t23095
【RF Studio】RF19探空火箭发射记录
2010/02/16
IP:广东
RF19 was successfully launched on 2010/2/15.
we had a 2.4GHz module and a 433MHz module on it, which sends the video signal and flight data back.
well,
let's check the acc data out:
X:
Y:
Z:
and air speed:
it doesnt matter if you reject me:
U0 = 4.2v
Ut = 4.8v
115kpa / 5v * 4.2v = 96.6
115kpa / 5v * 4.8v = 110.4
presure(H) = 96.6kpa
presure(D) = 110.4kpa
presure(delta) = 13.8kpa = 13800pa
p(air) = 1.3kg/m^3
according to the formula : q = (1/2) pv^2
(1/2)pv^2 = 13800pa
0.65 * v^2 = 13800pa
v^2 = 21230pa
v = 145m/s
so, the rocket was flying at 145m/s.
(dont care about it.)
and some pictures(no introduction to them, never mind.)
+1000
瞳
2010/02/16
强人
+5000
我说要有光
2010/02/16
赞扬
+999
power_rdx
2010/02/16
补全
+2000
delete
2010/02/16
強烈讚揚
west_0830
2010/02/16
你的分太多了。。
+2000
black
2010/02/16
於是我
92
93°作者
16年11个月前IP:未同步
191115
the length of my rocket is 1.5m, so,
according to the formula : a = s/t^2
s = 1.6m,
t = 1/24s
a = 1.6m / 0.0173 = 93 m/s^2
93°作者
16年11个月前IP:未同步
191121
Engine
this time we were using a metal engine:
16年11个月前IP:未同步
191124
好啊  羡慕啊  [s:259]  [s:118]  [s:233]  [s:237]  [s:116]
93°作者
16年11个月前IP:未同步
191127
video from my rocket (just ignore it, damn it !!!!!!!)
93°作者
16年11个月前IP:未同步
191129
16年11个月前IP:未同步
191130
[quote]引用楼主93°于10-02-16 17:12发表的 【RF Studio】RF19探空火箭发射记录 :
[size=3]
we are having a 2.4GHz module and a 433MHz module on it, which sends the video signal and flight data back.
.......[/quote]
if u wanna copy my words down here please change the tense first THX.
16年11个月前IP:未同步
191134
于广西象州县宽带发来贺电
这次火箭发射视频背景不错。但是插值产生的锯齿依然存在,请教ing.
93°作者
16年11个月前IP:未同步
191135
引用第7楼novakon于2010-02-16 17:33发表的  :
sorry ,never mind plz
引用第8楼novakon于2010-02-16 17:38发表的 于广西象州县宽带发来贺电 :
idk
[flash=640,480]XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX target="_blank" style="font-size:20px;">点击此处查看视频
16年11个月前IP:未同步
191138
我靠
9g的加速度
原來是通過壓力變化來計算速度的額
不考慮風壓對傳感器的影響么
16年11个月前IP:未同步
191150
according to the formula : a = s/t^2?
93°作者
16年11个月前IP:未同步
191156
引用第11楼why1gz于2010-02-16 17:56发表的  :
没问题吧。。。我考试一直这么算啊
16年11个月前IP:未同步
191163
引用第12楼93°于2010-02-16 18:03发表的  :
没问题吧。。。我考试一直这么算啊
什么最好玩?无过于初中化学和高中物理以及大学高数
16年11个月前IP:未同步
191164
s=1/2at^2
93°作者
16年11个月前IP:未同步
191165
引用第13楼chiataimakra于2010-02-16 18:08发表的  :
问题是,算这个用高中物理就够了吧。。
16年11个月前IP:未同步
191166
引用第14楼why1gz于2010-02-16 18:09发表的  :
s=1/2at^2
gj
16年11个月前IP:未同步
191168
某人說93強的可怕呢- -
等他上線估計有的看了= =
16年11个月前IP:未同步
191169
[s:92] 开伞药又下多了??
PS:其实我很欣赏那个倒插在那里还在燃烧的镜头............
16年11个月前IP:未同步
191170
18楼
呃,
s = v零t + 1/2at2.
93°作者
16年11个月前IP:未同步
191176
19楼
原始数据文件
attachment icon data.txt 2.41KB TXT 39次下载
16年11个月前IP:未同步
191180
20楼
开伞失败了??
唔 可以去参加XX比赛了
93°作者
16年11个月前IP:未同步
191184
21楼
s=1/2at^2
有问题?
