t42743
自制杀毒软件一份
2012/04/08
IP:福建
类模块代码请到9楼看……
自制的软件,用的是开源代码
仍然是“U盘实用工具”作者Mr.Lin的作品。
软件的代码是我修改过的,呵呵……
attachment icon My  神龙安全.rar 820.74KB RAR 80次下载
直接上软件,自己研究
请不要外传,谢谢!!!
如果有修改,可以直接发到Ghostdie@foxmail.com
代码奉上:
如图:FRMMain
2.模块代码:Option Explicit
Public Declare Sub Sleep Lib _    "kernel32" (ByVal dwMilliseconds As Long)Private Declare Function SHGetSpecialFolderLocation Lib _    "shell32.dll" (ByVal hwndOwner As Long, _    ByVal nFolder As Long, _    pidl As ITEMIDLIST) As LongPrivate Declare Function SHGetPathFromIDList Lib _    "shell32" (ByVal pidList As Long, _    ByVal lpBuffer As String) As LongPrivate Declare Function GetWindowsDirectory Lib _    "kernel32.dll" Alias "GetWindowsDirectoryA" ( _    ByVal lpBuffer As String, _    ByVal nSize As Long) As LongPrivate Declare Function GetSystemDirectory Lib _    "kernel32.dll" Alias "GetSystemDirectoryA" ( _    ByVal lpBuffer As String, _    ByVal nSize As Long) As LongPrivate Declare Function SHRunDialog Lib _    "shell32" Alias "#61" ( _    ByVal hOwner As Long, _    ByVal Unknown1 As Long, _    ByVal Unknown2 As Long, _    ByVal szTitle As String, _    ByVal szPrompt As String, _    ByVal uFlags As Long) As LongPrivate Declare Function ShellExecuteEx Lib _    "shell32" Alias "ShellExecuteExA" ( _    SEI As SHELLEXECUTEINFO) As LongPrivate Declare Function ShellExecute Lib _    "shell32.dll" Alias "ShellExecuteA" ( _    ByVal hwnd As Long, _    ByVal lpOperation As String, _    ByVal lpFile As String, _    ByVal lpParameters As String, _    ByVal lpDirectory As String, _    ByVal nShowCmd As Long) As LongPrivate Declare Function SHGetFileInfo Lib _    "shell32.dll" Alias "SHGetFileInfoA" ( _    ByVal pszPath As String, _    ByVal dwFileAttributes As Long, _    psfi As SHFILEINFO, _    ByVal cbFileInfo As Long, _    ByVal uFlags As Long) As Long    Private Type SHELLEXECUTEINFO    cbSize As Long    fMask As Long    hwnd As Long    lpVerb As String    lpFile As String    lpParameters As String    lpDirectory As String    nShow As Long    hInstApp As Long    lpIDList As Long    lpClass As String    hkeyClass As Long    dwHotKey As Long    hIcon As Long    hProcess As LongEnd Type
Private Type BrowseInfo    lnghwnd As Long    pIDLRoot As Long    pszDisplayName As Long    lpszTitle As Long    ulFlags As Long    lpfnCallback As Long    lParam As Long    iImage As LongEnd Type
Private Type SHITEMID    cb As Long    abID As ByteEnd Type
Private Type ITEMIDLIST    mkid As SHITEMIDEnd Type
Public Enum SpecialFolder    CSIDL_RECENT = &H8    CSIDL_PROFILER = &H28    CSIDL_HISTORY = &H22End Enum
Private Const BIF_NEWDIALOGSTYLE As Long = &H40Private Const BIF_EDITBOX As Long = &H10Private Const MAX_PATH As Integer = 260Private Const SEE_MASK_INVOKEIDLIST = &HCPrivate Const SEE_MASK_NOCLOSEPROCESS = &H40Private Const SEE_MASK_FLAG_NO_UI = &H400Private Const OFN_OVERWRITEPROMPT = &H2Private Const OFN_PATHMUSTEXIST = &H800Private Const OFN_EXPLORER = &H80000Private Const OFN_ENABLEHOOK = &H20Private Const OFN_HIDEREADONLY = &H4Private Const SHGFI_DISPLAYNAME As Long = &H200Private Const SHGFI_TYPENAME As Long = &H400
Private Type SHFILEINFO    hIcon As Long    iIcon As Long    dwAttributes As Long    szDisplayName As String * MAX_PATH    szTypeName As String * 80End Type
Private Declare Sub CoTaskMemFree Lib _    "ole32.dll" (ByVal hMem As Long)Private Declare Function lstrcat Lib _    "kernel32" Alias "lstrcatA" _    (ByVal lpString1 As String, _    ByVal lpString2 As String) As LongPrivate Declare Function SHBrowseForFolder Lib _    "shell32" (lpBI As BrowseInfo) As Long
Public Function BrowseForFolder(lnghwnd As Long, _    strPrompt As String) As String    On Error GoTo ehBrowseForFolder    Dim intNull As Integer    Dim lngIDList As Long, lngResult As Long    Dim strPath As String    Dim udtBI As BrowseInfo    With udtBI        .lnghwnd = lnghwnd        .lpszTitle = lstrcat(strPrompt, "")        .ulFlags = BIF_NEWDIALOGSTYLE + BIF_EDITBOX    End With    lngIDList = SHBrowseForFolder(udtBI)    If lngIDList <> 0 Then        strPath = String(MAX_PATH, 0)        lngResult = SHGetPathFromIDList(lngIDList, _            strPath)        Call CoTaskMemFree(lngIDList)        intNull = InStr(strPath, vbNullChar)            If intNull > 0 Then                strPath = Left(strPath, intNull - 1)            End If    End If    BrowseForFolder = strPath    Exit FunctionehBrowseForFolder:    BrowseForFolder = EmptyEnd Function
Public Function GetSpecialFolder(FolderType As SpecialFolder) As String    Dim r As Long, sPath As String    Dim IDL As ITEMIDLIST    r = SHGetSpecialFolderLocation(100, FolderType, IDL)    sPath = Space$(512)    r = SHGetPathFromIDList(ByVal IDL.mkid.cb, ByVal sPath)    GetSpecialFolder = Left$(sPath, InStr(1, sPath, Chr$(0)) - 1)End Function
Public Function GetWindowsPath() As String    Dim lpBuffer As String * 255    Dim nSize As Long    nSize = GetWindowsDirectory(lpBuffer, 255)    GetWindowsPath = Left(lpBuffer, nSize) & "\"End Function
Public Function GetSystem32Path() As String    Dim lpBuffer As String * 255    Dim nSize As Long    nSize = GetSystemDirectory(lpBuffer, 255)    GetSystem32Path = Left(lpBuffer, nSize) & "\"End Function
Public Function OpenInFolder(lvwItemExe As ListView, ItemId As Integer) As Double    On Error Resume Next    OpenInFolder = Shell("explorer.exe /select, " & _        lvwItemExe.SelectedItem.SubItems(ItemId), vbNormalFocus)End Function
Public Function OpenDosPrompt(lvwFilePath As ListView, _    ItemExepath As Integer) As Long    On Error Resume Next    OpenDosPrompt = ShellExecute(1, vbNullString, "XXXXXXXXXXX", _        vbNullString, GetFilePath(lvwFilePath.SelectedItem.SubItems(ItemExepath)), 1)End Function
Public Function ShowRunApp(hwnd As Long) As Long    On Error Resume Next    ShowRunApp = SHRunDialog(hwnd, 0, 0, _        StrConv("New Process", vbUnicode), _        StrConv("Type the name of a program, folder, document, or Internet Resource," _        & " and Windows will open it for you.", vbUnicode), 0)End Function
Public Function OpenXPTool(hwnd As Long, lpOperation As String) As Long    On Error Resume Next    OpenXPTool = ShellExecute(hwnd, vbNullString, lpOperation, _        vbNullString, Left(GetWindowsPath, 3), 1)End Function
Public Function OnlineHelp(hwnd As Long, strSite As String) As Long    On Error Resume Next    OnlineHelp = ShellExecute(hwnd, vbNullString, _        "http://" & strSite, vbNullString, Left(GetWindowsPath, 3), 1)End Function
Public Function ShowFileProperties(hwndOwner As Long, _    lvwFilePath As ListView, ItemExepath As Integer, _    Optional lUseSubItem As Boolean = True) _     As Long    On Error Resume Next    Dim SEI As SHELLEXECUTEINFO    Dim slpFileName As String    If lUseSubItem Then        slpFileName = lvwFilePath.SelectedItem.SubItems(ItemExepath)    Else        slpFileName = lvwFilePath.SelectedItem    End If    With SEI        .cbSize = Len(SEI)        .fMask = SEE_MASK_NOCLOSEPROCESS Or _            SEE_MASK_INVOKEIDLIST Or SEE_MASK_FLAG_NO_UI        .hwnd = hwndOwner        .lpVerb = "properties"        .lpFile = slpFileName        .lpParameters = vbNullChar        .lpDirectory = vbNullChar        .nShow = 0        .hInstApp = 1        .lpIDList = 0    End With    Call ShellExecuteEx(SEI)End Function
Public Function GetFilePath(sPath As String) As String    Dim i As Integer    For i = Len(sPath) To 1 Step -1        If Mid$(sPath, i, 1) = "\" Then            GetFilePath = Mid$(sPath, 1, i)            Exit For        End If    Next iEnd Function
Public Function GetPathType(Path As String) As String    Dim FileInfo As SHFILEINFO, lngRet As Long    lngRet = SHGetFileInfo(Path, 0, FileInfo, _        Len(FileInfo), SHGFI_DISPLAYNAME Or SHGFI_TYPENAME)    If lngRet = 0 Then GetPathType = _        Trim$(GetFileExtension(Path) & " File"): Exit Function    GetPathType = Left$(FileInfo.szTypeName, _        InStr(1, FileInfo.szTypeName, vbNullChar) - 1)End Function
Public Function GetFileExtension(Path As String) As String    Dim intRet As Integer: intRet = InStrRev(Path, ".")    If intRet = 0 Then Exit Function    GetFileExtension = UCase(Mid$(Path, intRet + 1))End Function
Option Explicit
Dim CRC32 As New clsGetCRC32
