国外关于ETN的研究资料
smith2015/02/22化学 IP:日本
ETN(Erythritol Tetranitrate),中文名赤癣醇四硝酸酯,这个东西和太安类似,国外的论坛上面比较热门,不过我搜了一下科创,好像之前还没有研究过。
ETN的结构图如下:
维基百科给的介绍:
XXXXXXXXXXXXXXXXXXXXXXX/wiki/Erythritol_tetranitrate
按照维基给的介绍,精制的ETN在压药密度为1.6 g/cm时的爆速在8000–8100 m/s,已经很接近太安,但此物比太安敏感,甚至不需要起爆药(有作为起爆药的潜力),但相对的比HMTD这些起爆药撞击敏感度低,而且不容易分解。
ETN的分解方程式:
2 C4H6N4O12 → 8 CO2 + 6 H2O + 4 N2 + 1 O2
从分解来看ETN是正氧平衡的,而PETN分解的方程是负氧平衡的。
合成的方法和太安类似,不需要发烟硝,国外的老外更狠,甚至不用硝酸,直接用98%的硫酸和硝酸钾合成,合成和测试的视频在YouTube有
XXXXXXXXXXXXXXX/HYmCxP2PVVs
作为KCer上YouTube应该不是什么问题吧,从合成的视频来看,用的是68%硝酸和98%硫酸和赤癣醇,合成用的冰冷却混酸法,和PETN类似。
从多个测试的视频来看,ETN用铁锤20cm高度落锤不爆,但对温度极为敏感,极少量(0.05g)高温下开放加热直接爆。
另外再说一下赤癣醇,这个主要是作为一种甜味剂使用,甜味是蔗糖的两倍,比季戊四醇更和谐更便宜。
老外合成的讨论贴:
XXXXXXXXXXXXXXXXXXXXXXXXXXXXX/talk/XXXXXXXXXXXXXp?tid=26572&page=18#pid387259
XXXXXXXXXXXXXXXXXXXXXXXXXXXXX/talk/XXXXXXXXXXXXXp?tid=23432&page=2#pid386746
XXXXXXXXXXXXXXXXXXXXXXXXXXXXX/talk/XXXXXXXXXXXXXp?tid=10575&page=38#pid386871
需要主意的是后面精制的步骤,有个老外用了甲醇加热溶解去精制,结果出了意外,这个是帖子:
XXXXXXXXXXXXXXXXXXXXXXXXXXXXX/talk/XXXXXXXXXXXXXp?tid=22554
他说的精制的步骤:
This necessitated a recrystallization from hot methanol, which I proceeded to do in a large beaker on a radiant cooktop. I grabbed a 1L beaker and brought about 500 ml of MEOH to a low boil while dissolving 50 grams of crude brown ETN into the hot alcohol.
这里似乎是直接用红外炉加热甲醇,再投下ETN,结果ETN起爆,烧杯爆炸,导致烧杯碎片飞入其脖子和手臂受伤,最后还怪到了made in china的烧杯上面
BTW, the cause of the accident turned out to be the Chinese knockoff beaker that I bought at a kitchen store earlier that year. The "Pyrex" logo on another one bought at the same time, on closer inspection, read "Pyrox", with a tiny "made in China" text at the bottom. Instead of being made with Pyrex borosilicate glass, it was cheap soda-lime glass that couldn't stand up to heating. I never noticed the difference
他说这个烧杯不是耐热烧杯,但我更倾向于精制的过程使用水浴加热或磁力搅拌。而不应该使用直接加热。
几个ETN测试视频:
XXXXXXXXXXXXXXXXXXXXXXX/watch?v=gAe1pLXMiv0
XXXXXXXXXXXXXXXXXXXXXXX/watch?v=weDfp4zai3A ETN.png
来自:数理化 / 化学
39
smith 作者
9年3个月前 IP:日本
750488
老外起ETN的方法也是千奇百怪,有用起爆药的,也有不用起爆药的,用起爆药的话普通的HMTD可以,国外甚至有用我们的禁药TATP起的,不用起爆药则是桥丝较多
Einstein
9年3个月前 IP:江苏
750495
。。我看成PETN了才进来看看的
smith作者
9年3个月前 IP:日本
750497
引用 Einstein:
。。我看成PETN了才进来看看的
不是PETN,从国外的研究来看ETN有潜力成为一种安全的起爆药,合成难度中等,主要难度在于浓硫酸上。所以未来一段时间HMTD还是主流
博丽灵梦
9年3个月前 IP:河北
750510
您要不要看看这个
https://www.kechuang.org/t/65323
王者归来abs
9年3个月前 IP:北京
750514
那个我还发过2333333333事故报告
因为用了廉价的中国烧杯23333333333333333
王者归来abs
9年3个月前 IP:北京
750516
另外这个就是丁四醇四硝酸酯 以前做过 乌尔班斯基的书上有完整介绍
大董鸡
9年3个月前 IP:四川
750529
混酸制同样会有无法除去的硫酸酯杂质吗?
