t70949
【设计艺术】如何把一名婴儿变成酒壶
2015/04/18
IP:北京
首先声明一下,这个点子本身是个老外的点子,不是原创的。我做的仅仅是把外文翻译成中文,以阅读性、原作心理、操作性三者平衡度优先翻译。
本楼上自己完成的作品图,下一楼放上外文原文,方便各位不便爬墙读者。译文的话,发部分预览,借KC导流一下我们现在的线上创客内容吧。
这个作品适合带到人多的公众场合使用。本来老外那里有些公众场合禁止喝酒,他拿这个作为掩护。放在我国,用法可以很好玩,类似“大哥别杀我”这种的。附带一提,因经费问题,另一个成人尺寸大小的没法制作——“啃老酒瓶”,就是老年人体型大小的,在脖子上开口,吸红酒。
这是一枚婴儿,家政月嫂培训用,30块包邮。
背面
解开背后魔术贴,脱掉上衣。
网布里面都是PP棉。
户外旅行用PP胶水囊,2.5升。
吸管
吸嘴外观
为了便宜,买的是挎兜背带。
DZ9A9930.jpg 、
丰刃剪刀
动刀子解剖
开膛破肚的反面
把水囊塞到身体部位
把吸管伸到头部
上大功率交流电手钻,钻头最大口径。
大开脑洞!
脑洞大开!
贯穿!
整理衣服
完成外观,结果是蓝角大王。
亲一个——其实是喝水啦
这就是父爱?!
放大图
(补充:如果地方开两会,乡镇县级的,带过去会让你一夜之间在腾讯上被围观的。不光可以喝酒喝水喝果汁,如果喝豆浆/豆腐脑的话……)
31
kalimov作者
11年8个月前IP:北京
763385
现在放上原文教程
现在放上原文教程。原文链接XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX下一楼是部分译文和译文地址。
Baby flask
by mikeasaurus
Download9 Steps
Collection  I Made it!  Favorite Share
It's so frustrating not being able to enjoy my adult beverage in public. Sporting events, movies, church, all frown on bringing in your own booze. Instead of brown-bagging your beverage at the next bash, why not hide it in plain sight, inside ababy flask!This doll holds a refillable drink bladder that lets you sip from a straw hidden in the top of the head. Everyone loves babies, and you can dismiss any inquisitive investigators by simply saying "Shhh. she's sleeping". This should deter all but the most persistent people.
This project is based off the Cool Baby by Simon Philion, when it failed to get funding I knew I still had to have one. I made a DIY Cool Baby that I named Brandi. Though not insulated it like the genuine article it works well enough for most applications.Here's a short video showing the baby flask in action:
Ready to bust open a baby for delicious science? Let's make!
Step 1: Supplies
To make this baby flask I used:
You'll also need a drill with a large diameter bit, and a sharp knife.
Step 2: Gut baby
Open back of doll and make a small incision in the back, then remove all the batting inside.
Step 3: Measure + cut bladder hose
My bladder was 2 litres and would take up all the room inside the baby carcass. The hose was much too long, so needed to be cut down to more manageable size.I measured how long the hose needed to be, then cut off the excess. The mouth bite was cut from the remaining hose and attached to the new shortened length by pressing it into the barbs, holding it securely in place.
Step 4: Drill baby
To make an opening for the mouth bite we'll need to drill a hole in the doll head. The head is soft and hollow, so this is fairly easy. Drill into the soft baby head meat with a large diameter drill bit.
Step 5: Insert bladder
Insert the empty bladder into the baby cavity and feed the drinking hose up through the neck and into the hollow head. The mouth bite can be pulled through the opening in the head.
Step 6: Fill baby flask
With the bladder installed you can fill your baby flask with your favourite beverage.
Step 7: Seal baby
Seal up the velcro backing of the baby clothes and you're all set to bring your baby to the next sporting event.
Step 8: Put in carrier
To really make this believable you'll need a way to carry your baby flask inconspicuously.Place your baby in a baby carrier so you can take small sips under the guise of giving your baby kisses or cooing words.
Step 9: Baby beverage
Remember to carry a baby bag full of refills for when you finish your baby flask.
Drink your baby responsibly.
*do not put baby in microwave
[hr]
Have you made your own baby flask? I want to see it!
kalimov作者
11年8个月前IP:北京
763387
译文
这里放上译文。全部译文的地址:XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
伤心、病狂——婴儿酒瓶
原文链接:XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
原作:Mike Asaurus
译者:Kalimov
(译者按:在外国,有时候在公众场合是禁止喝酒的,避免带坏小朋友。想过酒瘾就得做伪装。放了在中国,不光大街上抽烟喝酒没人管,要想做得有个性点吸引眼球外,除了把婴儿酒瓶和自己的嘴唇漆成血红色外,一时半会还真想不到什么办法。)
在公众场合无法畅饮成人饮料着实恼火。在体育活动、电影院、教堂,带酒过来绝对不受待见。除了在下次尝试时用棕色带子遮着酒的方法,何不大隐于市,藏身于婴儿酒瓶中!?
介绍大家认识布兰蒂。虽然她不是我的女儿,但确实是个很好的婴儿伪装。这个洋娃娃内有个可添加的饮料囊,用隐藏在头部的吸管就能吸出来。每个人都喜欢婴儿,你也可以用简单的借口“嘘,她正睡着呢”来逐开好奇者,除了倔脾气的人都能拒之门外。
这个作品是基于Simon Philion的众筹项目冷藏婴儿而来的。他当项目筹款失败无从生产,而我仍却需要一个这样的。Philion在Kickstarter的留言中说,他的原型产品值好几千美元,(译者注:那是全套十个豪华版婴儿,单个基本版的则40美元。)我做的这个大约花费70美元。尽管不像他的隔热性能那么好,但在大部分场合都能正常使用。
下面是使用婴儿酒瓶的短片:
准备好剖开个婴儿,做个美味的科学不?做了它吧!
如果想看全部译文,欢迎移步XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX吧。
(同时也欢迎KCER来发文互链哈!)
kalimov作者
11年8个月前IP:北京
763466
今天收集到线下意见(中关村那头的),不在脑袋上开孔,改在菊花……(可惜这娃娃结构上没法做到,全是PP棉)
还有就是装豆腐脑
kalimov作者
11年7个月前IP:北京
770662
25楼
引用 c8920158:
只能说有点标题党,我还以为是用头骨,感情我太邪恶了。挺吓人的,如果在国外会不会被击毙?国内会不会被群殴?
这本来是老外的创意,在国外只能算是sick humour。国内的话,我真的是拿去吓人用的。在别人反应过来要围堵我的时候,早逃之夭夭了。
kalimov作者
11年5个月前IP:北京
782131
29楼
科学的极限与极限的科学
创意的极限与极限的创意
