,HIGH);
  digitalWrite(3,HIGH);
  pinMode(0,INPUT);
  pinMode(1,INPUT);
  pinMode(2,INPUT);
  pinMode(3,INPUT);
  pinMode(6,INPUT);
  pinMode(7,INPUT);
  pinMode(8,INPUT);
  //Set button pin to input:
  pinMode(BUTTON_INPUT,INPUT);
  //Set internal pull-up resistor.
  digitalWrite(BUTTON_INPUT,HIGH);
  digitalWrite(0,LOW); // pull-down resistor
  digitalWrite(1,LOW);
  Wire.begin();                  // Start I2C
// If the device have just been programmed, write initial config/values to EEPROM:
  if (EEPROM.read(0) != 8)  {
//  #if (DEBUG)
     Serial.println("New board - saving default values!");
//  #endif
      init_sensors();
   #if (ALWAYS_CAL_GYRO ==0)
     setSensorOffset();
   #endif
    save Settings();
    saveMagData();
    saveAccData();
    EEPROM.write(0,8);
  getSettings();                 // Get settings saved in EEPROM
  init_sensors();                // Initialise I2C sensors
  calMag();
  resetCenter();
  init_timer_interrupt();        // Start timer interrupt (for sensors)
  ServoSupport::Init();
  ServoSupport::SetAng(1,9,90);
  ServoSupport::SetAng(2,10,90);
  ServoSupport::SetAng(3,8,90);
  ServoSupport::Start();
char serial_data[101];           // Array for serial-data
unsigned char serial_index =0;   // How many bytes have been received?
char string_started = 0;         // Only saves data if string starts with right byte
char outputMag = 0;
char outputAcc = 0;
void loop() {
  // Check button
  if (digitalRead(BUTTON_INPUT)==0) {
   resetValues = 1;
// All this is used for communication with GUI
  if (Serial.available()) {
    if (string_started == 1) {
         // Read incoming byte
           serial_data[serial_index++] = Serial.read();
           // If string ends with 'CH" it's channel configuration, that have been received.
           // String must always be 12 chars/bytes and ending with CH to be valid.
           if (serial_data[serial_index-2] == 'C' && serial_data[serial_index-1] == 'H' && serial_index == 14) {
              // To keep it simple, we will not let the channels be 0-initialised, but start from 1 to match actual channels.
               for (unsigned char i=0; i<13; i++) {
                  channel_mapping[i+1] = serial_data[i]-48;
                  // Update the dedicated PPM-in -> PPM-out array for faster performance.
                  if (serial_data[i]-48 < 14) {
//                    PpmIn_PpmOut[i+1] =  serial_data[i]-48;
                    PpmIn_PpmOut[serial_data[i]-48] =i+1;
               Serial.println("Channel mapping received");
               // Reset serial_index and serial_started
               serial_index=0;
               string_started = 0;
          if (serial_data[serial_index-2] == 'H' && serial_data[serial_index-1] == 'E') {
           // We need 8 parameters:
           // LP_tilt
           // LP_pan
           // Gyro_weight_tilt
           // Gyro_weight_pan
           // servo_max
           // servo_min
           // tilt_servo_gain
           // pan_servo_gain
           Serial.println("HT config received:");
           for (unsigned char k = 0; k< 10; k++) {
            valuesReceived[k] =0;
           int valuesReceived[20] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
           int comma_index =0;
           for (unsigned char k = 0; k < serial_index-2; k++) {
               // Looking for comma
               if (serial_data[k] == 44) {
                 comma_index++;
             else {
             valuesReceived[comma_index] = valuesReceived[comma_index]*10 + (serial_data[k]-48);
             // Mainly for debug:
             #if (DEBUG)
             Serial.print(serial_data[k]);
             #endif
          #if (DEBUG)
           Serial.println();
            for (unsigned char k = 0; k < comma_index+1; k++) {
               Serial.print(valuesReceived[k]);
               Serial.print(",");
           Serial.println();
          #endif
         tiltBeta        = (float)valuesReceived[0] / 100;
         panBeta         = (float)valuesReceived[1] / 100;
         gyroWeight      = (float)valuesReceived[2] / 100;
         GyroWeightPan   = (float)valuesReceived[3] / 100;
         tiltFactor     = (float)valuesReceived[4] / 10;
         panFactor     = (float)valuesReceived[5] / 10;
         rollFactor     = (float)valuesReceived[6] / 10;
        tiltInverse = 1;
        rollInverse = 1;
        panInverse = 1;
         if (valuesReceived[7] / 100 == 1) {
             panInverse = -1;
             valuesReceived[7]-=100;
         if (valuesReceived[7] / 10 == 1) {
          rollInverse = -1;
          valuesReceived[7]-=10;
         if (valuesReceived[7] / 1 == 1) {
           tiltInverse = -1;
               serial_index=0;
               string_started = 0;
         servoPanCenter = valuesReceived[8];