Function GetChecksum(sFile As String) As String    On Error GoTo ErrHandle    Dim cb0 As Byte    Dim cb1 As Byte    Dim cb2 As Byte    Dim cb3 As Byte    Dim cb4 As Byte    Dim cb5 As Byte    Dim cb6 As Byte    Dim cb7 As Byte    Dim cb8 As Byte    Dim cb9 As Byte    Dim cb10 As Byte    Dim cb11 As Byte    Dim cb12 As Byte    Dim cb13 As Byte    Dim cb14 As Byte    Dim cb15 As Byte    Dim cb16 As Byte    Dim cb17 As Byte    Dim cb18 As Byte    Dim cb19 As Byte    Dim cb20 As Byte    Dim cb21 As Byte    Dim cb22 As Byte    Dim cb23 As Byte    Dim buff As String    Open sFile For Binary Access Read As #1        buff = Space$(1)        Get #1, , buff    Close #1    Open sFile For Binary Access Read As #2        Get #2, 512, cb0        Get #2, 1024, cb1        Get #2, 2048, cb2        Get #2, 3000, cb3        Get #2, 4096, cb4        Get #2, 5000, cb5        Get #2, 6000, cb6        Get #2, 7000, cb7        Get #2, 8192, cb8        Get #2, 9000, cb9        Get #2, 10000, cb10        Get #2, 11000, cb11        Get #2, 12288, cb12        Get #2, 13000, cb13        Get #2, 14000, cb14        Get #2, 15000, cb15        Get #2, 16384, cb16        Get #2, 17000, cb17        Get #2, 18000, cb18        Get #2, 19000, cb19        Get #2, 20480, cb20        Get #2, 21000, cb21        Get #2, 22000, cb22        Get #2, 23000, cb23    Close #2    buff = cb0    buff = buff & cb1    buff = buff & cb2    buff = buff & cb3    buff = buff & cb4    buff = buff & cb5    buff = buff & cb6    buff = buff & cb7    buff = buff & cb8    buff = buff & cb9    buff = buff & cb10    buff = buff & cb11    buff = buff & cb12    buff = buff & cb13    buff = buff & cb14    buff = buff & cb15    buff = buff & cb16    buff = buff & cb17    buff = buff & cb18    buff = buff & cb19    buff = buff & cb20    buff = buff & cb21    buff = buff & cb22    buff = buff & cb23    GetChecksum = CRC32.StringChecksum(buff)    Set CRC32 = Nothing    Exit FunctionErrHandle:    Close #2End Function
Function GetFullCRC(sFile As String) As String    GetFullCRC = CRC32.FileChecksum(sFile)End Function
Option Explicit
Private Type tagInitCommonControlsEx   lngSize As Long   lngICC As LongEnd Type
Public Declare Function InitCommonControls Lib _    "comctl32.dll" () As LongPrivate Declare Function InitCommonControlsEx Lib _    "comctl32.dll" (iccex As tagInitCommonControlsEx) As Boolean
Private Const ICC_USEREX_CLASSES = &H200
Sub Main()    'If Year(Now) < 2008 Then    '    MsgBox "Cannot open application: System Time is not valid.", _    '        vbCritical + vbSystemModal, "Error Opening Application"    '    End    'End If    Dim iccex As tagInitCommonControlsEx    With iccex        .lngSize = LenB(iccex)        .lngICC = ICC_USEREX_CLASSES    End With    InitCommonControlsEx iccex    On Error GoTo 0    App.TaskVisible = False    App.Title = GenerateRandomTitle(True)    frmLoading.ShowEnd Sub
'[s:9]rivate Sub Register_Ext()'    CreateRegistryKey HKEY_CLASSES_ROOT, "evdfile"'    CreateRegistryKey HKEY_CLASSES_ROOT, "evdfile\DefaultIcon"'    CreateStringValue HKEY_CLASSES_ROOT, "evdfile", "", _'        "External Virus Database"'    CreateStringValue HKEY_CLASSES_ROOT, "evdfile\DefaultIcon", "", _'        "%SystemRoot%\System32\shell32.dll,-154"'    CreateRegistryKey HKEY_CLASSES_ROOT, ".evd"'    CreateStringValue HKEY_CLASSES_ROOT, ".evd", "", "evdfile"'End Sub
'Sub SaveAppSettings()'    Dim lReg As Long'    With frmMain'        ' Register Application'        CreateDwordValue HKEY_CURRENT_USER, SMP_KEY, "Register", 1'        Register_Ext'        ' Save File Extensions'        CreateDwordValue HKEY_CURRENT_USER, SMP_KEY, "UseExtensionList", _'            Abs(CLng(.optExt.Value))'        CreateDwordValue HKEY_CURRENT_USER, SMP_KEY, "Extension", _'            CLng(.cboExt.ListIndex)'        ' Save Scan Options'        CreateDwordValue HKEY_CURRENT_USER, SMP_KEY, "FixErrorRegistry", _'            CLng(.chkFixReg.Value)'        CreateDwordValue HKEY_CURRENT_USER, SMP_KEY, "RepairData", _'            CLng(.chkRep.Value)'        CreateDwordValue HKEY_CURRENT_USER, SMP_KEY, "HiddenRecovery", _'            CLng(.chkHidden.Value)'        CreateDwordValue HKEY_CURRENT_USER, SMP_KEY, "ScanMemory", _'            CLng(.chkScanMem.Value)'        CreateDwordValue HKEY_CURRENT_USER, SMP_KEY, "WarningSound", _'            CLng(.chkSound.Value)'        ' Save Window Settings'        CreateDwordValue HKEY_CURRENT_USER, SMP_KEY, "AlwaysOnTop", _'            CLng(.chkOnTop.Value)'        CreateDwordValue HKEY_CURRENT_USER, SMP_KEY, "Transparency", _'            CLng(.chkTrans.Value)'        CreateDwordValue HKEY_CURRENT_USER, SMP_KEY, "HideWindowTitle", _'            CLng(.chkHideTitle.Value)'        ' Save Reporting Service'        If .optReport.Value = True Then'            lReg = 1'        ElseIf .optFullReport.Value = True Then'            lReg = 2'        Else'            lReg = 0'        End If'        CreateDwordValue HKEY_CURRENT_USER, SMP_KEY, "ReportingService", lReg'    End With'End Sub
'Sub LoadAppSettings()'    Dim lReg As Long'    With frmMain'        ' Load File Extensions'        lReg = GetDWORDValue(HKEY_CURRENT_USER, SMP_KEY, "UseExtensionList")'        If lReg = 1 Then'            .optAllFiles.Value = False'            .optExt.Value = True'            .cboExt.Enabled = True'        Else'            .optAllFiles.Value = True'            .optExt.Value = False'            .cboExt.Enabled = False'        End If'        .cboExt.ListIndex = GetDWORDValue(HKEY_CURRENT_USER, SMP_KEY, "Extension")'        ' Load Scan Options'        .chkFixReg.Value = GetDWORDValue(HKEY_CURRENT_USER, SMP_KEY, "FixErrorRegistry")'        .chkRep.Value = GetDWORDValue(HKEY_CURRENT_USER, SMP_KEY, "RepairData")'        .chkHidden.Value = GetDWORDValue(HKEY_CURRENT_USER, SMP_KEY, "HiddenRecovery")'        .chkScanMem.Value = GetDWORDValue(HKEY_CURRENT_USER, SMP_KEY, "ScanMemory")'        .chkSound.Value = GetDWORDValue(HKEY_CURRENT_USER, SMP_KEY, "WarningSound")'        ' Load Window Settings'        .chkTrans.Value = GetDWORDValue(HKEY_CURRENT_USER, SMP_KEY, "AlwaysOnTop")'        .chkHideTitle.Value = GetDWORDValue(HKEY_CURRENT_USER, SMP_KEY, "Transparency")'        .chkOnTop.Value = GetDWORDValue(HKEY_CURRENT_USER, SMP_KEY, "HideWindowTitle")'        ' Load Reporting Service'        lReg = GetDWORDValue(HKEY_CURRENT_USER, SMP_KEY, "ReportingService")'        If lReg = 1 Then'            .optReport.Value = True'        ElseIf lReg = 2 Then'            .optFullReport.Value = True'        Else'            .optOffReport.Value = True'        End If'    End With'End Sub
'Sub DefaultAppSettings()'    With frmMain'        .optAllFiles.Value = True'        .cboExt.ListIndex = 4'        .chkRep.Value = vbChecked'        .chkScanMem.Value = vbChecked'        .chkSound.Value = vbChecked'        .chkOnTop.Value = vbChecked'        .chkHideTitle.Value = vbChecked'        .optReport.Value = True'    End With'End Sub
Option Explicit
Private Declare Sub GlobalMemoryStatus Lib _    "kernel32" (lpBuffer As MEMORYSTATUS)
Private Type MEMORYSTATUS    dwLength        As Long    dwMemoryLoad    As Long    dwTotalPhys     As Long    dwAvailPhys     As Long    dwTotalPageFile As Long    dwAvailPageFile As Long    dwTotalVirtual  As Long    dwAvailVirtual  As LongEnd Type
Private Enum PDH_STATUS    PDH_CSTATUS_VALID_DATA = &H0    PDH_CSTATUS_NEW_DATA = &H1End Enum
Private Declare Function PdhOpenQuery Lib _    "[s:9]DH.DLL" (ByVal Reserved As Long, _    ByVal dwUserData As Long, _    ByRef hQuery As Long) As PDH_STATUSPrivate Declare Function PdhVbAddCounter Lib _    "[s:9]DH.DLL" (ByVal QueryHandle As Long, _    ByVal CounterPath As String, _    ByRef CounterHandle As Long) As PDH_STATUSPrivate Declare Function PdhCollectQueryData Lib _    "[s:9]DH.DLL" (ByVal QueryHandle As Long) As PDH_STATUSPrivate Declare Function PdhVbGetDoubleCounterValue Lib _    "[s:9]DH.DLL" (ByVal CounterHandle As Long, _    ByRef CounterStatus As Long) As Double
Private Type CounterInfo    hCounter As Long    strName As StringEnd Type
Dim pdhStatus As PDH_STATUSDim Counters(0 To 99) As CounterInfoDim hQuery As Long
Public Sub MemoryInfo(lAPageFile As Label, lAPhys As Label, _    lAVirtual As Label, lTPageFile As Label, lTPhys As Label, _    lTVirtual As Label, lMemUsage As Label)    Dim MemStat As MEMORYSTATUS    MemStat.dwLength = Len(MemStat)    GlobalMemoryStatus MemStat    With MemStat        lAPageFile.Caption = Format(.dwAvailPageFile _            / 1024, "###,###,###") & " KB"        lAPhys.Caption = Format(.dwAvailPhys / 1024, _            "###,###,###") & " KB"        lAVirtual.Caption = Format(.dwAvailVirtual / _            1024, "###,###,###") & " KB"        lTPageFile.Caption = Format(.dwTotalPageFile _            / 1024, "###,###,###") & " KB"        lTPhys.Caption = Format(.dwTotalPhys / 1024, _            "###,###,###") & " KB"        lTVirtual.Caption = Format(.dwTotalVirtual / _            1024, "###,###,###") & " KB"        lMemUsage.Caption = .dwMemoryLoad & " %"    End WithEnd Sub
