t29959
请教这个是怎么产生脉冲微波的
2010/10/21
IP:广东
The setup developed for experimental validation is shown
in Fig. 1. It consists of a cylindrical tank filled with water for
optimal acoustic coupling between the acoustic detector and
the submerged imaging target. To generate high energy
pulses in the nanosecond range, we utilized a custom-made
pulser consisting of a high-voltage triggered spark gap
Model GP-41B, Perkin Elmer Inc., Waltham, MA for fast
discharge of energies stored in a high-voltage capacitor,
which was charged up to 40 kV. In this way, ultrawideband
high power electromagnetic impulses with durations of
10 ns, carrying energy of up to 0.7 J, were generated see
Sec. III for exact impulse shapes with tunable impulse repetition
frequency in the range of 1–100 Hz. For comparison,
due to substantial costs associated with ultrahigh-peak-power
microwave amplification equipment, the existing pulsed thermoacoustic
sources commonly use much lower energies of a
few millijoules per pulse along with relatively long pulse
durations in the microsecond range.3,17 As a result, the spatial
resolution significantly deteriorates while acquisition times
are prolonged due to extensive signal averaging essential for
noise suppression.
上图是装置
16年3个月前IP:未同步
262738
不懂英文,咋还有个电脑。。
16年3个月前IP:未同步
262743
估计电脑先被微波灭掉。。。
loulou85作者
16年3个月前IP:未同步
262865
电脑是数据采集的,采集transducer收到的超声波,这一部分可以不看,只要左边一部分就是微波发射了
16年2个月前IP:未同步
263358
求原文出处
loulou85作者
16年2个月前IP:未同步
264700
[s:251][s:251]
有高手能给看看吗,max发生器接天线产生微波,这种好做吗,对外界干扰大吗,哪里能做,谢谢
16年2个月前IP:未同步
264753
引用第5楼loulou85于2010-11-07 16:01发表的  :
[s:251][s:251]
如果电容是用的比较好的脉冲电容。。
不用接天线都可以当EMP了。。