         panMinPulse = valuesReceived[9];
         panMaxPulse = valuesReceived[10];
         servoTiltCenter = valuesReceived[11];
         tiltMinPulse = valuesReceived[12];
         tiltMaxPulse = valuesReceived[13];
         servoRollCenter = valuesReceived[14];
         rollMinPulse = valuesReceived[15];
         rollMaxPulse = valuesReceived[16];
         htChannels[0] = valuesReceived[17];
         htChannels[1] = valuesReceived[18];
         htChannels[2] = valuesReceived[19];
         Serial.println(htChannels[0]);
         Serial.println(htChannels[1]);
         Serial.println(htChannels[2]);
         save Settings();
          // Debug info
          else if (serial_data[serial_index-5] == 'D' && serial_data[serial_index-4] == 'E' && serial_data[serial_index-3] == 'B' && serial_data[serial_index-2] == 'U' && serial_data[serial_index-1] == 'G') {
               debugOutput();
               serial_index=0;
               string_started = 0;
          // Start magnetometer cal
          else if (serial_data[serial_index-4] == 'C' && serial_data[serial_index-3] == 'A' && serial_data[serial_index-2] == 'S' && serial_data[serial_index-1] == 'T') {
               outputMag = 1;
               serial_index=0;
               string_started = 0;
          // Start accelerometer cal
          else if (serial_data[serial_index-4] == 'G' && serial_data[serial_index-3] == 'R' && serial_data[serial_index-2] == 'A' && serial_data[serial_index-1] == 'V') {
               outputAcc = 1;
               serial_index=0;
               string_started = 0;
          // Stop magnetometer cal
          else if (serial_data[serial_index-4] == 'C' && serial_data[serial_index-3] == 'A' && serial_data[serial_index-2] == 'E' && serial_data[serial_index-1] == 'N') {
               outputMag = 0;
               serial_index=0;
               string_started = 0;
          // Stop accelerometer cal
          else if (serial_data[serial_index-4] == 'G' && serial_data[serial_index-3] == 'R' && serial_data[serial_index-2] == 'E' && serial_data[serial_index-1] == 'N') {
               outputAcc = 0;
               serial_index=0;
               string_started = 0;
          // Start plotting if PLST received:
          else if (serial_data[serial_index-4] == 'P' && serial_data[serial_index-3] == 'L' && serial_data[serial_index-2] == 'S' && serial_data[serial_index-1] == 'T') {
               printPlot = 1;
               serial_index=0;
               string_started = 0;
          // Stop plotting if PLEN received:
          else if (serial_data[serial_index-4] == 'P' && serial_data[serial_index-3] == 'L' && serial_data[serial_index-2] == 'E' && serial_data[serial_index-1] == 'N') {
               printPlot = 0;
               serial_index=0;
               string_started = 0;
          // Save settings
          else if (serial_data[serial_index-4] == 'S' && serial_data[serial_index-3] == 'A' && serial_data[serial_index-2] == 'V' && serial_data[serial_index-1] == 'E') {
              save Settings();
               serial_index=0;
               string_started = 0;
          //Calibrate gyro
          else if (serial_data[serial_index-4] == 'C' && serial_data[serial_index-3] == 'A' && serial_data[serial_index-2] == 'L' && serial_data[serial_index-1] == 'I') {
               setSensorOffset();
               saveSsttings();
                Serial.print("Gyro offset measured:");
                Serial.print(gyroOff[0]);
                Serial.print(",");
                Serial.print(gyroOff[1]);
                Serial.print(",");
                Serial.println(gyroOff[2]);
               serial_index=0;
               string_started = 0;
            else if (serial_data[serial_index-2] == 'M' && serial_data[serial_index-1] == 'A') {
              Serial.println(serial_data);
              int valuesReceived[5] = {0,0,0,0,0};
              int comma_index =0;
                     comma_index++;
                 else {
                  magOffset[0] = valuesReceived[0]-2000;
                  magOffset[1] = valuesReceived[2]-2000;
                  magOffset[2] = valuesReceived[1]-2000;
                  saveMagData();
            else if (serial_data[serial_index-3] == 'A' && serial_data[serial_index-2] == 'C' && serial_data[serial_index-1] == 'C') {
              int comma_index =0;
           for (unsigned char k = 0; k < serial_index-3; k++) {
                     comma_index++;
                 else {
                  accOffset[0] = valuesReceived[0]-2000;
                  accOffset[1] = valuesReceived[1]-2000;
                  accOffset[2] = valuesReceived[2]-2000;
                  saveAccData();
         // If more than 100 bytes have been received, the string is not valid. Reset and "try again" (wait for $ to indicate start of new string).