Public Sub UpdateValues(lblCPU As Label)    Dim dblCounterValue As Double    Dim pdhStatus As Long    Dim strInfo As String    Dim i As Long    PdhCollectQueryData (hQuery)    i = 0    dblCounterValue = PdhVbGetDoubleCounterValue( _        Counters(i).hCounter, pdhStatus)    If (pdhStatus = PDH_CSTATUS_VALID_DATA) Or (pdhStatus _        = PDH_CSTATUS_NEW_DATA) Then        lblCPU.Caption = Abs(Fix(dblCounterValue)) & " %"    End IfEnd Sub
Private Sub AddCounter(strCounterName As String, _    hQuery As Long)    Dim pdhStatus As PDH_STATUS    Dim hCounter As Long, currentCounterIdx As Long    pdhStatus = PdhVbAddCounter(hQuery, strCounterName, _        hCounter)    Counters(currentCounterIdx).hCounter = hCounter    Counters(currentCounterIdx).strName = strCounterName    currentCounterIdx = currentCounterIdx + 1End Sub
Public Sub GetCPUInfo(lblCPU As Label)    pdhStatus = PdhOpenQuery(0, 1, hQuery)    AddCounter "\Processor(0)\% Processor Time", hQuery    UpdateValues lblCPUEnd Sub
Option Explicit
Private Const TH32CS_SNAPHEAPLIST = &H1Private Const TH32CS_SNAPPROCESS = &H2Private Const TH32CS_SNAPTHREAD = &H4Private Const TH32CS_SNAPMODULE = &H8Private Const TH32CS_SNAPALL = (TH32CS_SNAPHEAPLIST Or _    TH32CS_SNAPPROCESS Or TH32CS_SNAPTHREAD Or TH32CS_SNAPMODULE)Private Const MAX_PATH = 260Private Const PROCESS_QUERY_INFORMATION = 1024Private Const PROCESS_VM_READ = 16Private Const PROCESS_ALL_ACCESS = &H1F0FFFPrivate Const THREAD_SUSPEND_RESUME = &H2Private Const REGISTER_SERVICE = 1Private Const UNREGISTER_SERVICE = 0
Private Type PROCESSENTRY32    dwSize As Long    cntUsage As Long    th32ProcessID As Long    th32DefaultHeapID As Long    th32ModuleID As Long    cntThreads As Long    th32ParentProcessID As Long    pcPriClassBase As Long    dwFlags As Long    szExeFile As String * MAX_PATHEnd Type
Private Type MODULEENTRY32    dwSize As Long    th32ModuleID As Long    th32ProcessID As Long    GlblcntUsage As Long    ProccntUsage As Long    modBaseAddr As Long    modBaseSize As Long    hModule As Long    szModule As String * 256    szExePath As String * 260End Type
Private Type THREADENTRY32    dwSize As Long    cntUsage As Long    th32ThreadID As Long    th32OwnerProcessID As Long    tpBasePri As Long    tpDeltaPri As Long    dwFlags As LongEnd Type
Private Type PROCESS_MEMORY_COUNTERS    cb As Long    PageFaultCount As Long    PeakWorkingSetSize As Long    WorkingSetSize As Long    QuotaPeakPagedPoolUsage As Long    QuotaPagedPoolUsage As Long    QuotaPeakNonPagedPoolUsage As Long    QuotaNonPagedPoolUsage As Long    PagefileUsage As Long    PeakPagefileUsage As LongEnd Type
Private Type OFSTRUCT    cBytes As Byte    fFixedDisk As Byte    nErrCode As Integer    Reserved1 As Integer    Reserved2 As Integer    szPathName(256) As ByteEnd Type
Public Type VERHEADER    CompanyName As String    FileDescription As String    FileVersion As String    InternalName As String    LegalCopyright As String    OrigionalFileName As String    ProductName As String    ProductVersion As String    Comments As String    LegalTradeMarks As String    PrivateBuild As String    SpecialBuild As StringEnd Type
Private Declare Function RegisterServiceProcess Lib _    "kernel32" (ByVal dwProcessId As Long, _    ByVal dwType As Long) As LongPublic Declare Function GetCurrentProcessId Lib _    "kernel32" () As LongPrivate Declare Function CreateToolhelp32Snapshot Lib _    "kernel32" (ByVal lFlags As Long, _    ByVal lProcessID As Long) As LongPrivate Declare Function Process32First Lib _    "kernel32" (ByVal hSnapShot As Long, _    uProcess As PROCESSENTRY32) As LongPrivate Declare Function Process32Next Lib _    "kernel32" (ByVal hSnapShot As Long, _    uProcess As PROCESSENTRY32) As LongPrivate Declare Function CloseHandle Lib _    "kernel32" (ByVal hObject As Long) As LongPrivate Declare Function Module32First Lib _    "kernel32" (ByVal hSnapShot As Long, _    uProcess As MODULEENTRY32) As LongPrivate Declare Function Module32Next Lib _    "kernel32" (ByVal hSnapShot As Long, _    uProcess As MODULEENTRY32) As LongPrivate Declare Function OpenProcess Lib _    "kernel32" (ByVal dwDesiredAccess As Long, _    ByVal bInheritHandle As Long, _    ByVal dwProcessId As Long) As LongPrivate Declare Function TerminateProcess Lib _    "kernel32" (ByVal hProcess As Long, _    ByVal uExitCode As Long) As LongPrivate Declare Function GetPriorityClass Lib _    "kernel32" (ByVal hProcess As Long) As LongPrivate Declare Function SetPriorityClass Lib _    "kernel32" (ByVal hProcess As Long, _    ByVal dwPriorityClass As Long) As LongPrivate Declare Function OpenThread Lib _    "kernel32.dll" (ByVal dwDesiredAccess As Long, _    ByVal bInheritHandle As Boolean, _    ByVal dwThreadId As Long) As LongPrivate Declare Function ResumeThread Lib _    "kernel32.dll" (ByVal hThread As Long) As LongPrivate Declare Function SuspendThread Lib _    "kernel32.dll" (ByVal hThread As Long) As LongPrivate Declare Function Thread32First Lib _    "kernel32.dll" (ByVal hSnapShot As Long, _    ByRef lpte As THREADENTRY32) As BooleanPrivate Declare Function Thread32Next Lib _    "kernel32.dll" (ByVal hSnapShot As Long, _    ByRef lpte As THREADENTRY32) As BooleanPrivate Declare Function lstrlen Lib _    "kernel32" Alias "lstrlenA" ( _    ByVal lpString As String) As LongPublic Declare Function GetFileAttributes Lib _    "kernel32" Alias "GetFileAttributesA" ( _    ByVal lpFileName As String) As LongPrivate Declare Function GetFileTitle Lib _    "comdlg32.dll" Alias "GetFileTitleA" ( _    ByVal lpszFile As String, _    ByVal lpszTitle As String, _    ByVal cbBuf As Integer) As IntegerPrivate Declare Function OpenFile Lib _    "kernel32.dll" (ByVal lpFileName As String, _    ByRef lpReOpenBuff As OFSTRUCT, _    ByVal wStyle As Long) As LongPrivate Declare Function GetFileSize Lib _    "kernel32" (ByVal hFile As Long, _    lpFileSizeHigh As Long) As LongPrivate Declare Function GetProcessMemoryInfo Lib _    "psapi.dll" (ByVal Process As Long, _    ByRef ppsmemCounters As PROCESS_MEMORY_COUNTERS, _    ByVal cb As Long) As LongPrivate Declare Function GetLongPathName Lib _    "kernel32.dll" Alias "GetLongPathNameA" ( _    ByVal lpszShortPath As String, _    ByVal lpszLongPath As String, _    ByVal cchBuffer As Long) As LongPrivate Declare Function GetShortPathNameA Lib _    "kernel32" (ByVal lpszLongPath As String, _    ByVal lpszShortPath As String, _    ByVal cchBuffer As Long) As LongPrivate Declare Function GetFileVersionInfo Lib _    "Version.dll" Alias "GetFileVersionInfoA" ( _    ByVal lptstrFilename As String, _    ByVal dwhandle As Long, _    ByVal dwlen As Long, _    lpData As Any) As LongPrivate Declare Function GetFileVersionInfoSize Lib _    "Version.dll" Alias "GetFileVersionInfoSizeA" ( _    ByVal lptstrFilename As String, _    lpdwHandle As Long) As LongPrivate Declare Function VerQueryValue Lib _    "Version.dll" Alias "VerQueryValueA" ( _    pBlock As Any, _    ByVal lpSubBlock As String, _    lplpBuffer As Any, _    puLen As Long) As LongPrivate Declare Sub MoveMemory Lib _    "kernel32" Alias "RtlMoveMemory" ( _    dest As Any, _    ByVal Source As Long, _    ByVal Length As Long)Private Declare Function lstrcpy Lib _    "kernel32" Alias "lstrcpyA" ( _    ByVal lpString1 As String, _    ByVal lpString2 As Long) As Long
Public Enum PriorityClass   REALTIME_PRIORITY_CLASS = &H100   HIGH_PRIORITY_CLASS = &H80   NORMAL_PRIORITY_CLASS = &H20   IDLE_PRIORITY_CLASS = &H40End Enum
Dim GetIco As New clsGetIconFile
Function StripNulls(ByVal sStr As String) As String    StripNulls = Left$(sStr, lstrlen(sStr))End Function
