t65384
TATP、HMTD及其它起爆药摩擦感度的最新研究结果
2014/05/24
IP:上海
本帖不代表本人对HMTD、TATP有任何推荐的意思,只是报道一下相关化合物摩擦感度的最新研究结果。
请注意:有机过氧化物极其危险!不建议大量合成!
HMTD、TATP和其它Primary Explosive摩擦感度的最新研究结果:
Journal of Hazardous Materials 213–214 (2012) 236–241
attachment icon Sensitivity to Friction for Primary Explosives.pdf 1.33MB PDF 108次下载 预览
首先是相关晶体的SEM or 光学显微镜照片:
然后是摩擦感度图表:
可以得出:
1. HMTD的摩擦感度高于DADP;
2. DADP的摩擦感度略高于TATP;
3. 晶体形态对摩擦感度有较大影响,晶型规整且无锐角的能材感度相对于晶型混乱且棱角较多的低;
4. 原文献结论:纯过氧化物并没有像之前认为的那样拥有极高的感度;
5. HMTD纯品感度过高,应钝化改性后使用。
根据感度和安定性等等数据,不建议使用纯HMTD作为起爆药。
另外,HMTD和TATP含有~5%的水分,其感度会大大降低(另一篇文献结果)。
但是HMTD对水不稳定,易于分解。
国外论坛参考:
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
还有一篇文献:
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
预览:
@QQQQQQQ 帮我下个文献吧~
其它相关文献:
attachment icon Triacetone Triperoxide:Its Chemical Destruction.pdf 138.81KB PDF 60次下载 预览
attachment icon Thermal Decomposition of Various Acid Concerntrations to Synthesize Triacetone T.attach 1.05MB ATTACH 15次下载
attachment icon Study of TATP:Stability of TATP Solutions.pdf 171.48KB PDF 37次下载 预览
attachment icon Study of TATP:Spontaneous Transformation of TATP to DADP.pdf 205.94KB PDF 48次下载 预览
attachment icon Study of TATP:Method for Determination of Residual Acids in TATP.pdf 802.01KB PDF 24次下载 预览
attachment icon Study of TATP:Mass Loss and Friction Sensitivity During Ageing.pdf 840.14KB PDF 41次下载 预览
attachment icon Study of TATP:Influence of Reaction Conditions on Product Composition.pdf 255.69KB PDF 34次下载 预览
attachment icon Novel Approach to the Detection of Triacetone Triperoxide (TATP):Its Structure .attach 92.33KB ATTACH 6次下载
attachment icon Factors Influencing Triacetone Triperoxide (TATP) and Diacetone Diperoxide (DADP.attach 644.70KB ATTACH 9次下载
attachment icon Factors Influencing Destruction of Triacetone Triperoxide (TATP).pdf 320.58KB PDF 41次下载 预览
attachment icon F1-A1:Synthetic Routes to New and Improvised High Explosives.pdf 346.95KB PDF 29次下载 预览
attachment icon Determination of the Vapor Density of Triacetone Triperoxide (TATP) Using a Gas .attach 90.84KB ATTACH 2次下载
attachment icon Decomposition of Triacetone Triperoxide Is an Entropic Explosion.pdf 758.31KB PDF 35次下载 预览
attachment icon Ultrasonic Activation of Triacetone Triperoxide.pdf 306.50KB PDF 37次下载 预览
attachment icon The Forensic Analysis of Triacetone Triperoxide (TATP) Precursors and Synthetic .attach 1008.68KB ATTACH 2次下载
attachment icon Reaction Kinetics of Acetone Peroxide Formation and Structure Investigations Usi.attach 328.40KB ATTACH 8次下载
attachment icon Detonation Performance of TATP-AN-Based Explosives.pdf 276.06KB PDF 42次下载 预览
attachment icon Decomposition of a Multi-Peroxidic Compound Triacetone Triperoxide (TATP).pdf 211.50KB PDF 43次下载 预览
attachment icon Mass Spectrometry Analysis of HMTD by its Decomposition Products.pdf 453.70KB PDF 38次下载 预览
attachment icon Forensic Investigation of Some Peroxides Explosives.pdf 513.70KB PDF 35次下载 预览
attachment icon Decreasing the Friction Sensitivity of TATP, DADP and HMTD.pdf 553.04KB PDF 33次下载 预览
attachment icon Explosive Properties of Primary Explosives.pdf 1.00MB PDF 36次下载 预览
attachment icon 环状有机过氧化物--独特的新概念炸药.pdf 403.55KB PDF 58次下载 预览
attachment icon 有机过氧化物的危险特性及安全性评价研究进展.pdf 511.03KB PDF 83次下载 预览
警示大家:
1. 有机过氧化物极其危险!!!不建议大量合成!!!