           else if (serial_index > 100) {
               serial_index = 0;
               string_started = 0;
    else if (Serial.read() == '$') {
        string_started = 1;
  // if "read_sensors" flag is set high, read sensors and update
  if (read_sensors == 1) {
        updateSensors();
        gyroCalc();
        accCalc();
        magCalc();
        filter();
        if (counter++ >7) {
//          testGyroOutput();
       //   testMagOutput();
//           quickTest();
          if (printPlot == 1) {
             headtrackerOutput();
          else if (outputMag) {
             calMagOutput();
          else if (outputAcc) {
            calAccOutput();
            counter=0;
    // Will first update read_sensors when everything's done.
        read_sensors = 0;
void saveSettings() {
// This is the necessary head-tracler settings:
         maxPulse        = valuesReceived[4];
         servoCenter     = valuesReceived[5];
         tiltFactor     = (float)valuesReceived[6] / 10;
         panFactor     = (float)valuesReceived[7] / 10;
  // Chars
  EEPROM.write(1,(unsigned char) (tiltBeta*100));
  EEPROM.write(2,(unsigned char) (panBeta*100));
  EEPROM.write(3,(unsigned char) (gyroWeight*100));
  EEPROM.write(4,(unsigned char) (GyroWeightPan*100));
  // And some integers
  EEPROM.write(5,(unsigned char)maxPulse);
  EEPROM.write(6,(unsigned char)(maxPulse>>8));
  EEPROM.write(7,(unsigned char)servoPanCenter);
  EEPROM.write(8,(unsigned char)(servoPanCenter>>8));
  EEPROM.write(9,(unsigned char) (tiltFactor*10));
  EEPROM.write(10,(int)((tiltFactor*10))>>8);
  EEPROM.write(11,(unsigned char) (panFactor*10));
  EEPROM.write(12,(int)((panFactor*10))>>8);
  // Channel inverse settings:
  EEPROM.write(13,(unsigned char)(tiltInverse+1));
  EEPROM.write(14,(unsigned char)(rollInverse+1));
  EEPROM.write(15,(unsigned char)(panInverse+1));
  EEPROM.write(16,(unsigned char)servoTiltCenter);
  EEPROM.write(17,(unsigned char)(servoTiltCenter>>8));
  EEPROM.write(18,(unsigned char)servoRollCenter);
  EEPROM.write(19,(unsigned char)(servoRollCenter>>8));
  EEPROM.write(20,(unsigned char)panMaxPulse);
  EEPROM.write(21,(unsigned char)(panMaxPulse>>8));
  EEPROM.write(22,(unsigned char)panMinPulse);
  EEPROM.write(23,(unsigned char)(panMinPulse>>8));
  EEPROM.write(24,(unsigned char)tiltMaxPulse);
  EEPROM.write(25,(unsigned char)(tiltMaxPulse>>8));
  EEPROM.write(26,(unsigned char)tiltMinPulse);
  EEPROM.write(27,(unsigned char)(tiltMinPulse>>8));
  EEPROM.write(28,(unsigned char)rollMaxPulse);
  EEPROM.write(29,(unsigned char)(rollMaxPulse>>8));
  EEPROM.write(30,(unsigned char)rollMinPulse);
  EEPROM.write(31,(unsigned char)(rollMinPulse>>8));
  EEPROM.write(32,(unsigned char)htChannels[0]);
  EEPROM.write(33,(unsigned char)htChannels[1]);
  EEPROM.write(34,(unsigned char)htChannels[2]);
  // Saving gyro calibration values
  int temp = (int)(gyroOff[0]+500.5);
  EEPROM.write(35,(unsigned char)temp);
  EEPROM.write(36,(unsigned char)(temp>>8));
  temp = (int)(gyroOff[1]+500.5);
  EEPROM.write(37,(unsigned char)temp);
  EEPROM.write(38,(unsigned char)(temp>>8));
  temp = (int)(gyroOff[2]+500.5);
  EEPROM.write(39,(unsigned char)temp);