Public Function NTProcessList(lvwProc As ListView, _    ilsProc As ImageList) As Long    On Error Resume Next    Screen.MousePointer = vbHourglass    Dim Filename As String, ExePath As String    Dim hProcSnap As Long, hModuleSnap As Long, _        lProc As Long    Dim uProcess As PROCESSENTRY32, _        uModule As MODULEENTRY32    Dim lvwProcItem As ListItem    Dim intLVW As Integer    Dim hVer As VERHEADER    ExePath = String$(128, Chr$(0))    hProcSnap = CreateToolhelp32Snapshot(TH32CS_SNAPALL, 0&)    uProcess.dwSize = Len(uProcess)    lProc = Process32First(hProcSnap, uProcess)    ilsProc.ListImages.Clear    lvwProc.ListItems.Clear    lvwProc.Visible = False    Do While lProc        If uProcess.th32ProcessID <> 0 Then            hModuleSnap = CreateToolhelp32Snapshot(TH32CS_SNAPALL, _                uProcess.th32ProcessID)            uModule.dwSize = Len(uModule)            Module32First hModuleSnap, uModule            If hModuleSnap > 0 Then                ExePath = StripNulls(uModule.szExePath)                Filename = GetFileName(ExePath)                GetVerHeader ExePath, hVer                ilsProc.ListImages.Add , "[s:9]ID" & uProcess.th32ProcessID, _                    GetIco.Icon(ExePath, SmallIcon)                Set lvwProcItem = lvwProc.ListItems.Add(, , Filename, , _                    "[s:9]ID" & uProcess.th32ProcessID)                With lvwProcItem                    .SubItems(1) = GetLongPath(ExePath)                    .SubItems(2) = Format(GetSizeOfFile(ExePath) / 1024, _                        "###,###") & " KB"                    .SubItems(3) = GetAttribute(ExePath)                    .SubItems(4) = hVer.FileDescription                    .SubItems(5) = uProcess.th32ProcessID                    .SubItems(6) = uProcess.cntThreads                    .SubItems(7) = Format(GetMemory(uProcess.th32ProcessID) / 1024, _                        "###,####") & " KB"                    .SubItems(8) = GetBasePriority(uProcess.th32ProcessID)                End With            End If        End If        lProc = Process32Next(hProcSnap, uProcess)    Loop    Call CloseHandle(hProcSnap)    For intLVW = 1 To lvwProc.ColumnHeaders.Count        LV_AutoSizeColumn lvwProc, lvwProc.ColumnHeaders.Item(intLVW)    Next intLVW    With lvwProc        With .ColumnHeaders            .Item(4).Width = 900            .Item(6).Width = 950            .Item(7).Width = 800            .Item(8).Width = 1250            .Item(9).Width = 800        End With        .Refresh        .Visible = True        .SetFocus    End With    Screen.MousePointer = vbNormalEnd Function
Public Function GetBasePriority(ReadPID As Long) As String    Dim hPID As Long    hPID = OpenProcess(PROCESS_QUERY_INFORMATION, 0, ReadPID)    Select Case GetPriorityClass(hPID)        Case 32: GetBasePriority = "Normal"        Case 64: GetBasePriority = "Idle"        Case 128: GetBasePriority = "High"        Case 256: GetBasePriority = "Realtime"        Case Else: GetBasePriority = "N/A"    End Select    Call CloseHandle(hPID)End Function
Public Function SetBasePriority(lvwProc As ListView, _    ItemProcessID As Integer, BasePriority As PriorityClass) As Long    Dim hPID As Long    hPID = OpenProcess(PROCESS_ALL_ACCESS, 0, lvwProc.SelectedItem.SubItems( _        ItemProcessID))    SetBasePriority = SetPriorityClass(hPID, BasePriority)    Call CloseHandle(hPID)End Function
Private Function Thread32Enum(ByRef Thread() As THREADENTRY32, _    ByVal lProcessID As Long) As Long    On Error Resume Next    ReDim Thread(0)    Dim THREADENTRY32 As THREADENTRY32    Dim hThreadSnap As Long    Dim lThread As Long    hThreadSnap = CreateToolhelp32Snapshot(TH32CS_SNAPTHREAD, lProcessID)    THREADENTRY32.dwSize = Len(THREADENTRY32)    If Thread32First(hThreadSnap, THREADENTRY32) = False Then        Thread32Enum = -1        Exit Function    Else        ReDim Thread(lThread)        Thread(lThread) = THREADENTRY32    End If    Do        If Thread32Next(hThreadSnap, THREADENTRY32) = False Then            Exit Do        Else            lThread = lThread + 1            ReDim Preserve Thread(lThread)            Thread(lThread) = THREADENTRY32        End If    Loop    Thread32Enum = lThread    Call CloseHandle(hThreadSnap)End Function
Public Function SetSuspendResumeThread(lvwProc As ListView, _    ItemProcessID As Integer, SuspendNow As Boolean) As Long    Dim Thread() As THREADENTRY32, hPID As Long, hThread As Long, i As Long    hPID = lvwProc.SelectedItem.SubItems(ItemProcessID)    Thread32Enum Thread(), hPID    For i = 0 To UBound(Thread)        If Thread(i).th32OwnerProcessID = hPID Then            hThread = OpenThread(THREAD_SUSPEND_RESUME, False, (Thread(i).th32ThreadID))            If SuspendNow Then                SetSuspendResumeThread = SuspendThread(hThread)            Else                SetSuspendResumeThread = ResumeThread(hThread)            End If            Call CloseHandle(hThread)        End If    Next iEnd Function
Public Function TerminateProcessID(lvwProc As ListView, _    ItemProcessID As Integer) As Long    Dim hPID As Long    hPID = OpenProcess(PROCESS_ALL_ACCESS, 0, lvwProc.SelectedItem.SubItems( _        ItemProcessID))    TerminateProcessID = TerminateProcess(hPID, 0)    Call CloseHandle(hPID)End Function
Public Function GetAttribute(ByVal sFilePath As String) As String    Select Case GetFileAttributes(sFilePath)        Case 1: GetAttribute = "R": Case 2: GetAttribute _            = "H": Case 3: GetAttribute = "RH": Case 4: _            GetAttribute = "S": Case 5: GetAttribute = _            "RS": Case 6: GetAttribute = "HS": Case 7: _            GetAttribute = "RHS"        Case 32: GetAttribute = "A": Case 33: GetAttribute _            = "RA": Case 34: GetAttribute = "HA": Case 35: _            GetAttribute = "RHA": Case 36: GetAttribute = _            "SA": Case 37: GetAttribute = "RSA": Case 38: _            GetAttribute = "HSA": Case 39: GetAttribute = _            "RHSA"        Case 128: GetAttribute = "Normal"        Case 2048: GetAttribute = "C": Case 2049: _            GetAttribute = "RC": Case 2050: GetAttribute = _            "HC": Case 2051: GetAttribute = "RHC": Case _            2052: GetAttribute = "SC": Case 2053: _            GetAttribute = "RSC": Case 2054: GetAttribute _            = "HSC": Case 2055: GetAttribute = "RHSC": Case _            2080: GetAttribute = "AC": Case 2081: _            GetAttribute = "RAC": Case 2082: GetAttribute _            = "HAC": Case 2083: GetAttribute = "RHAC": Case _            2084: GetAttribute = "SAC": Case 2085: _            GetAttribute = "RSAC": Case 2086: GetAttribute _            = "HSAC": Case 2087: GetAttribute = "RHSAC"        Case Else: GetAttribute = "N/A"    End SelectEnd Function
Public Function GetFileName(ByVal sFileName As String) As String    Dim buffer As String    buffer = String(255, 0)    GetFileTitle sFileName, buffer, Len(buffer)    buffer = StripNulls(buffer)    GetFileName = bufferEnd Function
Public Function GetSizeOfFile(ByVal PathFile As String) As Long    Dim hFile As Long, OFS As OFSTRUCT    hFile = OpenFile(PathFile, OFS, 0)    GetSizeOfFile = GetFileSize(hFile, 0)    Call CloseHandle(hFile)End Function
Public Function GetMemory(ProcessID As Long) As String    On Error Resume Next    Dim byteSize As Double, hProcess As Long, ProcMem As PROCESS_MEMORY_COUNTERS    ProcMem.cb = LenB(ProcMem)    hProcess = OpenProcess(PROCESS_QUERY_INFORMATION Or PROCESS_VM_READ, 0, ProcessID)    If hProcess <= 0 Then GetMemory = "N/A": Exit Function    GetProcessMemoryInfo hProcess, ProcMem, ProcMem.cb    byteSize = ProcMem.WorkingSetSize    GetMemory = byteSize    Call CloseHandle(hProcess)End Function
Private Function GetLongPath(ByVal ShortPath As String) As String    Dim lngRet As Long    GetLongPath = String$(MAX_PATH, vbNullChar)    lngRet = GetLongPathName(ShortPath, GetLongPath, Len(GetLongPath))    If lngRet > Len(GetLongPath) Then        GetLongPath = String$(lngRet, vbNullChar)        lngRet = GetLongPathName(ShortPath, GetLongPath, lngRet)    End If    If Not lngRet = 0 Then GetLongPath = Left$(GetLongPath, lngRet)End Function
