t60376
转帖:Arduino教程(提高篇)——驱动12864LCD模块
2013/09/06
IP:广西
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
mini12864图:
mini12864可配合取模软件及各种单片机可完成中文汉字、英文字符和图形显示,更适合Arduino做显示相关的互动作品,该mini液晶屏成本相对较低,适用于各类仪器,小型设备的显示领域。
由于LCD驱动IC众多,这里我们仅以OPENJUMPER的mini12864LCD为例教学,其他的LCD,你只需找到不同的库来驱动即可。
下面按步骤来驱动mini12864显示图片:
第一步:
下载取模软件
attachment icon 字模提取V2.2.zip 512.81KB ZIP 18次下载
(512.81 KB)
第二步:
处理图片,图片提取软件
attachment icon 图片提取软件.zip 730.20KB ZIP 22次下载 (731Kb),把你想要mini12864显示的图片,用软件处理为128*64的.bmp图
          如图:
第三步:
使用取模软件
            1、打开取模软件,新建图像,选择宽度128,高度64
2、打开你的图片,将做好的分辨率为128*64的.bmp图导入
3、反向取模,由于此处用的液晶点阵为反向显示,这里的取模须反向取模。(取消这一步,使用程序库里函数也可以达到此效果反向显示)
4、
生成数组,并复制下面的数组
第四步:
下载库文件
attachment icon 库文件.zip 2.65KB ZIP 25次下载
,安装在arduino安装文件的libraries下面,打开IDE,敲入下面示例代码。
第五步:
复制刚才生成的数组,取代 bmp3[1024]里面的所有数组,编译并下载到您的arduino里。
#include "Lcd12864.h"
#include  "SPI.h"
unsigned char const bmp3[1024]={
0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xC0,0xF0,0x30,0x30,0x30,0x30,0x30,0x30,0x30,
0xF0,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0xFC,0xFC,0xFC,0x30,0x3C,0x0C,0x0C,
0x0C,0x0C,0x0C,0xFC,0xF0,0xF0,0x00,0x00,0x00,0x00,0xF0,0xF0,0xFC,0x0C,0x0C,0x0C,
0x0C,0x0C,0x0C,0x0C,0xFC,0xF0,0xF0,0x00,0x00,0x00,0x00,0xFC,0xFC,0xFC,0x30,0x3C,
0x0C,0x0C,0x0C,0xFC,0xF0,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x0F,0x0F,0x3F,0x30,0xF0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,
0xF0,0x30,0x3F,0x0F,0x0F,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x30,0xF0,0xC0,0xC0,
0xC0,0xC0,0xC0,0xFF,0x3F,0x3F,0x00,0x00,0x00,0x00,0x3F,0x3F,0xFF,0xC3,0xC3,0xC3,
0xC3,0xC3,0xC3,0xC3,0xF3,0x33,0x33,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,
0x00,0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0xFC,0xFC,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,
0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x0C,
0x0F,0x03,0x03,0x03,0xFF,0xFC,0xFC,0x0C,0x0F,0x03,0x03,0x03,0xFF,0xFC,0xFC,0x00,
0x00,0x00,0x00,0xFF,0xFF,0xFF,0x0C,0x0F,0x03,0x03,0x03,0x03,0x03,0xFF,0xFC,0xFC,
0x00,0x00,0x00,0x00,0xFC,0xFC,0xFF,0xC3,0xC3,0xC3,0xC3,0xC3,0xC3,0xC3,0xFF,0xFC,
0xFC,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x0C,0x0F,0x03,0x03,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x0F,
0x3F,0x30,0x30,0x30,0x30,0x30,0x3F,0x0F,0x0F,0x00,0x00,0x00,0x00,0x0F,0x0F,0x3F,
0x30,0x30,0x30,0x3C,0x0C,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,0x3F,0x3F,0x3F,0x00,
0x00,0x00,0x00,0x00,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,0x00,0x3F,0x3F,0x3F,0x00,
0x00,0x00,0x00,0xFF,0xFF,0xFF,0x0C,0x3C,0x30,0x30,0x30,0x30,0x30,0x3F,0x0F,0x0F,
0x00,0x00,0x00,0x00,0x0F,0x0F,0x3F,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x3C,0x0C,
0x0C,0x00,0x00,0x00,0x00,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x0F,0x0F,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
void setup()
   lcd12864 x;
  x.LcmInit();
void loop()
    lcd12864 x;
    x.PUTBMP(bmp3);             //液晶点阵正向显示1秒
    delay(1000);
    x.PUTREVERSEBMP(bmp3);        //反向显示1秒
    delay(1000);
第六步:mini12864与arduino之间的接线。
CS—— 8                   //片选 低有效
RST—— 9          //给芯片复位,低有效,如果不需软件给芯片复位,可不连接
A0——10              //数据和命令选择,L 命令 H  数据
CLK——13           //时钟
MOSI——11         //数据
VCC——5V
GND——GND          //电源接线
LED——背光选择     //低有效
显示效果:
+100
精选精选
+100
猎鹰
2013/09/06
少见的经典转帖,感觉合并起来都可以作为精华帖了。