  EEPROM.write(40,(unsigned char)(temp>>8));
  Serial.println("Settings saved!");
void getSettings() {
  tiltBeta = (float)EEPROM.read(1)/100;
  panBeta = (float)EEPROM.read(2)/100;
  gyroWeight = (float)EEPROM.read(3)/100;
  GyroWeightPan = (float)EEPROM.read(4)/100;
  maxPulse = EEPROM.read(5)+(EEPROM.read(6)<<8);
  servoPanCenter = EEPROM.read(7)+(EEPROM.read(8)<<8);
  tiltFactor = (float)(EEPROM.read(9)+(EEPROM.read(10)<<8)) / 10;
  panFactor = (float)(EEPROM.read(11)+(EEPROM.read(12)<<8)) / 10;
  servoTiltCenter = EEPROM.read(16)+(EEPROM.read(17)<<8);
  servoRollCenter = EEPROM.read(18)+(EEPROM.read(19)<<8);
  panMaxPulse = EEPROM.read(20)+(EEPROM.read(21)<<8);
  panMinPulse = EEPROM.read(22)+(EEPROM.read(23)<<8);
  tiltMaxPulse = EEPROM.read(24)+(EEPROM.read(25)<<8);
  tiltMinPulse = EEPROM.read(26)+(EEPROM.read(27)<<8);
  rollMaxPulse = EEPROM.read(28)+(EEPROM.read(29)<<8);
  rollMinPulse = EEPROM.read(30)+(EEPROM.read(31)<<8);
  htChannels[0] = EEPROM.read(32);
  htChannels[1] = EEPROM.read(33);
  htChannels[2] = EEPROM.read(34);
  gyroOff[0] = EEPROM.read(35)+(EEPROM.read(36)<<8)-500;
  gyroOff[1] = EEPROM.read(37)+(EEPROM.read(38)<<8)-500;
  gyroOff[2] = EEPROM.read(39)+(EEPROM.read(40)<<8)-500;
  tiltInverse = -1;
  rollInverse = -1;
  panInverse = -1;
  if (EEPROM.read(13) == 2) {
      tiltInverse = 1;
  if (EEPROM.read(14) == 2) {
      rollInverse = 1;
  if (EEPROM.read(15) == 2) {
      panInverse = 1;
  magOffset[0] = EEPROM.read(200)+(EEPROM.read(201)<<8)-2000;
  magOffset[1] = EEPROM.read(202)+(EEPROM.read(203)<<8)-2000;
  magOffset[2] = EEPROM.read(204)+(EEPROM.read(205)<<8)-2000;
  accOffset[0] = EEPROM.read(206)+(EEPROM.read(207)<<8)-2000;
  accOffset[1] = EEPROM.read(208)+(EEPROM.read(209)<<8)-2000;
  accOffset[2] = EEPROM.read(210)+(EEPROM.read(211)<<8)-2000;
#if (DEBUG)
debugOutput();
#endif
void saveMagData() {
  int temp;
    temp = (int)(magOffset[0]+2000);
  EEPROM.write(200,(unsigned char)temp);
  EEPROM.write(201,(unsigned char)(temp>>8));
    temp = (int)(magOffset[1]+2000);
  EEPROM.write(202,(unsigned char)temp);
  EEPROM.write(203,(unsigned char)(temp>>8));
    temp = (int)(magOffset[2]+2000);
  EEPROM.write(204,(unsigned char)temp);
  EEPROM.write(205,(unsigned char)(temp>>8));
  Serial.println("Mag-offset saved!");
void saveAccData() {
  int temp;
    temp = (int)(accOffset[0]+2000);
  EEPROM.write(206,(unsigned char)temp);
  EEPROM.write(207,(unsigned char)(temp>>8));
    temp = (int)(accOffset[1]+2000);
  EEPROM.write(208,(unsigned char)temp);
  EEPROM.write(209,(unsigned char)(temp>>8));
    temp = (int)(accOffset[2]+2000);
  EEPROM.write(210,(unsigned char)temp);
  EEPROM.write(211,(unsigned char)(temp>>8));
  Serial.println("Acc-offset saved!");
  Serial.print(accOffset[0]);
  Serial.print(",");
  Serial.print(accOffset[1]);
  Serial.print(",");
  Serial.println(accOffset[2]);
void debugOutput() {
Serial.println();
Serial.println();
Serial.println();
Serial.println("------ Debug info------");
Serial.print("tiltBeta: ");
Serial.println(tiltBeta);
Serial.print("panBeta: ");
Serial.println(panBeta);
Serial.print("gyroWeight: ");
Serial.println(gyroWeight);