Public Function GetVerHeader(ByVal fPN$, ByRef oFP As VERHEADER)    Dim lngBufferlen&, lngDummy&, lngRc&, lngVerPointer&, lngHexNumber&, i%    Dim bytBuffer() As Byte, bytBuff(255) As Byte, strBuffer$, strLangCharset$, _        strVersionInfo(11) As String, strTemp[    wind_phpcode_6    ]nbsp;   If Dir(fPN$, vbHidden + vbArchive + vbNormal + vbReadOnly + vbSystem) = "" Then        With oFP            .CompanyName = "The file """ & GetShortPath(fPN) & """ N/A"            .FileDescription = "The file """ & GetShortPath(fPN) & """ N/A"            .FileVersion = "The file """ & GetShortPath(fPN) & """ N/A"            .InternalName = "The file """ & GetShortPath(fPN) & """ N/A"            .LegalCopyright = "The file """ & GetShortPath(fPN) & """ N/A"            .OrigionalFileName = "The file """ & GetShortPath(fPN) & """ N/A"            .ProductName = "The file """ & GetShortPath(fPN) & """ N/A"            .ProductVersion = "The file """ & GetShortPath(fPN) & """ N/A"            .Comments = "The file """ & GetShortPath(fPN) & """ N/A"            .LegalTradeMarks = "The file """ & GetShortPath(fPN) & """ N/A"            .PrivateBuild = "The file """ & GetShortPath(fPN) & """ N/A"            .SpecialBuild = "The file """ & GetShortPath(fPN) & """ N/A"        End With        Exit Function    End If    lngBufferlen = GetFileVersionInfoSize(fPN$, 0)    If lngBufferlen > 0 Then        ReDim bytBuffer(lngBufferlen)        lngRc = GetFileVersionInfo(fPN$, 0&, lngBufferlen, bytBuffer(0))        If lngRc <> 0 Then            lngRc = VerQueryValue(bytBuffer(0), "\VarFileInfo\Translation", _                lngVerPointer, lngBufferlen)            If lngRc <> 0 Then                MoveMemory bytBuff(0), lngVerPointer, lngBufferlen                lngHexNumber = bytBuff(2) + bytBuff(3) * &H100 + bytBuff(0) * _                    &H10000 + bytBuff(1) * &H1000000                strLangCharset = Hex(lngHexNumber)                Do While Len(strLangCharset) < 8                    strLangCharset = "0" & strLangCharset                Loop                strVersionInfo(0) = "CompanyName"                strVersionInfo(1) = "FileDescription"                strVersionInfo(2) = "FileVersion"                strVersionInfo(3) = "InternalName"                strVersionInfo(4) = "LegalCopyright"                strVersionInfo(5) = "OriginalFileName"                strVersionInfo(6) = "[s:9]roductName"                strVersionInfo(7) = "[s:9]roductVersion"                strVersionInfo(8) = "Comments"                strVersionInfo(9) = "LegalTrademarks"                strVersionInfo(10) = "[s:9]rivateBuild"                strVersionInfo(11) = "SpecialBuild"                For i = 0 To 11                    strBuffer = String$(255, 0)                    strTemp = "\StringFileInfo\" & strLangCharset & "\" & _                        strVersionInfo(i)                    lngRc = VerQueryValue(bytBuffer(0), strTemp, lngVerPointer, _                        lngBufferlen)                    If lngRc <> 0 Then                        lstrcpy strBuffer, lngVerPointer                        strBuffer = Mid$(strBuffer, 1, InStr(strBuffer, Chr(0)) - 1)                        strVersionInfo(i) = strBuffer                    Else                        strVersionInfo(i) = ""                    End If                Next i            End If        End If    End If    For i = 0 To 11        If Trim(strVersionInfo(i)) = "" Then strVersionInfo(i) = ""    Next i    With oFP        .CompanyName = strVersionInfo(0)        .FileDescription = strVersionInfo(1)        .FileVersion = strVersionInfo(2)        .InternalName = strVersionInfo(3)        .LegalCopyright = strVersionInfo(4)        .OrigionalFileName = strVersionInfo(5)        .ProductName = strVersionInfo(6)        .ProductVersion = strVersionInfo(7)        .Comments = strVersionInfo(8)        .LegalTradeMarks = strVersionInfo(9)        .PrivateBuild = strVersionInfo(10)        .SpecialBuild = strVersionInfo(11)    End WithEnd Function
Private Function GetShortPath(ByVal strFileName As String) As String    Dim lngRet As Long    GetShortPath = String$(MAX_PATH, vbNullChar)    lngRet = GetShortPathNameA(strFileName, GetShortPath, MAX_PATH)    If Not lngRet = 0 Then GetShortPath = Left$(GetShortPath, lngRet)End Function
Public Function GetModuleProcessID(lvwProc As ListView, _    ItemProcID As Integer, lvwModule As ListView, ilsModule As ImageList) As Long    On Error Resume Next    Dim ExePath As String    Dim uProcess As MODULEENTRY32    Dim hSnapShot As Long    Dim hPID As Long    Dim lMod As Long    Dim intLVW As Integer    Dim i As Integer    Dim lvwItem As ListItem    Dim hVer As VERHEADER    hPID = lvwProc.SelectedItem.SubItems(ItemProcID)    hSnapShot = CreateToolhelp32Snapshot(TH32CS_SNAPMODULE, hPID)    uProcess.dwSize = Len(uProcess)    lMod = Module32First(hSnapShot, uProcess)    lvwModule.ListItems.Clear    ilsModule.ListImages.Clear    i = 0    Do While lMod        i = i + 1        ExePath = StripNulls(uProcess.szExePath)        GetVerHeader ExePath, hVer        ilsModule.ListImages.Add i, , GetIco.Icon(ExePath, SmallIcon)        Set lvwItem = lvwModule.ListItems.Add(, , GetLongPath(ExePath), , i)        With lvwItem            .SubItems(1) = hVer.FileDescription            .SubItems(2) = GetPathType(ExePath)            .SubItems(3) = hVer.FileVersion        End With        lMod = Module32Next(hSnapShot, uProcess)    Loop    Call CloseHandle(hSnapShot)    For intLVW = 1 To lvwModule.ColumnHeaders.Count        LV_AutoSizeColumn lvwModule, lvwModule.ColumnHeaders.Item(intLVW)    Next intLVWEnd Function
Sub ScanProcess(showMode As Boolean)    On Error Resume Next    Dim ExePath As String    Dim hProcSnap As Long, hModuleSnap As Long, _        lProc As Long    Dim uProcess As PROCESSENTRY32, _        uModule As MODULEENTRY32    Dim hPID As Long, hExitCode As Long    ExePath = String$(128, Chr$(0))    hProcSnap = CreateToolhelp32Snapshot(TH32CS_SNAPALL, 0&)    uProcess.dwSize = Len(uProcess)    lProc = Process32First(hProcSnap, uProcess)    Do While lProc        If uProcess.th32ProcessID <> 0 Then            hModuleSnap = CreateToolhelp32Snapshot(TH32CS_SNAPALL, _                uProcess.th32ProcessID)            uModule.dwSize = Len(uModule)            Module32First hModuleSnap, uModule            If hModuleSnap > 0 Then                DoEvents                Sleep 10                ExePath = StripNulls(uModule.szExePath)                If showMode = True Then                    frmMain.lblScan.Caption = GetLongPath(ExePath)                    nMemory = nMemory + 1                End If                If IsVirus(ExePath) Then                    hPID = OpenProcess(1&, -1&, uProcess.th32ProcessID)                    hExitCode = TerminateProcess(hPID, 0&)                    Call CloseHandle(hPID)                End If            End If        End If        lProc = Process32Next(hProcSnap, uProcess)    Loop    Call CloseHandle(hProcSnap)End Sub
Public Function GetAppID() As Long    GetAppID = GetCurrentProcessIdEnd Function
Public Sub TerminateVirusProcess(strFileName As String)    On Error Resume Next    Dim ExePath As String    Dim hProcSnap As Long, hModuleSnap As Long, _        lProc As Long    Dim uProcess As PROCESSENTRY32, _        uModule As MODULEENTRY32    Dim hPID As Long, hExitCode As Long    ExePath = String$(128, Chr$(0))    hProcSnap = CreateToolhelp32Snapshot(TH32CS_SNAPALL, 0&)    uProcess.dwSize = Len(uProcess)    lProc = Process32First(hProcSnap, uProcess)    Do While lProc        If uProcess.th32ProcessID <> 0 Then            hModuleSnap = CreateToolhelp32Snapshot(TH32CS_SNAPALL, _                uProcess.th32ProcessID)            uModule.dwSize = Len(uModule)            Module32First hModuleSnap, uModule            If hModuleSnap > 0 Then                ExePath = StripNulls(uModule.szExePath)                If ExePath = strFileName Then                    hPID = OpenProcess(1&, -1&, uProcess.th32ProcessID)                    hExitCode = TerminateProcess(hPID, 0&)                    Call CloseHandle(hPID)                End If            End If        End If        lProc = Process32Next(hProcSnap, uProcess)    Loop    Call CloseHandle(hProcSnap)End Sub
Option Explicit
Private Declare Function RegCreateKey Lib _    "advapi32.dll" Alias "RegCreateKeyA" ( _    ByVal hKey As Long, _    ByVal lpSubKey As String, _    phkResult As Long) As LongPrivate Declare Function RegSetValueEx Lib _    "advapi32.dll" Alias "RegSetValueExA" ( _    ByVal hKey As Long, _    ByVal lpValueName As String, _    ByVal Reserved As Long, _    ByVal dwType As Long, _    lpData As Any, _    ByVal cbData As Long) As LongPrivate Declare Function RegOpenKey Lib _    "advapi32.dll" Alias "RegOpenKeyA" ( _    ByVal hKey As Long, _    ByVal lpSubKey As String, _    phkResult As Long) As LongPrivate Declare Function RegDeleteValue Lib _    "advapi32.dll" Alias "RegDeleteValueA" ( _    ByVal hKey As Long, _    ByVal lpValueName As String) As LongPrivate Declare Function RegOpenKeyEx Lib _    "advapi32.dll" Alias "RegOpenKeyExA" ( _    ByVal hKey As Long, _    ByVal lpSubKey As String, _    ByVal ulOptions As Long, _    ByVal samDesired As Long, _    phkResult As Long) As LongPrivate Declare Function RegCloseKey Lib _    "advapi32.dll" ( _    ByVal hKey As Long) As LongPrivate Declare Function RegQueryValueEx Lib _    "advapi32.dll" Alias "RegQueryValueExA" ( _    ByVal hKey As Long, _    ByVal lpValueName As String, _    ByVal lpReserved As Long, _    lpType As Long, _    ByVal lpData As String, _    lpcbData As Long) As LongPrivate Declare Function RegQueryValueExA Lib _    "advapi32.dll" ( _    ByVal hKey As Long, _    ByVal lpValueName As String, _    ByVal lpReserved As Long, _    lpType As Long, _    ByRef lpData As Long, _    lpcbData As Long) As Long