smith作者
9年3个月前 IP:日本
750530
引用 718281828kc:
您要不要看看这个
最后结论是什么?1.精制后可无起爆药使用?2.像太安一样当扩爆药?能否直接使用导火索?
9年3个月前 IP:日本
750532
老外这个贴子老早就看过了 贴吧里到处传
博丽灵梦
9年3个月前 IP:河北
750552
引用 smith:
1. 可以;2. 可以;3. 作死。。。。
博丽灵梦
9年3个月前 IP:河北
750553
引用 smith:
事实上这个已经在国外商品化了,是无起爆药*管
博丽灵梦
9年3个月前 IP:河北
750555
引用 77159:
老外这个贴子老早就看过了 贴吧里到处传
卧槽您在岛国?。。。。。。
friedel
9年3个月前 IP:上海
750562
加热能材溶液的玻璃器皿一旦破裂确实是挺可怕的,想想硝基四唑钠水溶液滴到电炉上还会噼里啪啦一阵响呢
QQQQQQQ
9年3个月前 IP:天津
750574
ETN做无起爆药雷管 ,没有MHN和SY有业余前途,主要ETN转爆轰还是费劲,不像MHN 松装 用铝纸包两层 一烧就炸,而且猛度会高于同样mg的DDNP和TATP
smith作者
9年3个月前 IP:日本
750595
引用 718281828kc:
不能直接使用导火索,是MHN、ETN之类的会和导火索的BP反应敏化,还是容易蹿火提前起爆?
博丽灵梦
9年3个月前 IP:河北
750598
引用 smith:
没反应233.。。。。。这个需要一定强度的起爆药
9年3个月前 IP:湖北
750604
引用 718281828kc:
卧槽您在岛国?。。。。。。
何以见得?
博丽灵梦
9年3个月前 IP:河北
750606
引用 77159:
何以见得?
9年3个月前 IP:湖北
750607
vpn挂着忘记关了....
Johnny-Wei
9年3个月前 IP:广东
750632
"另外再说一下赤癣醇,这个主要是作为一种甜味剂使用,甜味是蔗糖的两倍,比季戊四醇更和谐更便宜。 "
赤癣醇比季戊四醇贵啊,甘露醇才便宜
9年3个月前 IP:贵州
750653
哈哈,好贴。
王者归来abs
9年3个月前 IP:山东
750671
引用 friedel:
硝基四唑钠直接爆。。偶氮四唑钠才会噼里啪啦。。。亲测 不过我的是一滴溶液溅在磁搅上。。后来一开加热啪的一声吓得我玻璃棒都掉了
QQQQQQQ
9年3个月前 IP:天津
750712
引用 王者归来abs:
是的 NaNT是我见过的最响的盐,不过比SADDT慢了很多 ,但是真响。。。。。。
dracula1429
9年3个月前 IP:江苏
750715
请无视国内文献二逼到家的爆热计算
论密度和爆速比不得petn,论氧平衡比不得MHN正,它的唯一优点是在正氧的基础上熔点低仅61℃,有希望作为熔铸体系的载体,尤其是其含铝熔铸体极适合作为水下武器装药。不过在熔融时的感度有待研究,万一在熔融时感度激增,那它真是一点优点都没有了。
ps:楼主这贴让我想起三年前我还挺着迷这货的特意买了一公斤赤藓糖醇,现在应该在车库的哪个犄角旮旯里发霉了。
attachment icon 1_2_3_4-丁四醇四硝酸酯的合成、表征和性能.pdf 1.17MB PDF 1296次下载 预览
丑丑
9年1个月前 IP:四川
764200
长见识了   谢谢分享
洪水之势
8年11个月前 IP:浙江
778699
引用 Johnny-Wei:
赤癣醇比季戊四醇贵啊,甘露醇才便宜
某六酯,大作死-_-#
半个萌
7年4个月前 IP:浙江
830002
加热感度飙升,到溶液状态就和ng感度一样了,而且这个状态加铝更危险。建议做出来后不要做熔铸
新黑火药
5年11个月前 IP:江苏
846536
引用smith发表于15楼的内容
引用 718281828kc:1. 可以;2. 可以;3. 作死。。。。 不能直接使用导火索,是MH...