2. 玩能材之前,首先要学习化学基础理论。
比如无机化学(推荐吴国庆编写的《无机化学》第四版)、有机化学(强烈推荐《基础有机化学》第三版)、结构化学(周公度、段连运《结构化学基础》第四版)等等,二楼放资料。
强烈鄙视玩能材不学化学的人!杜绝中二小白!!!
3. 合成能材时,绝对要少量合成!
大批量造低端能材纯属是kbfz的行为,绝不是能材党应有的,水平一般、操作熟练的能材党就能做到这一点。
毕竟我们不是兵工厂,目的也不是大规模生产。当然,对于如何提高产率的研究,应当大力支持。
4. 玩能材绝不仅仅是为了听个响。
分子结构分析计算、反应机理、标准操作、晶型控制、合成设计等等都很重要。
5. 科学没有高下之分。在讨论中也应尊重对方,学会包容。这是人的基本素养。
即使有不同的学术见解也要心平气和地讨论,而讨论也应限制在学术方面,而不是人身攻击。
6. 不要老是说过氧化物低级。。。见第5条。
上面的23篇英文文献都是在Journal of Hazardous Materials、Journal of the American Chemical Society等等著名期刊上发表的。
TATP的研究主要集中在检测上(原因你懂的),其次是爆炸合成、敏化剂等等,其相关衍生物也有不少,改性后综合性能也有较大提升。
无论如何,过氧化物炸药独特的储能方式、结构和熵驱动过程对于新概念炸药和炸药理论的贡献还是非常大的,在爆炸合成的应用上也是大放异彩。
不过必须承认,其应用于配方炸药的难度很大。尽管上面有一个TATP-AN的配方,TNT当量106%。
现在除了kbfz之外,几乎没有人或组织大规模使用含有TATP的配方。
7. 注意安全规范操作!
能材合成不是普通的合成,一出事故就是大事故。
尤其是老手。所谓会水水中死,会拳拳下亡,一时大意,阴沟翻船,遗憾终生(如果还有)。
PS: 在此帖喷者杀无赦!论坛不是用来吵架的地方!!
[groupid=337]化学[/groupid]
+150
焓熵`
2014/05/24
高质量发帖
+1000
trample
2014/05/24
很久没有看到这样有货的帖子了
+1000
bh,王者归来
2014/05/24
大赞!
+50
阿飘先生
2014/05/25
赞!
+100
托尼史塔克
2014/05/25
高质量发帖
46
12年7个月前IP:未同步
690709
打包上传,记着下载全部压缩包,并放在同一目录下解压:
1. 基础有机化学(第三版) - 邢其毅等
2. 有机化学(第三版) - 胡宏纹+习题解析
3. 无机化学(第四版) - 吴国庆
4. 普通无机化学(第二版) - 严宣申, 王长富
5. 结构化学基础(第四版) - 周公度, 段连运+习题解析
attachment icon Reference.haozip01.zip 10.00MB ZIP 39次下载
attachment icon Reference.haozip02.zip 10.00MB ZIP 33次下载
attachment icon Reference.haozip03.zip 10.00MB ZIP 25次下载
attachment icon Reference.haozip04.zip 10.00MB ZIP 25次下载
attachment icon Reference.haozip05.zip 10.00MB ZIP 21次下载
attachment icon Reference.haozip06.zip 10.00MB ZIP 20次下载
attachment icon Reference.haozip07.zip 10.00MB ZIP 19次下载
attachment icon Reference.haozip08.zip 10.00MB ZIP 18次下载
attachment icon Reference.haozip09.zip 5.72MB ZIP 19次下载
12年7个月前IP:未同步
690720
其它资料:
1. 化学基础文献更新
https://www.kechuang.org/t/65191
2. HEDM最新文献集合
https://www.kechuang.org/t/65178
3. 量子计算软件Gaussian09W B.01+GaussView5.0.8
https://www.kechuang.org/t/65192
4. 化学软件包ChemBioOffice 2012
https://www.kechuang.org/t/65008
5. Chemdraw 10.0汉化版
https://www.kechuang.org/t/64617
6. 能材计算器
https://www.kechuang.org/t/64704
或者是淘帖专辑(包含上述帖子)
https://www.kechuang.org/t/1
12年7个月前IP:未同步
690722
虎哥 发表于 2014-5-24 19:08
大赞!