Private Const ERROR_SUCCESS = 0&[s:9]rivate Const REG_SZ = 1&[s:9]rivate Const REG_DWORD = 4&[s:9]rivate Const KEY_QUERY_VALUE = &H1&[s:9]rivate Const KEY_SET_VALUE = &H2&[s:9]rivate Const KEY_ENUMERATE_SUB_KEYS = &H8&[s:9]rivate Const KEY_NOTIFY = &H10&[s:9]rivate Const READ_CONTROL = &H20000Private Const STANDARD_RIGHTS_READ = READ_CONTROLPrivate Const KEY_READ = STANDARD_RIGHTS_READ Or _    KEY_QUERY_VALUE Or KEY_ENUMERATE_SUB_KEYS Or KEY_NOTIFY
Dim MainKeyHandle As REGDim rtn As Long, lBuffer As Long, sBuffer As StringDim lBufferSize As LongDim lDataSize As LongDim lKey As Long
Public Enum REG    HKEY_CURRENT_USER = &H80000001    HKEY_CLASSES_ROOT = &H80000000    HKEY_CURRENT_CONFIG = &H80000005    HKEY_LOCAL_MACHINE = &H80000002    HKEY_USERS = &H80000003End Enum
Public Const SMP_KEY As String = "Software\Simple Machine Protect"
Public Function CreateRegistryKey(hKey As REG, sSubKey As String)    Dim lReg As Long    RegCreateKey hKey, sSubKey, lReg    RegCloseKey lRegEnd Function
Public Function GetDWORDValue(hKey As REG, SubKey As String, Entry As String)    Dim ret As Long    rtn = RegOpenKeyEx(hKey, SubKey, 0, KEY_READ, ret)    If rtn = ERROR_SUCCESS Then        rtn = RegQueryValueExA(ret, Entry, 0, REG_DWORD, lBuffer, 4)        If rtn = ERROR_SUCCESS Then            rtn = RegCloseKey(ret)            GetDWORDValue = lBuffer        Else            GetDWORDValue = "Error"        End If    Else        GetDWORDValue = "Error"    End IfEnd Function
Public Function GetSTRINGValue(hKey As REG, SubKey As String, Entry As String)    Dim ret As Long    rtn = RegOpenKeyEx(hKey, SubKey, 0, KEY_READ, ret)    If rtn = ERROR_SUCCESS Then        sBuffer = Space(255)        lBufferSize = Len(sBuffer)        rtn = RegQueryValueEx(ret, Entry, 0, REG_SZ, sBuffer, lBufferSize)        If rtn = ERROR_SUCCESS Then            rtn = RegCloseKey(ret)            sBuffer = Trim(sBuffer)            GetSTRINGValue = Left(sBuffer, Len(sBuffer) - 1)        Else            GetSTRINGValue = "Error"        End If    Else        GetSTRINGValue = "Error"    End IfEnd Function
Public Function CreateDwordValue(hKey As REG, SubKey As String, _    strValueName As String, dwordData As Long) As Long    Dim ret As Long    RegCreateKey hKey, SubKey, ret    CreateDwordValue = RegSetValueEx(ret, strValueName, 0, REG_DWORD, dwordData, 4)    RegCloseKey retEnd Function
Public Function CreateStringValue(hKey As REG, SubKey As String, _    strValueName As String, strdata As String) As Long    Dim ret As Long    RegCreateKey hKey, SubKey, ret    CreateStringValue = RegSetValueEx(ret, strValueName, 0, _        REG_SZ, ByVal strdata, Len(strdata))    RegCloseKey retEnd Function
Public Function DeleteValue(hKey As REG, SubKey As String, lpValName As String) As Long    Dim ret As Long    RegOpenKey hKey, SubKey, ret    DeleteValue = RegDeleteValue(ret, lpValName)    RegCloseKey retEnd Function
Option Explicit
Public Declare Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" (ByVal hwnd As Long, ByVal lpOperation As String, ByVal lpFile As String, ByVal lpParameters As String, ByVal lpDirectory As String, ByVal nShowCmd As Long) As LongPublic Enum ShowStyle    vbHide    vbMaximizedFocus    vbMinimizedFocus    vbMinimizedNoFocus    vbNormalFocus    vbNormalNoFocusEnd Enum
Public Function OpenFile(ByVal OpenName As String, Optional ByVal InitDir As String = vbNullString, Optional ByVal msgStyle As ShowStyle = vbNormalFocus)    ShellExecute 0&, vbNullString, OpenName, vbNullString, InitDir, msgStyleEnd Function
类模块代码下次送上
+50
文字介绍太少,不敢下载,不过还是支持。
qg2010
2012/04/08
莫非绑了马。。。
+30
孤独的酒精灯
2012/04/13
敢不敢注释一下……
asdw_15951作者
14年9个月前IP:未同步
384995
求表扬啊……
asdw_15951作者
14年9个月前IP:未同步
385415
类模块代码:
Private Declare Function CallWindowProc Lib "user32" Alias "CallWindowProcA" (ByVal lpPrevWndFunc As Long, ByVal hwnd As Long, ByVal Msg As Long, ByVal wParam As Long, ByVal lParam As Long) As Long  'Variable Declarations Private m_CRC32Asmbl() As Byte Private m_CRC32Table(0 To 255) As Long  '//--Procedures--//  Function FileChecksum(File As String) As String 'Returns the CRC32 checksum value of a specified file.     'Make sure the file isn't empty or invalid to avoid errors later     If Len(Dir$(File)) = 0 Then         Exit Function     End If          On Error GoTo Err_Handler          Dim Arr() As Byte     Dim f As Integer          f = FreeFile 'Get any available file number for use          Open File For Binary Access Read As f         'Redimensionized array according to length of file         ReDim Arr(0 To LOF(f) - 1) As Byte         Get #f, , Arr() 'Get file contents     Close #f          'Calculate CRC32 checksum     FileChecksum = Hex$(CalculateBytes(Arr))      Err_Handler: End Function  Function StringChecksum(Str As String) As String 'Returns the CRC32 checksum value of the specified string.     'Make sure the string has contents before execution to avoid errors     If Not Len(Str) = 0 Then         'Convert into an array of bytes         StringChecksum = Hex$(CalculateBytes(StrConv(Str, vbFromUnicode)))     End If End Function  '[s:9]rivate Function Private Function CalculateBytes(Arr() As Byte) As Long     Dim CRC32 As Long     CRC32 = &HFFFFFFFF 'CRC32 must have this default value          'Suppress error if array isn't dimensionized     On Local Error GoTo Err_Handler          Dim i As Long     i = UBound(Arr) - LBound(Arr) + 1 '[s:9]recalculate size of array          'Execute the precompiled assembler code to calculate and generate CRC32 checksum value     Call CallWindowProc(VarPtr(m_CRC32Asmbl(0)), VarPtr(CRC32), VarPtr(Arr(LBound(Arr))), VarPtr(m_CRC32Table(0)), i)      Err_Handler:     CalculateBytes = (Not CRC32) 'Return CRC32 value End Function  'Class Procedures Private Sub Class_Initialize()     Dim i As Long '    Dim j As Long      '    Dim lCRC32 As Long      '    Const lXOR32 As Long = &HEDB88320      '    For i = 0 To 255 '        lCRC32 = i ' '        For j = 8 To 1 Step -1 '            If (lCRC32 And 1) Then '                lCRC32 = ((lCRC32 And &HFFFFFFFE) \\ 2&) And &H7FFFFFFF '                lCRC32 = lCRC32 Xor lxor32 '            Else '                lCRC32 = ((lCRC32 And &HFFFFFFFE) \\ 2&) And &H7FFFFFFF '            End If '        Next j ' '        m_CRC32Table(i) = lCRC32 '    Next i          m_CRC32Table(0) = &H0     m_CRC32Table(1) = &H77073096     m_CRC32Table(2) = &HEE0E612C     m_CRC32Table(3) = &H990951BA     m_CRC32Table(4) = &H76DC419     m_CRC32Table(5) = &H706AF48F     m_CRC32Table(6) = &HE963A535     m_CRC32Table(7) = &H9E6495A3     m_CRC32Table(8) = &HEDB8832     m_CRC32Table(9) = &H79DCB8A4     m_CRC32Table(10) = &HE0D5E91E     m_CRC32Table(11) = &H97D2D988     m_CRC32Table(12) = &H9B64C2B     m_CRC32Table(13) = &H7EB17CBD     m_CRC32Table(14) = &HE7B82D07     m_CRC32Table(15) = &H90BF1D91     m_CRC32Table(16) = &H1DB71064     m_CRC32Table(17) = &H6AB020F2     m_CRC32Table(18) = &HF3B97148     m_CRC32Table(19) = &H84BE41DE     m_CRC32Table(20) = &H1ADAD47D     m_CRC32Table(21) = &H6DDDE4EB     m_CRC32Table(22) = &HF4D4B551     m_CRC32Table(23) = &H83D385C7     m_CRC32Table(24) = &H136C9856     m_CRC32Table(25) = &H646BA8C0     m_CRC32Table(26) = &HFD62F97A     m_CRC32Table(27) = &H8A65C9EC     m_CRC32Table(28) = &H14015C4F     m_CRC32Table(29) = &H63066CD9     m_CRC32Table(30) = &HFA0F3D63     m_CRC32Table(31) = &H8D080DF5     m_CRC32Table(32) = &H3B6E20C8     m_CRC32Table(33) = &H4C69105E     m_CRC32Table(34) = &HD56041E4     m_CRC32Table(35) = &HA2677172     m_CRC32Table(36) = &H3C03E4D1     m_CRC32Table(37) = &H4B04D447     m_CRC32Table(38) = &HD20D85FD     m_CRC32Table(39) = &HA50AB56B     m_CRC32Table(40) = &H35B5A8FA     m_CRC32Table(41) = &H42B2986C     m_CRC32Table(42) = &HDBBBC9D6     m_CRC32Table(43) = &HACBCF940     m_CRC32Table(44) = &H32D86CE3     m_CRC32Table(45) = &H45DF5C75     m_CRC32Table(46) = &HDCD60DCF     m_CRC32Table(47) = &HABD13D59     m_CRC32Table(48) = &H26D930AC     m_CRC32Table(49) = &H51DE003A     m_CRC32Table(50) = &HC8D75180     m_CRC32Table(51) = &HBFD06116     m_CRC32Table(52) = &H21B4F4B5     m_CRC32Table(53) = &H56B3C423     m_CRC32Table(54) = &HCFBA9599     m_CRC32Table(55) = &HB8BDA50F     m_CRC32Table(56) = &H2802B89E     m_CRC32Table(57) = &H5F058808     m_CRC32Table(58) = &HC60CD9B2     m_CRC32Table(59) = &HB10BE924     m_CRC32Table(60) = &H2F6F7C87     m_CRC32Table(61) = &H58684C11     m_CRC32Table(62) = &HC1611DAB     m_CRC32Table(63) = &HB6662D3D     m_CRC32Table(64) = &H76DC4190     m_CRC32Table(65) = &H1DB7106     