已经帮楼主编辑。包含代码请使用backtick(数字1左边的键),具体参考markdown规范。
#include<reg52.h>
#define uint unsigned int
#define uchar unsigned char
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
uint tent,sec;
bit write=0;
sbit sda=P1^2;
sbit scl=P1^7;
sbit dula=P2^6;
sbit wela=P2^7;
void delay()
void delay1ms(uint z)
uint x,y;
for(x=0;x<z;x++) for(y="0;y<110;y++);" } void start() { sda="1;" delay(); scl="1;" stop() response() uint i; while((sda="=1)&&(i<250))" i++; init() write_byte(uchar date) uchar temp,i; temp="date;" for(i="0;i<8;i++)" read_byte() k,i; k="(k<<1)|sda;" dealy(); return k; write_24c02(uchar adress,uchar start(); write_byte(0xa0); response(); write_byte(adress); write_byte(date); stop(); read_add(uchar adress) date; write_byte(0xa1); date="read_byte();" display(uchar shi,uchar ge) dula="1;" p0="table[shi];" wela="1;" delay1ms(5); main() init(); sec="read_add(2);" if(sec>100)
sec=0;
TMOD=0x01;
TH0=(65535-50000)/256;
TL0=(65535-50000)%256;
EA=1;
ET0=1;
TR0=1;
while(1)
display(sec/10,sec%10);
if(write==1)
write=0;
write_24c02(2,sec);
void qwe()interrupt 1
tent++;
if(tent=20)
tent=0;
sec++;
write=1;
if(sec==100)
sec=0;
</z;x++)></reg52.h>
给你个参考 display.c
#include "stm8s.h"
#include "display.h"
#define A(a) a ? (GPIOA->ODR |= GPIO_PIN_1):(GPIOA->ODR &= (~GPIO_PIN_1))
#define B(a) a ? (GPIOF->ODR |= GPIO_PIN_4):(GPIOF->ODR &= (~GPIO_PIN_4))
#define C(a) a ? (GPIOC->ODR |= GPIO_PIN_5):(GPIOC->ODR &= (~GPIO_PIN_5))
#define D(a) a ? (GPIOC->ODR |= GPIO_PIN_7):(GPIOC->ODR &= (~GPIO_PIN_7))
#define E(a) a ? (GPIOD->ODR |= GPIO_PIN_0):(GPIOD->ODR &= (~GPIO_PIN_0))
#define F(a) a ? (GPIOA->ODR |= GPIO_PIN_2):(GPIOA->ODR &= (~GPIO_PIN_2))
#define G(a) a ? (GPIOC->ODR |= GPIO_PIN_4):(GPIOC->ODR &= (~GPIO_PIN_4))
#define DP(a) a ? (GPIOC->ODR |= GPIO_PIN_6):(GPIOC->ODR &= (~GPIO_PIN_6))
// 0 1 2 3 4 5 6 7 8 9 P -
const uint8_t display_data[] = {0xFC,0X60,0xDA,0xF2,0x66,0xB6,0xBE,0xE0,0xFF,0xF6,0xCE,0x02};
//void Display_b(uint8_t data);
//void Display_3(uint16_t data,uint8_t dp,uint8_t dig);
//显示刷新函数
uint8_t dp == 小数点高有效 3'b000 ~ 3'b111
void Display(uint8_t dp)
extern uint8_t dig_1,dig_2,dig_3,display_cnt;
switch(display_cnt)
case 0: GPIOD->ODR &= (~GPIO_PIN_7);//DIG3_LOW
A(dig_1 & 0X80);
B(dig_1 & 0X40);
C(dig_1 & 0X20);
D(dig_1 & 0X10);
E(dig_1 & 0x08);
F(dig_1 & 0X04);
G(dig_1 & 0X02);
DP(dp & 0x04);
GPIOD->ODR |= GPIO_PIN_3;//DIG1_HIGH
break;
case 1: GPIOD->ODR &= (~GPIO_PIN_3);//DIG1_LOW
A(dig_2 & 0X80);
B(dig_2 & 0X40);
C(dig_2 & 0X20);
D(dig_2 & 0X10);
E(dig_2 & 0x08);
F(dig_2 & 0X04);
G(dig_2 & 0X02);