看了文献,发现以前忽视了一个问题,就是感度曲线的斜率——特征感度其实与安全不一定有直接关系 ...
可能是晶体结构不同。。。毕竟化合物分子结构相近,含能基团相同
也可能是金属离子的影响。。。不过Cu和Ag在同一族,还是相同的价态。。
PS:那是乙炔亚铜Cu2C2。。。
12年7个月前IP:未同步
690737
虎哥 发表于 2014-5-24 19:42
是啊,可惜没有叠氮银的图,要不可以比较一下。
LA的感度那么高,真是颠覆认识啊~~
@helium
用你的AgN3测试一下吧。。。。
记得感度非常高,但是没有定量数据
12年7个月前IP:未同步
690751
其实我一直推荐的是无起爆药*管(MHN等等)
实在不行,弱起爆药+扩爆药(NHN+PETN等等)
高起爆能力的化合物一般伴随同样高的感度,有时候还有较高的毒性or合成难度。。。
还有材料来源。。。。。。
比如LA、SA等等属于高感度,LA、SA、NHN、NHA、DACP、BNCP属于高毒性(N2H4、NaN3、Co2+),BNCP、NH4CuNT属于合成复杂。。。
四唑、叠氮类的前体也由于kbfz而难买得多。。。
看起来,GT类都还不错(如果CHZ好买的话)。当然,不推荐GTG(作死的Cd2+),其实Ni2+也是有毒的。。。GTX虽然威力一般,但是考虑价格和安全性,相对来说非常不错啊。。。
还有SY共晶,成本低、安全、合成简单、基本无毒、材料来源较广。。。
另外,现在正在考虑NAT(Nitramino Tetrazole,硝氨基四唑)盐(NAT2-,双负离子)的可行性,比如CaNAT。。。但是木有AT啊
除了自己造着玩/研究/花样作死的,建议实际应用应该选择上述的无起爆药/弱起爆药+扩爆药*管。
12年7个月前IP:未同步
690757
friedel 发表于 2014-5-24 20:51
个人感觉SY共晶起爆药也挺有前途的
对,SY共晶也是很不错的,成本低,环保,基本无毒
PS:上面的链接里没有提到AgN3摩擦感度的数据
只是说摩擦感度极高。。。
还有一个缺点,几乎是银盐的通性——光解。。。
启动成本高,一瓶AgNO3少说300。。。
12年7个月前IP:未同步
690758
friedel 发表于 2014-5-24 20:49
SA感度真心不高。。这篇帖子里面有挺详细的数据
http://bbs.kechuang.org/forum.php?mod=viewthread&tid ...
wesker版主原话:
12年7个月前IP:未同步
690763
friedel 发表于 2014-5-24 21:07
对的,启动成本太高绝对是一大问题。。除非买得到小量分装出售的硝酸银和叠氮钠
分装出售价格就坑爹了。。。
我亲眼见到试剂店老板把¥440/100g的硝酸银分装为¥150/25g。。。
叠氮钠管制太严,阿里巴巴直接屏蔽相关产品了
都是TMDkbfz搞的。。。。
12年7个月前IP:未同步
690775
qwe 发表于 2014-5-24 21:45
苏打azide淘宝有
还有图g什么东西,晶体貌似不错
由于分子结构原因,感度仍然很高
g就是电*管中的Lead Styphnate,斯蒂芬酸铅
12年7个月前IP:未同步
690780
19楼
qwe 发表于 2014-5-24 21:58
话说高氯酸酯有没有感度较低的,这个研究较少,现在只有小明甲酯(作死)
高氯酸盐还凑合
酯就是花样作死啊。。。。。。
12年7个月前IP:未同步
690833
22楼
helium 发表于 2014-5-24 22:43
1688搜“氮钠”依然可以搜到
呃呃呃
换个关键词就行啊
不过还是挺贵的
12年7个月前IP:未同步
690851
24楼
王者归来abs 发表于 2014-5-25 12:25
刚刚查了半天MHN资料
发现坛子里基本没有这个的系统教程 而且甚至连名称都没有统一起来
好好查一下吧。。。
https://www.kechuang.org/t/65323
12年7个月前IP:未同步
690879
26楼
darkorochi 发表于 2014-5-25 13:43
玩能材绝不仅仅是为了听个响。
好多中二其实就为了听个响。。。。不听响玩什么能材啊,随便按着实验教材 ...