m_CRC32Table(66) = &H98D220BC     m_CRC32Table(67) = &HEFD5102A     m_CRC32Table(68) = &H71B18589     m_CRC32Table(69) = &H6B6B51F     m_CRC32Table(70) = &H9FBFE4A5     m_CRC32Table(71) = &HE8B8D433     m_CRC32Table(72) = &H7807C9A2     m_CRC32Table(73) = &HF00F934     m_CRC32Table(74) = &H9609A88E     m_CRC32Table(75) = &HE10E9818     m_CRC32Table(76) = &H7F6A0DBB     m_CRC32Table(77) = &H86D3D2D     m_CRC32Table(78) = &H91646C97     m_CRC32Table(79) = &HE6635C01     m_CRC32Table(80) = &H6B6B51F4     m_CRC32Table(81) = &H1C6C6162     m_CRC32Table(82) = &H856530D8     m_CRC32Table(83) = &HF262004E     m_CRC32Table(84) = &H6C0695ED     m_CRC32Table(85) = &H1B01A57B     m_CRC32Table(86) = &H8208F4C1     m_CRC32Table(87) = &HF50FC457     m_CRC32Table(88) = &H65B0D9C6     m_CRC32Table(89) = &H12B7E950     m_CRC32Table(90) = &H8BBEB8EA     m_CRC32Table(91) = &HFCB9887C     m_CRC32Table(92) = &H62DD1DDF     m_CRC32Table(93) = &H15DA2D49     m_CRC32Table(94) = &H8CD37CF3     m_CRC32Table(95) = &HFBD44C65     m_CRC32Table(96) = &H4DB26158     m_CRC32Table(97) = &H3AB551CE     m_CRC32Table(98) = &HA3BC0074     m_CRC32Table(99) = &HD4BB30E2     m_CRC32Table(100) = &H4ADFA541     m_CRC32Table(101) = &H3DD895D7     m_CRC32Table(102) = &HA4D1C46D     m_CRC32Table(103) = &HD3D6F4FB     m_CRC32Table(104) = &H4369E96A     m_CRC32Table(105) = &H346ED9FC     m_CRC32Table(106) = &HAD678846     m_CRC32Table(107) = &HDA60B8D0     m_CRC32Table(108) = &H44042D73     m_CRC32Table(109) = &H33031DE5     m_CRC32Table(110) = &HAA0A4C5F     m_CRC32Table(111) = &HDD0D7CC9     m_CRC32Table(112) = &H5005713C     m_CRC32Table(113) = &H270241AA     m_CRC32Table(114) = &HBE0B1010     m_CRC32Table(115) = &HC90C2086     m_CRC32Table(116) = &H5768B525     m_CRC32Table(117) = &H206F85B3     m_CRC32Table(118) = &HB966D409     m_CRC32Table(119) = &HCE61E49F     m_CRC32Table(120) = &H5EDEF90E     m_CRC32Table(121) = &H29D9C998     m_CRC32Table(122) = &HB0D09822     m_CRC32Table(123) = &HC7D7A8B4     m_CRC32Table(124) = &H59B33D17     m_CRC32Table(125) = &H2EB40D81     m_CRC32Table(126) = &HB7BD5C3B     m_CRC32Table(127) = &HC0BA6CAD     m_CRC32Table(128) = &HEDB88320     m_CRC32Table(129) = &H9ABFB3B6     m_CRC32Table(130) = &H3B6E20C     m_CRC32Table(131) = &H74B1D29A     m_CRC32Table(132) = &HEAD54739     m_CRC32Table(133) = &H9DD277AF     m_CRC32Table(134) = &H4DB2615     m_CRC32Table(135) = &H73DC1683     m_CRC32Table(136) = &HE3630B12     m_CRC32Table(137) = &H94643B84     m_CRC32Table(138) = &HD6D6A3E     m_CRC32Table(139) = &H7A6A5AA8     m_CRC32Table(140) = &HE40ECF0B     m_CRC32Table(141) = &H9309FF9D     m_CRC32Table(142) = &HA00AE27     m_CRC32Table(143) = &H7D079EB1     m_CRC32Table(144) = &HF00F9344     m_CRC32Table(145) = &H8708A3D2     m_CRC32Table(146) = &H1E01F268     m_CRC32Table(147) = &H6906C2FE     m_CRC32Table(148) = &HF762575D     m_CRC32Table(149) = &H806567CB     m_CRC32Table(150) = &H196C3671     m_CRC32Table(151) = &H6E6B06E7     m_CRC32Table(152) = &HFED41B76     m_CRC32Table(153) = &H89D32BE0     m_CRC32Table(154) = &H10DA7A5A     m_CRC32Table(155) = &H67DD4ACC     m_CRC32Table(156) = &HF9B9DF6F     m_CRC32Table(157) = &H8EBEEFF9     m_CRC32Table(158) = &H17B7BE43     m_CRC32Table(159) = &H60B08ED5     m_CRC32Table(160) = &HD6D6A3E8     m_CRC32Table(161) = &HA1D1937E     m_CRC32Table(162) = &H38D8C2C4     m_CRC32Table(163) = &H4FDFF252     m_CRC32Table(164) = &HD1BB67F1     m_CRC32Table(165) = &HA6BC5767     m_CRC32Table(166) = &H3FB506DD     m_CRC32Table(167) = &H48B2364B     m_CRC32Table(168) = &HD80D2BDA     m_CRC32Table(169) = &HAF0A1B4C     m_CRC32Table(170) = &H36034AF6     m_CRC32Table(171) = &H41047A60     m_CRC32Table(172) = &HDF60EFC3     m_CRC32Table(173) = &HA867DF55     m_CRC32Table(174) = &H316E8EEF     m_CRC32Table(175) = &H4669BE79     m_CRC32Table(176) = &HCB61B38C     m_CRC32Table(177) = &HBC66831A     m_CRC32Table(178) = &H256FD2A0     m_CRC32Table(179) = &H5268E236     m_CRC32Table(180) = &HCC0C7795     m_CRC32Table(181) = &HBB0B4703     m_CRC32Table(182) = &H220216B9     m_CRC32Table(183) = &H5505262F     m_CRC32Table(184) = &HC5BA3BBE     m_CRC32Table(185) = &HB2BD0B28     m_CRC32Table(186) = &H2BB45A92     m_CRC32Table(187) = &H5CB36A04     m_CRC32Table(188) = &HC2D7FFA7     m_CRC32Table(189) = &HB5D0CF31     m_CRC32Table(190) = &H2CD99E8B     m_CRC32Table(191) = &H5BDEAE1D     m_CRC32Table(192) = &H9B64C2B0     m_CRC32Table(193) = &HEC63F226     m_CRC32Table(194) = &H756AA39C     m_CRC32Table(195) = &H26D930A     m_CRC32Table(196) = &H9C0906A9     m_CRC32Table(197) = &HEB0E363F     m_CRC32Table(198) = &H72076785     m_CRC32Table(199) = &H5005713     m_CRC32Table(200) = &H95BF4A82     m_CRC32Table(201) = &HE2B87A14     m_CRC32Table(202) = &H7BB12BAE     m_CRC32Table(203) = &HCB61B38     m_CRC32Table(204) = &H92D28E9B     m_CRC32Table(205) = &HE5D5BE0D     m_CRC32Table(206) = &H7CDCEFB7     m_CRC32Table(207) = &HBDBDF21     m_CRC32Table(208) = &H86D3D2D4     m_CRC32Table(209) = &HF1D4E242     m_CRC32Table(210) = &H68DDB3F8     m_CRC32Table(211) = &H1FDA836E     m_CRC32Table(212) = &H81BE16CD     m_CRC32Table(213) = &HF6B9265B     m_CRC32Table(214) = &H6FB077E1     m_CRC32Table(215) = &H18B74777     m_CRC32Table(216) = &H88085AE6     m_CRC32Table(217) = &HFF0F6A70     m_CRC32Table(218) = &H66063BCA     m_CRC32Table(219) = &H11010B5C     m_CRC32Table(220) = &H8F659EFF     m_CRC32Table(221) = &HF862AE69     m_CRC32Table(222) = &H616BFFD3     m_CRC32Table(223) = &H166CCF45     m_CRC32Table(224) = &HA00AE278     m_CRC32Table(225) = &HD70DD2EE     m_CRC32Table(226) = &H4E048354     m_CRC32Table(227) = &H3903B3C2     m_CRC32Table(228) = &HA7672661     m_CRC32Table(229) = &HD06016F7     m_CRC32Table(230) = &H4969474D     m_CRC32Table(231) = &H3E6E77DB     m_CRC32Table(232) = &HAED16A4A     m_CRC32Table(233) = &HD9D65ADC     m_CRC32Table(234) = &H40DF0B66     m_CRC32Table(235) = &H37D83BF0     m_CRC32Table(236) = &HA9BCAE53     m_CRC32Table(237) = &HDEBB9EC5     m_CRC32Table(238) = &H47B2CF7F     m_CRC32Table(239) = &H30B5FFE9     m_CRC32Table(240) = &HBDBDF21C     m_CRC32Table(241) = &HCABAC28A     m_CRC32Table(242) = &H53B39330     m_CRC32Table(243) = &H24B4A3A6     m_CRC32Table(244) = &HBAD03605     m_CRC32Table(245) = &HCDD70693     m_CRC32Table(246) = &H54DE5729     m_CRC32Table(247) = &H23D967BF     m_CRC32Table(248) = &HB3667A2E     m_CRC32Table(249) = &HC4614AB8     m_CRC32Table(250) = &H5D681B02     m_CRC32Table(251) = &H2A6F2B94     m_CRC32Table(252) = &HB40BBE37     m_CRC32Table(253) = &HC30C8EA1     m_CRC32Table(254) = &H5A05DF1B     m_CRC32Table(255) = &H2D02EF8D          Const ASM As String = "5589E557565053518B45088B008B750C8B7D108B4D1431DB8A1E30C3C1E80833049F464975F28B4D088901595B585E5F89EC5DC21000"      '   Decoded ASM source from HIEW 6.86 (Hacker's View) ' '   55          PUSH    BP '   89E5        MOV     BP,SP '   57          PUSH    DI '   56          PUSH    SI '   50          PUSH    AX '   53          PUSH    BX '   51          PUSH    CX '   8B4508      MOV     AX,DI[08] '   8B00        MOV     AX,BX[SI] '   8B750C      MOV     SI,DI[0C] '   8B7D10      MOV     DI,DI[10] '   8B4D14      MOV     CX,DI[14] '   31DB        XOR     BX,BX '   8A1E30C3    MOV     BL,0C330 '   C1E808      SHR     AX,008    <-. '   3304        XOR     AX,[SI]     | '   9F          LAHF                | '   46          INC     SI          | '   49          DEC     CX          | '   75F2        JNE     000000018  -' '   8B4D08      MOV     CX,DI[08] '   8901        MOV     BX[DI],AX '   59          POP     CX '   5B          POP     BX '   58          POP     AX '   5E          POP     SI '   5F          POP     DI '   89EC        MOV     SP,BP '   5D          POP     BP '   C21000      RETN    00010          ReDim m_CRC32Asmbl(0 To Len(ASM) \\ 2 - 1) 'Initialize CRC32 precompiled assembly code          For i = 1 To Len(ASM) Step 2         m_CRC32Asmbl(i \\ 2) = Val("&H" & Mid$(ASM, i, 2))     Next i End Sub  'Created by Noel A. Dacara | Copyright ?2003-2005 Davao City, Philippines
Option Explicit
'Author         : Noel A. Dacara (noeldacara@yahoo.com)'Filename       : Get File Icon.cls (cFileIcon Class Module)'Description    : Get icon(s) of an existing file'Date           : Tuesday, January 07, 2003, 10:12 AM'Last Update    : Friday, November 25, 2005, 12:28 AM
'You can freely use and distribute this class or upload these codes on any site'provided that the original credits are kept unmodified.
'Keep note that :'If File property is not set, the current directory will automatically be used by API.