Serial.print("GyroWeightPan: ");
Serial.println(GyroWeightPan);
Serial.print("servoPanCenter: ");
Serial.println(servoPanCenter);
Serial.print("servoTiltCenter: ");
Serial.println(servoTiltCenter);
Serial.print("servoRollCenter: ");
Serial.println(servoRollCenter);
Serial.print("tiltFactor: ");
Serial.println(tiltFactor);
Serial.print("panFactor: ");
Serial.println(panFactor);
Serial.print("Gyro offset saved ");
Serial.print(",");
Serial.print(",");
Serial.print("Mag offset saved ");
Serial.print(magOffset[0]);
Serial.print(",");
Serial.print(magOffset[1]);
Serial.print(",");
Serial.println(magOffset[2]);
Serial.print("Acc offset saved ");
Serial.print(",");
Serial.print(",");
SensorInfoPrint();
接收机程序
//this programm will put out a PPM signal
//////////////////////CONFIGURATION///////////////////////////////
#define chanel_number 9  //set the number of chanels
#define default_servo_value 1500  //set the default servo value
#define PPM_FrLen 22500  //set the PPM frame length in microseconds (1ms = 1000μs)
#define PPM_PulseLen 300  //set the pulse length
#define onState 1  //set polarity of the pulses: 1 is positive, 0 is negative
#define sigPin 10  //set PPM signal output pin on the arduino
/*this array holds the servo values for the ppm signal
change theese values in your code (usually servo values move between 1000 and 2000)*/
int ppm[chanel_number];
unsigned int angs,ang1,ang2;
char xx;
void setup(){
  Serial.begin(9600);
  //initiallize default ppm values
  for(int i=0; i<chanel_number; i++){
    ppm[i]= default_servo_value;
  pinMode(sigPin, OUTPUT);
  digitalWrite(sigPin, !onState);  //set the PPM signal pin to the default state (off)
  cli();
  TCCR1A = 0; // set entire TCCR1 register to 0
  TCCR1B = 0;
  OCR1A = 100;  // compare match register, change this
  TCCR1B |= (1 << WGM12);  // turn on CTC mode
  TCCR1B |= (1 << CS11);  // 8 prescaler: 0,5 microseconds at 16mhz
  TIMSK1 |= (1 << OCIE1A); // enable timer compare interrupt
  sei();
void loop(){
  //put main code here
    angs=Serial.parseInt();  //angs=ang1*180+ang2
  ppm[1] = angs/180;
  ppm[1] = map(ppm[1],1,179,1000,2000);
  ppm[2] = angs%180;
  ppm[2] = map(ppm[2],1,179,1000,2000);
  //ang1=angs/180; ang2=angs%180;
xx++;
if(50<=xx)
  ppm[0] = analogRead(A0);
  ppm[0] = map(ppm[0],0,1023,1000,2000);
  xx=0;
  delayMicroseconds(200);
ISR(TIMER1_COMPA_vect){  //leave this alone
  static boolean state = true;
  TCNT1 = 0;
  if(state) {  //start pulse
    digitalWrite(sigPin, onState);
    OCR1A = PPM_PulseLen * 2;
    state = false;
  else{  //end pulse and calculate when to start the next pulse
    static byte cur_chan_numb;
    static unsigned int calc_rest;
    state = true;
    if(cur_chan_numb >= chanel_number){
      cur_chan_numb = 0;
      calc_rest = calc_rest + PPM_PulseLen;//
      OCR1A = (PPM_FrLen - calc_rest) * 2;
      calc_rest = 0;
    else{
      OCR1A = (ppm[cur_chan_numb] - PPM_PulseLen) * 2;
      calc_rest = calc_rest + ppm[cur_chan_numb];
      cur_chan_numb++;
原概念是位老外Dennis Fire提出的,他的程序只写了头追的传感部分,输出的信号通过无人机的遥控器教练功能发射,不知道如何转蓝牙
568981484作者
9年11个月前IP:上海
829290
程序这是祖国版魔改的,感觉魔友自己对arduino的blink语句也是半罐子水,所以我也看的一团乱麻