中二如果不学理论,迟早得被某次实验报销。。。
一开始所有人都是菜鸟,只是部分菜鸟后来变成高手,大部分停留在菜鸟的水平上。
其实大多数人(包括我)都是因为想听个响才开始玩能材的,但是后来随着学习的深入,发现能材不仅仅只是听响,能材也是化学的一部分。
12年7个月前IP:未同步
690918
28楼
darkorochi 发表于 2014-5-25 15:55
能深入学就是好事啊,上大学之后就觉得,肯努力也是一种天赋优势,爱好广总不是坏事。
今年考研全靠毕业 ...
的确是这样
之前学的东西一定会在某个未知的时候体现其重要性
12年7个月前IP:未同步
691123
30楼
王者归来abs 发表于 2014-5-25 20:09
我看了您的帖子。。。
没有学术分。。。
已发。
12年7个月前IP:未同步
691181
32楼
QQQQQQQ 发表于 2014-5-26 15:33
这篇文献我看过 ,作者强行拟合来用摩擦感度来给大家暗示摩擦感度与起爆药的起爆力的关系,其实这是十分不 ...
的确
摩擦感度不能代表综合感度
其实还有撞击、针刺、火焰等等
不过作者就是现在仅有的两位研究TATP相关过氧化物的人。。。。。。
不好说数据的真实性,但是毕竟发表在J. Hazard. Mater.上。。。2014.1发表的
还是捷克国防部资助项目
12年7个月前IP:未同步
691182
33楼
另一位就在TATP诞生地——以色列的研究小组
12年7个月前IP:未同步
691185
35楼
QQQQQQQ 发表于 2014-5-26 15:41
事实上 起爆药的起爆力应分为三个等级:第一级应是具有金属性的氮桥网状配合物,该物质会立即成长为极高速 ...
LA的机械感度低吗。。。
当然,得看什么晶型
QQQQQQQ
2014/05/26
一个合格的LA当然是最完美的起爆药
12年7个月前IP:未同步
691188
37楼
QQQQQQQ 发表于 2014-5-26 15:45
至少我亲自打过工业LA的感度,我不同意该文献结果。
文献里的纯LA晶型比较。。。
还有,工业品可能和公司生产标准不同有关
QQQQQQQ
2014/05/26
目前没有用纯LA,即使结晶LA,其也是用PH引入的杂质晶控的。
12年7个月前IP:未同步
691193
38楼
不排除LA是自制的可能
原文:the crystalline agent was not used during LA production
没有用结晶控制剂
这份LA可能就是为了实验特制的纯品,而不是工业用
+5
QQQQQQQ
2014/05/26
好吧。。。。。。。。。。
+5
QQQQQQQ
2014/05/26
对了,你要下的文献发网址链接我。
12年5个月前IP:未同步
705419
41楼
friedel 发表于 2014-7-17 17:51
相关图片:
高氯酸碳酰肼合铜产物(最近刚做的)
难道说是[Cu(CHZ)2](ClO4)2?
11年9个月前IP:河北
755663
45楼
引用 QQQQQQQ:
这个我也做过 ,确实是这样的 ,AN和AP都有此现象,但是TATP与HMTD或GTN相比,最大的缺点在于起爆力上,前几天我刚去完某大学来进一步测试研究我的起爆药系列的新做出来的物质,事实上HMTD和GTG,GTCo(注意不光是GTN)可以应...
设备太屌23333的确,HMTD的用量可以非常小,比如我做实验都是3mg....