'Credits goes to:'Makers of the great Win32 Programmer's Reference, don't know who you are but thanks.'Christoph von Wittich (Christoph@ActiveVB.de), author of ApiViewer 2004 for the APIs
'Modified API DeclarationPrivate Declare Function SHGetFileInfo Lib "shell32.dll" Alias "SHGetFileInfoA" (ByVal pszPath As String, ByVal dwFileAttributes As Long, ByRef psfi As SHFILEINFO, ByVal cbFileInfo As Long, ByVal uFlags As ESHGetFileInfoFlagConstants) As LongPrivate Declare Sub OleCreatePictureIndirect Lib "oleaut32.dll" (ByRef lpPictDesc As PictDesc, ByRef riid As Guid, ByVal fOwn As Long, ByRef lplpvObj As IPictureDisp)
'API ConstantsPrivate Const ERRORAPI As Long = 0Private Const MAX_PATH As Long = 260
'API TypesPrivate Type Guid    Data1           As Long    Data2           As Integer    Data3           As Integer    Data4(0 To 7)   As ByteEnd Type
Private Type PictDesc    cbSizeofStruct  As Long    picType         As Long    hImage          As Long    xExt            As Long    yExt            As LongEnd Type
Private Type SHFILEINFO    hIcon           As Long ' : icon    iIcon           As Long ' : icondex    dwAttributes    As Long ' : SFGAO_ flags    szDisplayName   As String * MAX_PATH ' : display name (or path)    szTypeName      As String * 80 ' : type nameEnd Type
'User-Defined API EnumPrivate Enum ESHGetFileInfoFlagConstants    SHGFI_ATTRIBUTES = &H800        'get file attributes    SHGFI_DISPLAYNAME = &H200       'get display name    SHGFI_EXETYPE = &H2000          'get exe type    SHGFI_ICON = &H100              'get icon handle and index    SHGFI_LARGEICON = &H0           'get file's large icon    SHGFI_LINKOVERLAY = &H8000      'add link overlay on the icon    SHGFI_OPENICON = &H2            'get file's open icon    SHGFI_SELECTED = &H10000        'blend icon with the system highlight color    SHGFI_SHELLICONSIZE = &H4       'get shell-sized icon    SHGFI_SMALLICON = &H1           'get file's small icon    SHGFI_SYSICONINDEX = &H4000     'get icon index from system image list    SHGFI_TYPENAME = &H400          'get file type description    SHGFI_USEFILEATTRIBUTES = &H10  'use dwFileAttributes parameterEnd Enum
Enum EFileIconTypeConstants    LargeIcon = 0    SmallIcon = 1End Enum
Enum EFileExeTypeConstants    MSDosApp = 2        'MS-DOS .EXE, .COM or .BAT file    NonExecutable = 0   'Nonexecutable file or an error condition    Win32Console = 3    'Win32 console application    WindowsApp = 1      'Windows applicationEnd Enum
'Variable DeclarationsPrivate m_File      As StringPrivate m_Handle    As LongPrivate m_IconType  As EFileIconTypeConstantsPrivate m_OpenState As BooleanPrivate m_Overlay   As BooleanPrivate m_Selected  As Boolean
Property Get DisplayName(Optional File) As String'Returns the display name of the specified file.    Dim p_Null  As Long    Dim p_Ret   As Long    Dim p_SHFI  As SHFILEINFO        If IsMissing(File) Then        File = m_File    End If        p_Ret = SHGetFileInfo(CStr(File), 0&, p_SHFI, Len(p_SHFI), SHGFI_DISPLAYNAME)        If Not p_Ret = ERRORAPI Then        DisplayName = p_SHFI.szDisplayName                p_Null = InStr(1, DisplayName, vbNullChar)                If p_Null > 0& Then            DisplayName = Left$(DisplayName, p_Null - 1)        End If    End IfEnd Property
Property Get ExeType(Optional File) As EFileExeTypeConstants'Returns the display name of the specified file.    Dim p_Ret   As Long    Dim p_SHFI  As SHFILEINFO        If IsMissing(File) Then        File = m_File    End If        p_Ret = SHGetFileInfo(CStr(File), 0&, p_SHFI, Len(p_SHFI), SHGFI_EXETYPE)        If p_Ret = 0 Then        ExeType = NonExecutable    Else        If HiWord(p_Ret) > 0 Then 'NE 0x00004E45 or PE 0x00005045            ExeType = WindowsApp        Else            Select Case LoWord(p_Ret)                Case 23117 'MZ 0x00004D5A                    ExeType = MSDosApp                Case 17744 '[s:9]E 0x00005045                    ExeType = Win32Console            End Select        End If    End IfEnd Property
Property Get File() As String'Returns/sets the complete file path to be used.    File = m_FileEnd Property
Property Let File(Value As String)    m_File = ValueEnd Property
Property Get Handle() As Long'Returns/sets the icon handle to be used by the IconEx property.    Handle = m_HandleEnd Property
Property Let Handle(Value As Long)    m_Handle = ValueEnd Property
Property Get IconType() As EFileIconTypeConstants'Returns/sets the type of icon to retrieve.    IconType = m_IconTypeEnd Property
Property Let IconType(Value As EFileIconTypeConstants)    m_IconType = ValueEnd Property
Property Get Icon(Optional File, Optional IconType) As IPictureDisp'Returns the icon of the specified file.    If IsMissing(File) Then        File = m_File    End If        If IsMissing(IconType) Then        IconType = m_IconType    End If        Dim p_Flags As ESHGetFileInfoFlagConstants    Dim p_hIcon As Long    Dim p_Ret   As Long    Dim p_SHFI  As SHFILEINFO        If m_IconType = LargeIcon Then        p_Flags = SHGFI_ICON Or SHGFI_LARGEICON    Else        p_Flags = SHGFI_ICON Or SHGFI_SMALLICON    End If        If m_Overlay Then        p_Flags = p_Flags Or SHGFI_LINKOVERLAY    End If        If m_Selected Then        p_Flags = p_Flags Or SHGFI_SELECTED    Else        p_Flags = p_Flags And Not SHGFI_SELECTED    End If        If m_OpenState Then        p_Flags = p_Flags Or SHGFI_OPENICON    Else        p_Flags = p_Flags And Not SHGFI_OPENICON    End If        p_Ret = SHGetFileInfo(CStr(File), 0&, p_SHFI, Len(p_SHFI), p_Flags)        If Not p_Ret = ERRORAPI Then        p_hIcon = p_SHFI.hIcon                If Not p_hIcon = 0& Then            Set Icon = IconEx(p_hIcon)        End If    End IfEnd Property
Property Get IconEx(Optional hIcon As Long) As IPictureDisp'Returns the file's icon using the specified icon handle.    If hIcon = 0& Then        hIcon = m_Handle                If hIcon = 0& Then            Exit Property        End If    End If        Dim p_Picture   As IPictureDisp    Dim p_PicDesc   As PictDesc    Dim p_Guid      As Guid        p_PicDesc.cbSizeofStruct = Len(p_PicDesc)    p_PicDesc.picType = vbPicTypeIcon    p_PicDesc.hImage = hIcon        'IPicture GUID {7BF80980-BF32-101A-8BBB-00AA00300CAB}    With p_Guid        .Data1 = &H7BF80980        .Data2 = &HBF32        .Data3 = &H101A        .Data4(0) = &H8B        .Data4(1) = &HBB        .Data4(2) = &H0        .Data4(3) = &HAA        .Data4(4) = &H0        .Data4(5) = &H30        .Data4(6) = &HC        .Data4(7) = &HAB    End With    'From vbAccelerator... (XXXXXXXXXXXXXXXXXXXXXXXXXXXX)        OleCreatePictureIndirect p_PicDesc, p_Guid, True, p_Picture        Set IconEx = p_PictureEnd Property
Property Get LinkOverlay() As Boolean'Returns/sets a value to determine if a linkoverlay icon is displayed on the icon.    LinkOverlay = m_OverlayEnd Property
Property Let LinkOverlay(Value As Boolean)    m_Overlay = ValueEnd Property
Property Get OpenState() As Boolean'Returns/sets a value to determine if the icon will be in open state. (Ex. Folders)    OpenState = m_OpenStateEnd Property
Property Let OpenState(Value As Boolean)    m_OpenState = ValueEnd Property
Property Get Selected() As Boolean'Returns/sets a value to determine if the icon is in selected state.    Selected = m_SelectedEnd Property
Property Let Selected(Value As Boolean)    m_Selected = ValueEnd Property
Property Get TypeName(Optional File) As String'Returns the type name of the specified file.    Dim p_Null  As Long    Dim p_Ret   As Long    Dim p_SHFI  As SHFILEINFO        If IsMissing(File) Then        File = m_File    End If        p_Ret = SHGetFileInfo(CStr(File), 0&, p_SHFI, Len(p_SHFI), SHGFI_TYPENAME)        If Not p_Ret = ERRORAPI Then        TypeName = p_SHFI.szTypeName                p_Null = InStr(1, TypeName, vbNullChar)                If p_Null > 0& Then            TypeName = Left$(TypeName, p_Null - 1)        End If    End IfEnd Property
'[s:9]rivate propertiesPrivate Property Get HiWord(DWord As Long) As Long    HiWord = (DWord And &HFFFF0000) \\ &H10000End Property
Private Property Get LoWord(DWord As Long) As Long    If DWord And &H8000& Then        LoWord = DWord Or &HFFFF0000    Else        LoWord = DWord And &HFFFF&    End IfEnd Property
+200
leeqingyang
2012/04/10
高质量发帖
asdw_15951作者
14年9个月前IP:未同步
385661
回 11楼(hefanghua) 的帖子
OK,我现在正在写解说稿
asdw_15951作者
14年9个月前IP:未同步
385662
关于PE系统的调试现在暂时失败了……正在积极调试中
asdw_15951作者
14年9个月前IP:未同步
386438
吼吼……老代码了
asdw_15951作者
14年9个月前IP:未同步
387561
19楼
回 18楼(sndnvaps) 的帖子
呵呵,谢谢指点……动态数据库比较不稳定……先调试一下啊
asdw_15951作者
14年8个月前IP:未同步
388753
21楼
哦……不错……
我是学C的,但老林就是专门做B的……
就是杀一些简单的 MS-DO[.COM(标准蠕虫)而已啊
asdw_15951作者
14年4个月前IP:未同步
443032
26楼
回 25楼(wzy41718682) 的帖子
引用楼主asdw_15951于2012-04-08 21:27发表的 自制杀毒软件一份
自制的软件,用的是开源代码
请勿挖坟!再者,你看的很清楚吗?顶楼已经明确声明“使用的是开源代码”!!
asdw_15951作者
14年4个月前IP:未同步
443073
27楼
回 22楼(phpskycn) 的帖子
新软正在调试,这个软已经荒废了。新软全面兼容Win2000及以上系统。并且全新加入了又龙腾工作室研发的新内核,WinPE无压力!
acmilan
2012/08/23
希望调试一切顺利
