Deepace UWB-2 2.8GHz-11GHz 全向 线极化 超宽带天线
2017/07/03
IP:四川
Deepace UWB-2 是一款单极型超宽带全向天线,天线主要面向超宽带定位、通讯等设备配合使用,天线覆盖频率2.8GHz至9GHz,驻波典型值1.5以下,性能优良,体积小,效率高,一致性好。
淘宝链接:XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
参数指标
天线阻抗:50欧
功率容量:5w
频率范围:2.8GHz-11GHz
回波损耗:10dB
增益:3.8dBi
驻波比:典型值1.5 (2.8GHz-11GHz 小于2)
接头类型:SMA-K(母,外螺纹内孔)
天线尺寸:30mm * 42mm(不含接头)
UWB-2天线回波损耗测量数据
UWB-2天线驻波比测量数据
[ 修改于9年5个月前 - 2017/07/03 17:08:17 ]