好吧是我的错,应该是a=s/T^2,不是t
16年11个月前IP:未同步
191193
22楼
RF18做什么去了~~~~~
93°作者
16年11个月前IP:未同步
191196
23楼
引用第23楼pisces于2010-02-16 18:41发表的  :
RF18做什么去了~~~~~
“条子你好,条子再见”
16年11个月前IP:未同步
191215
24楼
陕西人民发来贺电      。
16年11个月前IP:未同步
191219
25楼
特區香港人民发来贺电
16年11个月前IP:未同步
191222
26楼
中华萌国大陆地区浙江省杭县发来贺电
有本的正面图否
16年11个月前IP:未同步
191240
27楼
推力强大阿  哪个土都喷出来了
有没视平 上传上阿  弟一个放在 YOU哪不安全~~~
16年11个月前IP:未同步
191241
28楼
还有哪电路~~板怎么爆的
16年11个月前IP:未同步
191246
29楼
那么传统的燃料。。。。。失望。。。。。
16年11个月前IP:未同步
191252
30楼
请上传航拍录像
还有,是不是开伞失败了。。。
93°作者
16年11个月前IP:未同步
191254
31楼
引用第31楼warmonkey于2010-02-16 20:00发表的  :
请上传航拍录像
还有,是不是开伞失败了。。。
画质太渣,上传会被吐槽。。。
93°作者
16年11个月前IP:未同步
191262
32楼
引用第10楼クロ于2010-02-16 17:42发表的  :
我靠
9g的加速度
原來是通過壓力變化來計算速度的額
不考慮風壓對傳感器的影響么
通过动压来计算的
16年11个月前IP:未同步
191319
33楼
93 同伙~~~~ 还好没吧哪个村理的稻草点着了 哈哈   ~~~
见小朋友 烧过一次 吓得几条村 的 人都跑去 救火
16年11个月前IP:未同步
191322
34楼
声音比较有力量。。。-1000分。。。
16年11个月前IP:未同步
191342
35楼
回 楼主(93°) 的帖子
赞!!!!!
2000分太少了
16年11个月前IP:未同步
191374
36楼
请上传航拍录像+1
16年11个月前IP:未同步
191377
37楼
看样子是开伞失败了
是否有最大飞行高度的计算或测量?
93°作者
16年11个月前IP:未同步
191381
38楼
不敢算。。。怕被吐槽
有爱的话,根据图表算吧。。
93°作者
16年11个月前IP:未同步
191385
39楼
引用第33楼jrcsh于2010-02-16 21:45发表的  :
发射时有小雨 。。。不担心
16年11个月前IP:未同步
191386
40楼
93,54,52,107---2010/2/15 15:32:45 +08:00
2,61,36,107---2010/2/15 15:32:45 +08:00
1,105,55,108---2010/2/15 15:32:45 +08:00
3,52,41,107---2010/2/15 15:32:45 +08:00
5,55,29,108---2010/2/15 15:32:45 +08:00
11,56,48,113---2010/2/15 15:32:45 +08:00
36,69,34,113---2010/2/15 15:32:45 +08:00
63,75,39,113---2010/2/15 15:32:45 +08:00
77,82,42,113---2010/2/15 15:32:45 +08:00
89,79,1,112---2010/2/15 15:32:45 +08:00
97,108,15,109---2010/2/15 15:32:45 +08:00
101,104,19,105---2010/2/15 15:32:45 +08:00
107,80,26,108---2010/2/15 15:32:45 +08:00
z轴加速度应该是第一排吧...单位是什么?
93°作者
16年11个月前IP:未同步
191388
41楼
引用第40楼10班陈大葱22号于2010-02-16 23:13发表的  :
0xff,
可以根据我之前算出来的93m/s^2来算,1是最大值(Z轴是反过来的。。。囧),也就是93
16年11个月前IP:未同步
191389
42楼
我又不是搞这个的,那图表根本就不认识。。。。
16年11个月前IP:未同步
191414
43楼
奇怪了 如果用加速度积分的话,火箭速度最高大概才60m/s...
加速度应该不止那么点吧...
我的想法是单片机每间隔1ms或更短读一次z轴加速度,存进EEPROM,火箭下来了以后再读出来,积分就可以得到速度了....
16年11个月前IP:未同步
191445
44楼
引用第38楼93°于2010-02-16 23:06发表的  :
不敢算。。。怕被吐槽
有爱的话,根据图表算吧。。
你就放心的算吧,我只是想了解一下火箭开伞失败的时候从多大的高度落下来会造成图中的损伤
相同的问题我不再吐槽。以前吐槽过了以后就算了
16年11个月前IP:未同步
191480
45楼
求加速度计型号及量程
93°作者
16年11个月前IP:未同步
191483
46楼
引用第45楼warmonkey于2010-02-17 11:27发表的  :
求加速度计型号及量程
x和y轴是freescale的mma7260,量程6G
z轴是freescale的mma3201,量程40G
93°作者
16年11个月前IP:未同步
191484
47楼
说实话不是很满意,期待RF20吧,哇哈哈哈哈
16年11个月前IP:未同步
191498
48楼
视频还是不放么。。。。。。
93°作者
16年11个月前IP:未同步
191500
49楼
引用第48楼侧卫007于2010-02-17 12:11发表的  :
视频还是不放么。。。。。。
渣啊。。。。
16年11个月前IP:未同步
191505
50楼
我看视频刚起飞的时候差点回力了= =!
为嘛X和Y轴也有那么大波动
