t13128
在國外网站看到的渦噴組件
2009/03/04
IP:香港
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
看上去不錯....750多美金...
Length
6.14" ( 156 mm )
Diameter
3.54" ( 90 mm )
Weight
1.87 pounds ( 850 grams )
Idle RPM
40,000 RPM
Max RPM
160,000 RPM
Thrust @Idle
0.8 pounds ( 0.4kg )
Maximum thrust
12.5lbs ( 5.7 Kg )
Nominal EGT
1166ー F ( 630ー C )
Fuel
Jet-A or Kerosene
Lubricant
Turbine oil
y2k作者
17年11个月前IP:未同步
79426
b.jpg .
釙210..................... [s:94]