如果用中间是铁丝的那种仙女棒烟花条,直接插在ETN、MHN装药中间,利用烟花条产生的高温直接加热装药,能否直接引起爆炸?如果可行的话,是否也算是无起爆药起爆的一种方式呢
新黑火药
5年11个月前 IP:江苏
846537
引用Johnny-Wei发表于20楼的内容
"另外再说一下赤癣醇,这个主要是作为一种甜味剂使用,甜味是蔗糖的两倍,比季戊四醇更和谐更便宜。 "赤...
赤藓醇最便宜啊,食品级的14.5元一公斤,还包邮,前段时间刚买了一公斤,要是买不到硝酸,我就准备当甜味剂来吃了
smith作者
5年11个月前 IP:广东
846542
引用新黑火药发表于28楼的内容
如果用中间是铁丝的那种仙女棒烟花条,直接插在ETN、MHN装药中间,利用烟花条产生的高温直接加热装药...
用铝箔包覆,然后放在绑在仙女棒旁边也许可能,我用小神鞭没有加任何起爆药都起爆过铜铵,就是靠响子的那一节放出的大量热量
新黑火药
5年11个月前 IP:江苏
846561
引用smith发表于30楼的内容
用铝箔包覆,然后放在绑在仙女棒旁边也许可能,我用小神鞭没有加任何起爆药都起爆过铜铵,就是靠响子的那一...
为什么一定要用铝箔包裹,直接接触不行吗?
smith作者
5年11个月前 IP:广东
846578
引用新黑火药发表于31楼的内容
铝箔约束有助于DDT
zx-46612
5年11个月前 IP:甘肃
846591
引用新黑火药发表于28楼的内容
为什么要舍近求远呢,诸如HMTD、GTN等材料易得制备简单起爆效果好的药,干嘛非得用ETN,ETN普通混酸方法得率并不高,火感热感也没有你想象中的那么好,业余还是不要ETN当起爆药了,工艺不过关,起爆成功率不稳定,还会带来安全风险,想了解ETN可以看我的帖子
新黑火药
5年11个月前 IP:江苏
846593
引用zx-46612发表于33楼的内容
为什么要舍近求远呢,诸如HMTD、GTN等材料易得制备简单起爆效果好的药,干嘛非得用ETN,ETN普...
嗯,有道理,我只是一直感觉无起爆药雷管很高端,而ETN恰好有沸点轰爆的特性,所以往那个方向想象了一下。之所以现在对ETN感兴趣,完全是季戊四醇禁售不好买,有商家开价70元500克,还只能走物流,费用到付,到手就要90元了,而赤藓糖醇食品级的,淘宝价14.5元一公斤,还包邮。
dracula1429
5年11个月前 修改于 5年11个月前 IP:江苏
846595
无起并不高端,这是某企业已经工业化生产投放市场的无起产品。核心是激发药(多为猛炸药+高氯酸盐),关键工艺为形成飞片的内帽零件的预裂缝加工。要经过大量实验确定激发药的用量和预裂片的厚度、预裂缝的深度,使得飞片达到一定速度可以可靠地冲击起爆猛炸药。难主要难在加工精度和大量的实验论证上。
至于爆炸桥丝式的,想要使用几百发组网的雷管爆破网路,必须高度复杂化雷管结构,要不然就需要极高功率的起爆器。这两点基本就把这条路堵死了。
剩下的基本是偷换概念,比如GTX雷管,对外宣传GTX感度很低,与传统起爆药不同,但是这玩意我依然一砸一个响,比号称高感的EDDP感度高的多。
ps:无起也不能掉以轻心,去年某无起生产线压药响了。。。。。。响了。。。。。。关键是压药工房响了,还殉爆了隔壁的半成品库房。mmp这样看,这感度也低不到哪去。
烈马西风见雄鹰
5年5个月前 IP:江苏
853083
引用博丽灵梦发表于4楼的内容
您要不要看看这个https://www.kechuang.org/t/65323
请问此贴需要何种权限方可阅读?
赤藓醇四硝酸酯
5年3个月前 IP:山西
854242
我头像 我以为没人知道这东西呢。
3年8个月前 IP:北京
885991
有人说这种物质熔点太低可能会有些影响,不知。。。
MARK_GYC
1年1个月前 IP:北京
918124
乙二醇防冻液路过
smith
2015/01/11注册,1天8时前活动
收音机爱好者
IP归属地:广东
