代码模板 使用代码模板生成代码
2017/04/28
IP:江苏
很简单的东西 用于批量生产代码
Buttons LeftThumbX LeftThumbY LeftTrigger RightThumbX RightThumbY RightTrigger
<textblock text="{0} = ">
<textblock text="{{Binding {0}}}">
<stackpanel grid.column="0">
   <textblock text="Buttons = ">
   <textblock text="LeftThumbX = ">
   <textblock text="LeftThumbY = ">
   <textblock text="LeftTrigger = ">
   <textblock text="RightThumbX = ">
   <textblock text="RightThumbY = ">
   <textblock text="RightTrigger = ">
</textblock></textblock></textblock></textblock></textblock></textblock></textblock></stackpanel>
<stackpanel grid.column="1">
   <textblock text="{Binding Buttons}">
   <textblock text="{Binding LeftThumbX}">
   <textblock text="{Binding LeftThumbY}">
   <textblock text="{Binding LeftTrigger}">
   <textblock text="{Binding RightThumbX}">
   <textblock text="{Binding RightThumbY}">
   <textblock text="{Binding RightTrigger}">
 namespace CodeTemplate
    class Program
        static void Main(string[] args)
            var Input = string.Empty;
            while (true)
                Input = Console.ReadLine();
                switch (Input.ToLower())
                    case "?":
                        Help.Instance.Write();
                        break;
                    case "c":
                    case "cls":
                        Console.Clear();
                        break;
                    case "t":
                    case "template":
                        Console.Clear();
                        Template.Instance.ReadTemplate();
                        Console.Clear();
                        break;
                    default:
                        ClearCurrentConsoleLine();
                        BuildCode.Instance.Read(Input);
                        break;
        public static void ClearCurrentConsoleLine()
            int currentLineCursor = Console.CursorTop - 1;
            Console.SetCursorPosition(0, currentLineCursor);
            Console.Write(new string(' ', Console.WindowWidth));
 class Template
        static Template _Instance = new Template();
        public static Template Instance
            get
                return _Instance;
        private Template()
        public void ReadTemplate()
            Console.WriteLine("请输入 Template");
            var input = Console.ReadLine();
            var Template = new StringBuilder();
            while (input != "end" && input != "e")
                Template.Append(input);
            CodeTemplate = Template.ToString();
        public string CodeTemplate { get; private set; }
class BuildCode
        static BuildCode _Instance = new BuildCode();
        public static BuildCode Instance
            get
                return _Instance;
        private BuildCode()
        public void Read(string Input)
            try
                Console.WriteLine(Template.Instance.CodeTemplate, Input.Split(new char[] { ' ' }, StringSplitOptions.RemoveEmptyEntries));
            catch (Exception ex)
                Console.WriteLine(ex.Message);
[ 修改于9年7个月前 - 2017/04/28 14:41:57 ]
张静茹作者
9年7个月前IP:江苏
833506
再举个栗子
变量
LeftThumbX
LeftThumbY
RightThumbX
RightThumbY
模板
public event EventHandler<short> Joypad_{0};
Joypad_{0}?.Invoke(this, JoypadKeyState.Gamepad.{0});
生成结果
public event EventHandler<short> Joypad_LeftThumbX;
public event EventHandler<short> Joypad_LeftThumbY;
public event EventHandler<short> Joypad_RightThumbX;
public event EventHandler<short> Joypad_RightThumbY;
Joypad_LeftThumbX?.Invoke(this, JoypadKeyState.Gamepad.LeftThumbX);
Joypad_LeftThumbY?.Invoke(this, JoypadKeyState.Gamepad.LeftThumbY);
Joypad_RightThumbX?.Invoke(this, JoypadKeyState.Gamepad.RightThumbX);
Joypad_RightThumbY?.Invoke(this, JoypadKeyState.Gamepad.RightThumbY);
张静茹作者
9年7个月前IP:江苏
833507
再举个栗子
变量
Y
None
DPadUp
DPadDown
DPadLeft
DPadRight
Start
Back
LeftThumb
RightThumb
LeftShoulder
RightShoulder
A
B
X
模板
public event EventHandler Joypad_{0};
Joypad_{0}?.Invoke(this, EventArgs.Empty);
结果
public event EventHandler Joypad_Y;
public event EventHandler Joypad_None;
public event EventHandler Joypad_DPadUp;
public event EventHandler Joypad_DPadDown;
public event EventHandler Joypad_DPadLeft;
public event EventHandler Joypad_DPadRight;
public event EventHandler Joypad_Start;
public event EventHandler Joypad_Back;
public event EventHandler Joypad_LeftThumb;
public event EventHandler Joypad_RightThumb;
public event EventHandler Joypad_LeftShoulder;
public event EventHandler Joypad_RightShoulder;
public event EventHandler Joypad_A;
public event EventHandler Joypad_B;
public event EventHandler Joypad_X;
Joypad_Y?.Invoke(this, EventArgs.Empty);
Joypad_None?.Invoke(this, EventArgs.Empty);
Joypad_DPadUp?.Invoke(this, EventArgs.Empty);
Joypad_DPadDown?.Invoke(this, EventArgs.Empty);
Joypad_DPadLeft?.Invoke(this, EventArgs.Empty);
Joypad_DPadRight?.Invoke(this, EventArgs.Empty);
Joypad_Start?.Invoke(this, EventArgs.Empty);
Joypad_Back?.Invoke(this, EventArgs.Empty);
Joypad_LeftThumb?.Invoke(this, EventArgs.Empty);
Joypad_RightThumb?.Invoke(this, EventArgs.Empty);
Joypad_LeftShoulder?.Invoke(this, EventArgs.Empty);
Joypad_RightShoulder?.Invoke(this, EventArgs.Empty);
Joypad_A?.Invoke(this, EventArgs.Empty);
Joypad_B?.Invoke(this, EventArgs.Empty);
Joypad_X?.Invoke(this, EventArgs.Empty);
张静茹作者
8年9个月前IP:江苏
843948
正确方法是使用 Visual Stuidio的 T4 模板  方便 功能强大的多。。。。。。
