现在放上原文教程。原文链接XXXXXXXXXXXXXXXXXXXXXXXXXXXX/id/baby-flask/?ALLSTEPS下一楼是部分译文和译文地址。
Baby flask
by mikeasaurus
Download9 Steps
Collection I Made it! Favorite Share
It's so frustrating not being able to enjoy my adult beverage in public. Sporting events, movies, church, all frown on bringing in your own booze. Instead of brown-bagging your beverage at the next bash, why not hide it in plain sight, inside ababy flask!This doll holds a refillable drink bladder that lets you sip from a straw hidden in the top of the head. Everyone loves babies, and you can dismiss any inquisitive investigators by simply saying "Shhh. she's sleeping". This should deter all but the most persistent people.
This project is based off the Cool Baby by Simon Philion, when it failed to get funding I knew I still had to have one. I made a DIY Cool Baby that I named Brandi. Though not insulated it like the genuine article it works well enough for most applications.Here's a short video showing the baby flask in action:
Ready to bust open a baby for delicious science? Let's make!
Step 1: Supplies
To make this baby flask I used:
You'll also need a drill with a large diameter bit, and a sharp knife.
Step 2: Gut baby
Open back of doll and make a small incision in the back, then remove all the batting inside.
Step 3: Measure + cut bladder hose
My bladder was 2 litres and would take up all the room inside the baby carcass. The hose was much too long, so needed to be cut down to more manageable size.I measured how long the hose needed to be, then cut off the excess. The mouth bite was cut from the remaining hose and attached to the new shortened length by pressing it into the barbs, holding it securely in place.
Step 4: Drill baby
To make an opening for the mouth bite we'll need to drill a hole in the doll head. The head is soft and hollow, so this is fairly easy. Drill into the soft baby head meat with a large diameter drill bit.
Step 5: Insert bladder
Insert the empty bladder into the baby cavity and feed the drinking hose up through the neck and into the hollow head. The mouth bite can be pulled through the opening in the head.
Step 6: Fill baby flask
With the bladder installed you can fill your baby flask with your favourite beverage.
Step 7: Seal baby
Seal up the velcro backing of the baby clothes and you're all set to bring your baby to the next sporting event.
Step 8: Put in carrier
To really make this believable you'll need a way to carry your baby flask XXXXXXXXXXXXXXXXXXace your baby in a baby carrier so you can take small sips under the guise of giving your baby kisses or cooing words.
Step 9: Baby beverage
Remember to carry a baby bag full of refills for when you finish your baby flask.
Drink your baby responsibly.
Have you made your own baby flask? I want to see it!
Baby flask
by mikeasaurus
Download9 Steps
Step 1: Supplies
Step 2: Gut baby
Step 4: Drill baby
Step 7: Seal baby
*do not put baby in microwave
[hr]