DP(dp & 0x02);
GPIOD->ODR |= GPIO_PIN_2;//DIG2_HIGH
break;
case 2: GPIOD->ODR &= (~GPIO_PIN_2);//DIG2_LOW
A(dig_3 & 0X80);
B(dig_3 & 0X40);
C(dig_3 & 0X20);
D(dig_3 & 0X10);
E(dig_3 & 0x08);
F(dig_3 & 0X04);
G(dig_3 & 0X02);
DP(dp & 0x01);
GPIOD->ODR |= GPIO_PIN_7;//DIG3_HIGH
break;
display_cnt++;
if(display_cnt == 3)
display_cnt = 0;
void Display_Init(void)
//PA 1 2
GPIO_Init(GPIOA,(GPIO_Pin_TypeDef)(GPIO_PIN_1 | GPIO_PIN_2), GPIO_MODE_OUT_PP_LOW_FAST);
//PC 4 5 6 7
GPIO_Init(GPIOC,(GPIO_Pin_TypeDef)(GPIO_PIN_4 | GPIO_PIN_5 | GPIO_PIN_6 | GPIO_PIN_7), GPIO_MODE_OUT_PP_LOW_FAST);
//PD 0 2 3 7
GPIO_Init(GPIOD,(GPIO_Pin_TypeDef)(GPIO_PIN_0 | GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_7), GPIO_MODE_OUT_PP_LOW_FAST);
//PF 4
GPIO_Init(GPIOF,GPIO_PIN_4, GPIO_MODE_OUT_PP_LOW_FAST);
数码管显示数据刷新
uint16_t data == 显示数据 0 ~ 999
void Display_update(uint16_t data)
extern uint8_t dig_1,dig_2,dig_3;
dig_1 = display_data[((uint8_t)(data/100))] ;
dig_2 = display_data[((uint8_t)((data%100)/10))];
dig_3 = display_data[((uint8_t)(data%10))];
display.h
#include "stm8s.h"
#ifndef DISPLAY_H_
#define DISPLAY_H_
void Display_Init(void);//数码管初始化
void Display(uint8_t dp);//数码管刷新
void Display_update(uint16_t data);//数码管显示数据更新
#endif
我是stm8io冲突没法使用整组io只能这么搞了 每次调用显示函数移位一次每次显示小号69 -71时钟周期
ORG 00H
AJMP MAIN
ORG 0BH
AJMP T0INT
ORG 30H
MAIN:LCALL INIT ;初始化
START:LCALL DISP ;开始
JB P1.4,PAUSE
SETB TR0
AJMP START
PAUSE: LCALL DISP //暂停
JB P1.5,CLEAR
CLR TR0
AJMP PAUSE
CLEAR: LCALL DISP //清零
JB P1.6,START
CLR TR0
MOV R4,#0
MOV R0,#0
AJMP CLEAR
DISP: //显示
MOV A,R4
MOV B,#10
DIV AB
MOV DPTR,#TAB //不带小数点显示
MOVC A,@A+DPTR
MOV P0,A
CLR P1.0
CLR P1.2
CLR P1.3
ACALL D1MS
SETB P1.0
SETB P1.2
SETB P1.3
MOV A,B
MOVC A,@A+DPTR
MOV P0,A
CLR P1.1
CLR P1.2
CLR P1.3
ACALL D1MS
SETB P1.1
SETB P1.2
SETB P1.3
ACALL D1MS
MOV A,R0
MOV B,#10
DIV AB
MOV DPTR,#TAB
MOVC A,@A+DPTR
MOV P0,A
CLR P1.2
CLR P1.0
CLR P1.1
ACALL D1MS
SETB P1.2
SETB P1.0
SETB P1.1
MOV A,B
MOV DPTR,#TABEL ;带小数点显示
MOVC A,@A+DPTR
MOV P0,A
CLR P1.3
CLR P1.0
CLR P1.1
ACALL D1MS
SETB P1.3
SETB P1.0
SETB P1.1
RET
INIT:MOV SP,#60H
MOV R4,#0
MOV DPTR,#TAB
MOV TMOD,#01H
MOV TH0,#0D8H ; 10MS
MOV TL0,#0F0H
SETB ET0
SETB EA
RET
T0INT:
MOV TH0,#0D8H
MOV TL0,#0F0H
INC R4
CJNE R4,#100,RTI ;10MS X 100 = 1S
MOV R4,#0
INC R0
CJNE R0,#100,RTI
MOV R0,#0
RTI:
RETI
D1MS:
MOV R7,#01H
DL1:
MOV R6,#8EH
DL0:
MOV R5,#02H
DJNZ R5,$
DJNZ R6,DL0
DJNZ R7,DL1
RET
TAB:
DB 3FH,06H,5BH,4FH,66H,6DH,7DH,07H,7FH,6FH 不带小数点显示
TABEL:
DB 0BFH,86H,0DBH,0CFH,0E6H,0EDH,0FDH,0F7H,0FFH,0EFH 带小数点显示
END
